Tundraman Posted July 26, 2016 Share Posted July 26, 2016 Like my 3.0R limited a lot- nice driving car, been reasonably trouble free. Until now... 7 years, 85k miles. Unfortunately, first major problem started last Friday. Constant misfires on cylinders 1 & 6. Car will intermittently start and run fine, then start misfiring or misfire immediately... odd. Only misfire codes (301,306) showing. Coils, plugs ok. Did the usual coil swap trick, tried a new plug, no fix. Grounds all good, clean. No fuel on the spark plugs for the misfiring cylinders. Suspecting that the injectors aren't being triggered- PCM problem. Don't mean to turn this into a troubleshooting thread.... Link to comment Share on other sites More sharing options...
theflystyle Posted July 26, 2016 Share Posted July 26, 2016 Like my 3.0R limited a lot- nice driving car, been reasonably trouble free. Until now... 7 years, 85k miles. Unfortunately, first major problem started last Friday. Constant misfires on cylinders 1 & 6. Car will intermittently start and run fine, then start misfiring or misfire immediately... odd. Only misfire codes (301,306) showing. Coils, plugs ok. Did the usual coil swap trick, tried a new plug, no fix. Grounds all good, clean. No fuel on the spark plugs for the misfiring cylinders. Suspecting that the injectors aren't being triggered- PCM problem. Don't mean to turn this into a troubleshooting thread.... I went through this exact same issue! Had to replace the ECU for it to go away $$$ Link to comment Share on other sites More sharing options...
Tundraman Posted August 7, 2016 Share Posted August 7, 2016 A new PCM fixed it. Had to pay the dealer.....diagnostic fee (even though I told them what the problem was.....), then programming time, and cost of the unit. Link to comment Share on other sites More sharing options...
theflystyle Posted August 8, 2016 Share Posted August 8, 2016 I feel your pain but am glad that fixed it. Just wish I knew what exactly in the PCM causes this issue. Link to comment Share on other sites More sharing options...
Tundraman Posted August 8, 2016 Share Posted August 8, 2016 I have the board out of the enclosure. Multi layer board, so I can't see a lead break if it's in the board itself. I have one component- need to identify it- that looks suspicious - brown edge, clear board overlay gone above it. Larger question is what caused it to smoke- internal structural failure or momentary external short (hope not!!). Link to comment Share on other sites More sharing options...
theflystyle Posted August 9, 2016 Share Posted August 9, 2016 I still have my old PCM. I took it out of the case and gave it a once over but didnt see anything suspicious. I still have it but would love to see a screenshot of where you are referring to so that I could do a comparison to mine. Link to comment Share on other sites More sharing options...
Tundraman Posted August 10, 2016 Share Posted August 10, 2016 Will post pix later. Link to comment Share on other sites More sharing options...
Jaisah-3.0R Posted November 2, 2016 Share Posted November 2, 2016 Has anyone used a tactrix cable and EcuFlash to tune their 2004 Subaru Legacy 3.0R? I can get RomRaider to connect and give me info but when I connect EcuFlash and try to read the rom off my ECU it just gives me an error. I have the green test cables connected. Link to comment Share on other sites More sharing options...
west_minist Posted November 2, 2016 Share Posted November 2, 2016 Use the sti04 or 05 method. Hook up all green connects by the ecu and driver side. Link to comment Share on other sites More sharing options...
Jaisah-3.0R Posted November 2, 2016 Share Posted November 2, 2016 Use the sti04 or 05 method. Hook up all green connects by the ecu and driver side. Cheers man, I couldn't find the one on the passenger side (Its JDM so right hand drive) but I finally managed to find it. Now I have managed to download the ROM off the ECU but the definition I have for EcuFlash either isn't right or theres nothing I can change The definition I have that matches is D2ZU002A (2004 JDM Legacy 3.0R AT DBW). Any idea why it wont let me view/change any data on my ROM? Any idea where to find a working ROM for my car? I got the ROM from here: http://www.romraider.com/forum/viewtopic.php?f=34&t=10664 Cheers Link to comment Share on other sites More sharing options...
west_minist Posted November 2, 2016 Share Posted November 2, 2016 You have to load the ecuflash file. I am not feeling you can really tune your car. If it is JDM, the car will have too much timing. Do go adding timing. Ok?!?! Link to comment Share on other sites More sharing options...
Jaisah-3.0R Posted November 2, 2016 Share Posted November 2, 2016 You have to load the ecuflash file. I am not feeling you can really tune your car. If it is JDM, the car will have too much timing. Do go adding timing. Ok?!?! You think my car will already have too much timing? I want to do some data logging and see if it's knocking and if it is I'll turn the advancement down a little bit. Is there anything I can do to tune my car? Timing, VVL, AF ratio, anything? I'm planning on getting some raptor headers at some point but I just want to start with tuning. I have loaded the definition and the ROM. It shows up on the screen but all the fields are greyed out and if I click on them they say something about not being properly defined. I can send you a screen shot tomorrow when I have another try. Do you think the definition file might be wrong or not compatible with my car or am I just using it wrong? Link to comment Share on other sites More sharing options...
west_minist Posted November 2, 2016 Share Posted November 2, 2016 Send a screen shot. Log and see and learn. Link to comment Share on other sites More sharing options...
