max6spd Posted April 10, 2011 Share Posted April 10, 2011 I'm using one from a Toyota Matrix temporarily. I need one one with loops on the top and clips on the bottom. The Matrix one has clips on the top and bottom. Link to comment Share on other sites More sharing options...
max6spd Posted April 12, 2011 Share Posted April 12, 2011 No. An 04-07 STi rear sway will fit the 04-08 FXT. An 08+ STi rear sway will fit the 10+ LGT. Link to comment Share on other sites More sharing options...
Syracuse36R Posted May 4, 2011 Share Posted May 4, 2011 Do the front clip or headlights from the JDM and/or Australian models fit the US Legacy? Link to comment Share on other sites More sharing options...
CL21376 Posted May 9, 2011 Share Posted May 9, 2011 Hawk HPS Front--HB533F.668 Hawk HPS Rear--HB671F.628Â I got them from Andrew Racing Link to comment Share on other sites More sharing options...
killerniceguy Posted June 15, 2011 Share Posted June 15, 2011 2004--->up Brembo FRONT caliper 2008--->up Brembo REAR caliper 2004--->STi Front Rotor Has this been confirmed? Further, do you need to use the 2004--->STi front rotor with the 2004--->STI Brembo front caliper, or will the STi caliper fit the LGT rotor. Link to comment Share on other sites More sharing options...
DeltaSniper Posted June 15, 2011 Share Posted June 15, 2011 (edited) KCA 326 Whiteline Rear Camber Bushings for 08+ STI Edited June 18, 2011 by DeltaSniper Link to comment Share on other sites More sharing options...
minuccims Posted June 15, 2011 Share Posted June 15, 2011 Has this been confirmed? Further, do you need to use the 2004--->STi front rotor with the 2004--->STI Brembo front caliper, or will the STi caliper fit the LGT rotor.  I've got Waz's old setup on the LGT. The OEM front rotors are not compatible with the STI calipers. Yes - 2004 STI Rotors since they are 5x100. Any 2004+ STI Caliper works. For the rears, need 08+ caliper and rotors for the eBrake. Have 08+ rotors cross drillled for 5x100 pattern. Link to comment Share on other sites More sharing options...
Waaazooo Posted June 15, 2011 Share Posted June 15, 2011 Brembo sells rear 2008 + rotors that are drilled specifically for 2010 lgt. Fred beans sells them, I don't have a last number. Sent from my ass using Tapatalk Link to comment Share on other sites More sharing options...
minuccims Posted June 16, 2011 Share Posted June 16, 2011 Hey Waz, thanks for posting the update. Brembos have been fantastic. Another transforming upgrade for the LGT. Link to comment Share on other sites More sharing options...
blklgt05 Posted June 18, 2011 Share Posted June 18, 2011 KCA 236 Whiteline Rear Camber Bushings for 08+ STIÂ are u sure its not KCA 326?? mod journal Link to comment Share on other sites More sharing options...
DeltaSniper Posted June 18, 2011 Share Posted June 18, 2011 Kept typing that damn number the wrong way.. yeah its KCA326. Link to comment Share on other sites More sharing options...
DeltaSniper Posted June 18, 2011 Share Posted June 18, 2011 And from the look of the online how-to's on the KCA326, it looks like its gonna be a MAJOR pain in the ass... lol.... Link to comment Share on other sites More sharing options...
kncart Posted June 18, 2011 Share Posted June 18, 2011 As long as you don't mind dropping the sub-frame, it's not bad at all Link to comment Share on other sites More sharing options...
dynamic_3.6 Posted June 19, 2011 Share Posted June 19, 2011 I can verify that the TOYOTA ELECTRONIC 4 LED FLASHER BLINKER TURN SIGNAL FIX: http://www.v-leds.com/BlinkerWarning...-p4481146.html works for the 5th gen legacy and makes all four turn signals blink at the correct speed AND retain all functionality (e.g. all the turn signals flash when the doors are locked/unlocked with the key fob). I'm using one with LED turn signal bulbs now. Link to comment Share on other sites More sharing options...
blklgt05 Posted June 22, 2011 Share Posted June 22, 2011 I can verify that the TOYOTA ELECTRONIC 4 LED FLASHER BLINKER TURN SIGNAL FIX: http://www.v-leds.com/BlinkerWarning...-p4481146.html works for the 5th gen legacy and makes all four turn signals blink at the correct speed AND retain all functionality (e.g. all the turn signals flash when the doors are locked/unlocked with the key fob). I'm using one with LED turn signal bulbs now. plz post installation pictures/instructions, thank you! mod journal Link to comment Share on other sites More sharing options...
themlruts Posted June 23, 2011 Share Posted June 23, 2011 plz post installation pictures/instructions, thank you! +1 Link to comment Share on other sites More sharing options...
dynamic_3.6 Posted June 25, 2011 Share Posted June 25, 2011 It's already installed so I missed the boat on that one but I'll take some pics of the screw/ fastener locations. The actual installation is really easy, its plug and play. Check out post #10 in this thread for good pics of the dash with the trim removed: http://legacygt.com/forums/showthread.php/ohm-resistors-do-need-turns-fr-and-rear-and-taillights-152140.html?t=152140&highlight=flasher Link to comment Share on other sites More sharing options...
dynamic_3.6 Posted June 25, 2011 Share Posted June 25, 2011 I started a new thread with pics. http://legacygt.com/forums/showthread.php/steering-column-dash-trim-removal-164783.html?p=3443443#post3443443 Link to comment Share on other sites More sharing options...
LOOKATLEGACY Posted June 27, 2011 Share Posted June 27, 2011 Will set of TEIN lowering springs for a 06-07 SUBARU STI fit on my 2011 legacy 2.5i? Link to comment Share on other sites More sharing options...
GravityGear Posted June 27, 2011 Share Posted June 27, 2011 no, but the tein lowering springs for the 2010+ legacy will fit your 2011 legacy 2.5i. Link to comment Share on other sites More sharing options...
SoullessCorpse Posted July 8, 2011 Share Posted July 8, 2011 Can parts for a GT be used on a non GT Legacy? Link to comment Share on other sites More sharing options...
ikonosin Posted July 8, 2011 Share Posted July 8, 2011 Can parts for a GT be used on a non GT Legacy? Depends on the part. Engine parts, no. Appearance & suspension, yes. Link to comment Share on other sites More sharing options...
BADLEGACY11 Posted July 24, 2011 Share Posted July 24, 2011 anybody know if the under seat oem sub for the 4th gen works for the 5th gen legacy? i've looked at numerous pics and I can't see much of a difference. any help? Link to comment Share on other sites More sharing options...
Nacron Posted July 25, 2011 Share Posted July 25, 2011 anybody know if the under seat oem sub for the 4th gen works for the 5th gen legacy? i've looked at numerous pics and I can't see much of a difference. any help? I think the sub itself is the same across all years but it's the bracket and harness that make it specific for the 5th gen. They also come with extensions for one of the AC ducts and a cap for the other so that you don't get condensation on the sub. Link to comment Share on other sites More sharing options...
ebo03 Posted July 29, 2011 Share Posted July 29, 2011 Whiteline KDT902 Positive Traction Kit. Usually seen advertised for 2008+ WRX & STI. They are rear subframe bushing inserts that really do a good job of firming up around the rear diff. Link to comment Share on other sites More sharing options...
