blacksus Posted April 23, 2011 Share Posted April 23, 2011 sorry guys this might be a dumb question but where would you add seafoam to a NA legacy? Link to comment Share on other sites More sharing options...
compsurge Posted April 25, 2011 Share Posted April 25, 2011 http://www.scoobymods.com/idle-speed-control-valve-cleaning-t3909.html?t=3909 Edit: I just looked at this link after I posted it several weeks ago... Don't know exactly why I put this one here. I thought I had one that displayed the proper location for a vacuum line to do this with. Link to comment Share on other sites More sharing options...
lensflare Posted May 7, 2011 Share Posted May 7, 2011 I had a turbo sentra with clogged up injectors and I swear I ran a bottle of seafoam and bam it was boosting like a champ again. I love this stuff! Link to comment Share on other sites More sharing options...
CousinLarry Posted May 15, 2011 Share Posted May 15, 2011 Big believer in this stuff. I use it in everything I own that has a motor. I got proof it worked. On my dirtbike, I was doing a head gasket change. When I pulled the head the valves and piston were covered in hard carbon deposits. I didn't have anything handy to clean it off with, and I was in a rush to get riding again, so I put it back together like that. A little while later I ran seafoam through a vacuum line, and put some in the gas tank. About a thousand miles later the headgasket went again. I pulled the head and the piston and valves looked clean and almost new. Made me a believer, I use it all the time. Just picked up an 05 LGT, going to run some through! Link to comment Share on other sites More sharing options...
subarulegay Posted May 17, 2011 Share Posted May 17, 2011 sorry guys this might be a dumb question but where would you add seafoam to a NA legacy? i want to know too..a picture would help! Link to comment Share on other sites More sharing options...
06_legacygt Posted May 21, 2011 Share Posted May 21, 2011 you can use almost any vac line that goes into the intake. most shops do it through the brake booster line, however because of the design of our manifolds i would try to find a line that gets you as close to possible of the center of the intake, which would be at the T by the BPV which goes to the T under the TMIC 2006 Legacy GT 5EAT Perrin UP, SPT CAI, OBXR CBE, Catless DP, Perrin TMIC, Stage 2 AP tune Soon after BNR 16G, Infamous Tune Link to comment Share on other sites More sharing options...
subarulegay Posted May 23, 2011 Share Posted May 23, 2011 sorry i asked about a 2.5 N/A i dont have a BPV Link to comment Share on other sites More sharing options...
SpecBGuy Posted May 23, 2011 Share Posted May 23, 2011 . Link to comment Share on other sites More sharing options...
dustincredible Posted June 1, 2011 Share Posted June 1, 2011 Just did this today. Instructions were spot on. Thanks OP! Sold: 2006 Subaru Legacy GT Spec B #104 of 500 Link to comment Share on other sites More sharing options...
jaxx4k Posted June 3, 2011 Share Posted June 3, 2011 BOV vac. hose is good... you slowly pour 1/3-1/2 bottle in there let it do it's magic, clean out all carbon on engine and turbo.let it sit for 10-15 min smoke out your house/block, pour the rest in gas tank and be done with total time took bout 30 min 1 man. if you have 2 guys take 15 min. Link to comment Share on other sites More sharing options...
CRogge Posted June 5, 2011 Share Posted June 5, 2011 I Seafoamed today and the car has never run better! It used to stall occasionally when returning to idle during the learning period after an ECU reset and always idled rough. It also had a pretty good stutter during acceleration. All of that is gone now! It feels like a whole new car! I added 1/3 of the bottle to the hose shown in the picture (BOV?), let it sit 5 minutes and then started it up and smoked out the driveway. The rest went into the oil and I'll put in fresh oil as soon as it cools down a bit. Link to comment Share on other sites More sharing options...
subarulegay Posted June 8, 2011 Share Posted June 8, 2011 ive got a bottle of seafoam waiting to be used on N/A 2.5i legacy but still have not found any info on which hose to use to suck it up can anyone help with a picture please? Link to comment Share on other sites More sharing options...
Max Capacity Posted June 10, 2011 Share Posted June 10, 2011 ive got a bottle of seafoam waiting to be used on N/A 2.5i legacy but still have not found any info on which hose to use to suck it up can anyone help with a picture please? Sounds like you want to put it directly into the intake system. I would just run the tank down to about 2 gallons left and dump it in the gas tank. Drive for about 30 miles then add about 2 or 3 gallons and drive it for about 40 miles then fill the tank. Or there must be a line after the air filter and before the throttle body. use that. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
quick4dr Posted July 4, 2011 Share Posted July 4, 2011 do I just suck up the seafoam with the vacuum line that connects to the BPV? Link to comment Share on other sites More sharing options...
compsurge Posted July 5, 2011 Share Posted July 5, 2011 Yes. Bring on the smoke show Link to comment Share on other sites More sharing options...
bigdadi Posted July 27, 2011 Share Posted July 27, 2011 i want to know too..a picture would help! For non-turbo ... use the PCV valve Link to comment Share on other sites More sharing options...
boostedgrocerygetter Posted July 29, 2011 Share Posted July 29, 2011 i know its been said but there is no reason to change your plugs after this process is done. never personally used seafoam but ive done countless BG fuel and intake system services. youll just want to change the oil due to the cleaner contaminating your oil from blow by. and my vote is for the throttle body if easily accessed for even dispersment through each runner. Link to comment Share on other sites More sharing options...
HDTurbo Posted July 29, 2011 Share Posted July 29, 2011 youll just want to change the oil due to the cleaner contaminating your oil from blow by. +1 I Seafoam (and a short, spirited, smoky drive....) right before O/F change. Link to comment Share on other sites More sharing options...
cbt299 Posted August 13, 2011 Share Posted August 13, 2011 just got some to put in the tank Link to comment Share on other sites More sharing options...
bigdadi Posted August 14, 2011 Share Posted August 14, 2011 just got some to put in the tank This is Step-1 and safest bet. I do it every 3 - 6 months. Link to comment Share on other sites More sharing options...
legacyshawn Posted August 17, 2011 Share Posted August 17, 2011 I've got a bottle waiting for me at home but only have 2500 miles on this oil. I'll wait another 2500 to do the seafoam. But i'm pumped. I guess i've concluded i'll do it throughout the pcv line but i don't know how or where to disconnect it. heck i don't even know what it does! lol Link to comment Share on other sites More sharing options...
I Donated Too luchadorjose Posted September 14, 2011 I Donated Too Share Posted September 14, 2011 lazy subscribe Link to comment Share on other sites More sharing options...
OutbackXT05 Posted September 14, 2011 Share Posted September 14, 2011 Would it be smart if ypu have a boost gauge teed off to the bpv line to disonnect it before the tee so the boost gauge doesnt get effected or eill it not do anything? Link to comment Share on other sites More sharing options...
compsurge Posted September 14, 2011 Share Posted September 14, 2011 Probably. I was going to do that anyway. Seafoaming soon as I'm due for an oil change and banjo bolt filter replacement. Link to comment Share on other sites More sharing options...
I Donated Too luchadorjose Posted September 14, 2011 I Donated Too Share Posted September 14, 2011 Is there anywhere that has a super detailed walkthrough? I want to do this but I'm getting super nervous about f*&%ing with the lines... detailed pictures anywhere? how fast to pour? do you start with the car on or off? when would you turn it on? etc. Sorry for being a noob Link to comment Share on other sites More sharing options...
