jmorris6689 Posted January 30, 2012 Author Share Posted January 30, 2012 ^^^??? Link to comment Share on other sites More sharing options...
Slickvic Posted January 30, 2012 Share Posted January 30, 2012 homo Jealous neighbor?? Link to comment Share on other sites More sharing options...
bmx045 Posted January 30, 2012 Share Posted January 30, 2012 what were you thinking when you got that 4 puck setup? Link to comment Share on other sites More sharing options...
compsurge Posted January 30, 2012 Share Posted January 30, 2012 Because race car. Duh. Link to comment Share on other sites More sharing options...
bmx045 Posted January 30, 2012 Share Posted January 30, 2012 http://29.media.tumblr.com/tumblr_lpbe5xTr341qhixh0o1_500.png Link to comment Share on other sites More sharing options...
jmorris6689 Posted January 30, 2012 Author Share Posted January 30, 2012 It was a really good deal, but I'll just switch out the discs when money is a little more abundant, until ten ill just deal with the pains of a 4 puck Link to comment Share on other sites More sharing options...
jmorris6689 Posted February 4, 2012 Author Share Posted February 4, 2012 Ok so I got the transmission and everything in, and I can not seek to be able to get it to work. I've bleed the slave and master cylinders multiple times. And I cannot get a decent pedal feel and the clutch will not fully engage. I'm wondering if I over torqued the pressure plate bolts. Any one have suggestions? Link to comment Share on other sites More sharing options...
20lgt06 Posted February 4, 2012 Share Posted February 4, 2012 those are some strong cigar boxes that are under your jack stands:eek: nice build hate to ask your total cost on the swap and build Link to comment Share on other sites More sharing options...
jmorris6689 Posted February 4, 2012 Author Share Posted February 4, 2012 Yea the lifting blocks are made out of pressure treated wood they seem to do a good job with getting the car up high enough. And you ate correct this hasnot been a cheap process Link to comment Share on other sites More sharing options...
jmorris6689 Posted February 10, 2012 Author Share Posted February 10, 2012 I'm thinking the pressure plate I got maybe bad Link to comment Share on other sites More sharing options...
SBT Posted February 13, 2012 Share Posted February 13, 2012 Any bluing on it before you resurfaced it? - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
jmorris6689 Posted February 13, 2012 Author Share Posted February 13, 2012 Nope Link to comment Share on other sites More sharing options...
SBT Posted February 13, 2012 Share Posted February 13, 2012 Ok so I got the transmission and everything in, and I can not seek to be able to get it to work. I've bleed the slave and master cylinders multiple times. And I cannot get a decent pedal feel and the clutch will not fully engage. I'm wondering if I over torqued the pressure plate bolts. Any one have suggestions? Did your clutch MC completely drain? If so, you'll need to pull it and bench bleed it. Nope And there wasn't any rattling from the spring bits? Think it's more a MC thing without having my foot on the pedal. Is the slave cylinder moving fully through its engagement path when you depress the pedal? - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
jmorris6689 Posted February 13, 2012 Author Share Posted February 13, 2012 No I made sure that I didn't drain my mc and it's a brand new STi slave cylinder from the dealer. The clutch acted the same way in the car it came out of so we figured it was a slave cylinder, and everything looked fine before it went in. I think I might just have to wait on some money and buy a new clutch, unless some one donates haha Link to comment Share on other sites More sharing options...
SBT Posted February 14, 2012 Share Posted February 14, 2012 So, when you depress and hold the clutch pedal, the slave piston articulates completely and holds the throw-out arm fully extended. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
BDII Posted February 14, 2012 Share Posted February 14, 2012 anti-lag is stupid on a road legal car. Need forum help? Private Message legGTLT Link to comment Share on other sites More sharing options...
jmorris6689 Posted February 14, 2012 Author Share Posted February 14, 2012 ^ what does anti lag have to do with anything?! But yes when the pedal is pushed the slave extends to the proper length as specified by Subaru. And I bleed a pint of fluid through the master and slave cylinders, never letting either go dry and I used a vacuum pump to do so. Link to comment Share on other sites More sharing options...
SBT Posted February 14, 2012 Share Posted February 14, 2012 I mentioned the MC because of my experience with mine. I put a WRX SS clutch line, which was too short on mine, it leaked, and bled-out during a long-distance trip. Thought I caught it in time to just fill and go, but that was only marginally successful. Then bled it using vaccuum first on the MC, then on the SC. Still wasn't working correctly and until I pulled it and bench bled it, did it finally start working right. YMMV. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
jmorris6689 Posted February 14, 2012 Author Share Posted February 14, 2012 Yea I hope I don't have o bench bleed it, but that is easier than pullin out that transmissio and replacing the clutch Link to comment Share on other sites More sharing options...
BDII Posted February 14, 2012 Share Posted February 14, 2012 assembly is coming along slowly, but since it is taking this long, the heads have been ported and polished. Ill get some pics up soon of everything. also i was wondering if anyone knows who makes a anti lag setup for subaru's ive searched around here alot and all that ive really found has been exhaust tip flame throwers lol. But the car should be back on the road and tuned by late next week. ^ what does anti lag have to do with anything?! But yes when the pedal is pushed the slave extends to the proper length as specified by Subaru. And I bleed a pint of fluid through the master and slave cylinders, never letting either go dry and I used a vacuum pump to do so. Need forum help? Private Message legGTLT Link to comment Share on other sites More sharing options...
jmorris6689 Posted February 14, 2012 Author Share Posted February 14, 2012 Damn that was a year ago Link to comment Share on other sites More sharing options...
BDII Posted February 14, 2012 Share Posted February 14, 2012 I'm guessing you saw the error in your ways? Need forum help? Private Message legGTLT Link to comment Share on other sites More sharing options...
jmorris6689 Posted February 15, 2012 Author Share Posted February 15, 2012 No it just isnt needed on this turbo setup Link to comment Share on other sites More sharing options...
mwiener2 Posted February 16, 2012 Share Posted February 16, 2012 I've had clutchs not bleed on the car properly with a vacuum bleeder. You have to do it manually, alot. My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
jmorris6689 Posted February 16, 2012 Author Share Posted February 16, 2012 Yea I guess I'll have to give it a shot Link to comment Share on other sites More sharing options...
