Custom Plaid Sub Box
The next project for my car I ave decided is a sound system. Nothing too crazy, but something that sounds good. I picked up a few members' ideas and put together a stealthy sub box that fits in the spot above the spare tire in the trunk of my Outback. This way I don't lose any cargo space, but I still get the kick of a sub.
Note: I am a not an acoustic engineer or audiophile, but I did get this done for $25. It was $10 for the wood at Home Depot, and $15 for the fabric and spray adhesive.
The box was built in two halves. I started with the top half because it was easier. A few simple cuts, screw, and glue.
http://img521.imageshack.us/img521/7418/01bottomcaulk.jpg
Next up I fabbed the bottom. I used the circle cutout from the top, and put it in a modded 5 gallon bucket. This extends the bottom of the box for more cubic feet and a larger mounting depth. Here is a test fit of the top half mated with the bottom half.
http://img210.imageshack.us/img210/7861/02testfit2halves.jpg
Next I set the height of bucket. This was kind of awkward, and a nail gun came in handy to tack the pieces together real quick. I realize a 5 gallon bucket is not the best material to use, but it was hanging around, and worked perfect. We'll see how it works I guess.
http://img806.imageshack.us/img806/7763/04setbottomheight.jpg
I added some vertical braces in the lower section of the box. I don't know if they will do anything, but I felt good putting them in. The crossmemebers come out in the next step. Also, I caulked pretty much every joint I could to maintain (or at least try) acoustic integrity.
http://img163.imageshack.us/img163/3156/03caulkandbrace.jpg
Back to the top half. I cut out a hole for the speaker posts.
http://img806.imageshack.us/img806/4121/05cutoutforposts.jpg
Both halves screwed and glued. This is the box upside-down.
http://img62.imageshack.us/img62/5193/06bothhalvesbottom.jpg
View from the top. It's looking a little better...
http://img696.imageshack.us/img696/6971/07bothhalvestop.jpg
Covering in fabric. I went with something semi-ridiculous and more importantly cheap. It's gonna be hidden anyway. I used 3M spray adhesive, it worked great; I have never used spray adhesive before.
http://img814.imageshack.us/img814/7278/08plaidcovering.jpg
All done. The box measures about 20"x20"x7", and has an internal volume of .66 cubic feet. I am using a Rockford Fosgate 10" sub.
http://img85.imageshack.us/img85/8058/09finalassembly.jpg
I can't hook it up yet because I don't have anything to hook it up to yet, but it looks pretty, and it DOES fit in the trunk of my car!