Jaisah-3.0R Posted November 2, 2016 Share Posted November 2, 2016 Send a screen shot. Log and see and learn. Okay here are 2 screenshots. I'd really like to be able to tune my car, even if I can't get more power from the stock setup. It's a passion I've had for a while and I'm eager to learn how to do it. Timing, AF ratio, DBW, VVL, VVT and diagnostics are the things I want to learn about/tweak. Link to comment Share on other sites More sharing options...
west_minist Posted November 2, 2016 Share Posted November 2, 2016 import the ecuflash file. I haven't look at it to see if that ecuflash file is valid, but usually there are. Also check your ecuflash user permission level. Before even focus on tuning, log her. See the link that can help you log. 32bit ECU - H6 3.0R http://xtremeracingtuning.com/forum/viewtopic.php?f=113&t=501#p1530 Do you have any tuning experience? Link to comment Share on other sites More sharing options...
Jaisah-3.0R Posted November 2, 2016 Share Posted November 2, 2016 import the ecuflash file. I haven't look at it to see if that ecuflash file is valid, but usually there are. Also check your ecuflash user permission level. Before even focus on tuning, log her. See the link that can help you log. 32bit ECU - H6 3.0R http://xtremeracingtuning.com/forum/viewtopic.php?f=113&t=501#p1530 Do you have any tuning experience? I cant find any way to import the ecuflash file. Do you mean the ROM or the definition? I've defined the location of the definitions under File>Options>metadata location and I've opened the ROM. You can see on the left that it has recognised my ROM correctly but no tables show up. I've set my user level to advanced and its also set to show tables that are outside of my use level but grey them out, still nothing showing. I guessing either this definition is faulty or it doesn't quite match my ROM. No tuning experience, just a passion for cars and a lot of reading/watching videos on the basics of tuning (timing, AF ratios, knock, load, VVT, VVL etc) Link to comment Share on other sites More sharing options...
west_minist Posted November 2, 2016 Share Posted November 2, 2016 Put the ecuflash file from RR website in the ecuflash location meta area. That's ok. We all started from.some place. Link to comment Share on other sites More sharing options...
Jaisah-3.0R Posted November 3, 2016 Share Posted November 3, 2016 Put the ecuflash file from RR website in the ecuflash location meta area. That's ok. We all started from.some place. I've done that. I downloaded the list of definitions from the RomRaider website and saved them into the metadata file in the EcuFlash file (where EcuFlash was installed) and then I went into the EcuFlash settings and made sure that it was referencing the correct location, which it is. Then I opened the ROM that I downloaded from my car and now I'm here. I'm 99% sure I've done everything correctly and EcuFlash says that it has loaded my ROM and that it's "using metadata XML ID D2ZU002A from file C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata/subaru metric/Legacy 3.0R/D2ZU002A.xml" but no tables show up, there's nothing I can change, nothing I can view. Link to comment Share on other sites More sharing options...
98legwag Posted November 3, 2016 Share Posted November 3, 2016 I'm just going to leave this here. http://i1098.photobucket.com/albums/g378/98legwag/2009%20%20Legacy%20R/20161023_152240_zpsv0cgruqm.jpg Link to comment Share on other sites More sharing options...
Geckoboy86 Posted November 6, 2016 Share Posted November 6, 2016 My 3.0R Link to comment Share on other sites More sharing options...
R3wir3d Posted December 22, 2016 Share Posted December 22, 2016 3.0r spec b 6mt. http://uploads.tapatalk-cdn.com/20161222/aeb738ac78e6106d33d92eebe16002c5.jpg Link to comment Share on other sites More sharing options...
west_minist Posted December 24, 2016 Share Posted December 24, 2016 I love the Spec B. There do respond very well to tuning begs for upgrades like boost. The last one I worked on was producing very good results. 3.0r spec b 6mt. http://uploads.tapatalk-cdn.com/20161222/aeb738ac78e6106d33d92eebe16002c5.jpg Link to comment Share on other sites More sharing options...
R3wir3d Posted December 31, 2016 Share Posted December 31, 2016 I love the Spec B. There do respond very well to tuning begs for upgrades like boost. The last one I worked on was producing very good results. Would love to put a tune on mine but am yet to do some supporting changes. Was thinking exhaust and headers before going down that path at the very least. Sent from my SM-G930F using Tapatalk Link to comment Share on other sites More sharing options...
west_minist Posted December 31, 2016 Share Posted December 31, 2016 As a driver, the big mod is the tune. Link to comment Share on other sites More sharing options...
R3wir3d Posted December 31, 2016 Share Posted December 31, 2016 As a driver, the big mod is the tune. Have you tuned the ez30 yourself? Link to comment Share on other sites More sharing options...
