define Posted June 16, 2010 Share Posted June 16, 2010 If I slowly release the clutch with just a small amount of throttle, sometimes the car will continue its rate of acceleration until I depress the clutch or tap the brake. It results in a lurching forward for quite a ways. I can have no feet on any pedals but it will continue accelerating. If I don't press the clutch/brake, it will eventually stop after a few seconds. Anyone else ever experience this? Link to comment Share on other sites More sharing options...
Vitamin_G Posted June 16, 2010 Share Posted June 16, 2010 Engine trying to prevent itself from stalling maybe? Link to comment Share on other sites More sharing options...
define Posted June 16, 2010 Author Share Posted June 16, 2010 Possibly. It is a bit unnerving, though...and I would hate for it to happen if my wife was driving. She would probably freak out Link to comment Share on other sites More sharing options...
Vitamin_G Posted June 16, 2010 Share Posted June 16, 2010 How high do the RPMs climb when it happens? Link to comment Share on other sites More sharing options...
define Posted June 16, 2010 Author Share Posted June 16, 2010 ~2k, I think. I'll pay more attention to that tomorrow and report back. Link to comment Share on other sites More sharing options...
snow05gtRI Posted June 16, 2010 Share Posted June 16, 2010 i feel like i've read about an issue with the Drive By Wire system related to this you're talking about. but thats all i can say. Link to comment Share on other sites More sharing options...
urfsin Posted June 16, 2010 Share Posted June 16, 2010 I have felt the same thing, but it's not all the time on my car. It only happens if I release the clutch in a particular way. I seem to avoid it for the most part. Slide It Sideways Link to comment Share on other sites More sharing options...
burnout8488 Posted June 16, 2010 Share Posted June 16, 2010 Is it PULLING itself to 2krpm or is it coasting UP to 2krpm on a slight downgrade possibly? For comparison: My car will idle at 500rpm in 1st and pull the car no problem on a flat surface, feet off the pedals. Never increases or decreases revs. Link to comment Share on other sites More sharing options...
proflatlander15 Posted June 16, 2010 Share Posted June 16, 2010 I have had the same problem, more so in traffic. Link to comment Share on other sites More sharing options...
joeleodee Posted June 16, 2010 Share Posted June 16, 2010 My car does this. I never really thought anything about it since it does not climb that high in RPM, but maybe it does and I don't notice it. Link to comment Share on other sites More sharing options...
jmorris6689 Posted June 16, 2010 Share Posted June 16, 2010 yeah mine does the same thing. it will usually do it when i am going up my steep driveway when i let the clutch out a certain way. Link to comment Share on other sites More sharing options...
CwhillVT Posted June 16, 2010 Share Posted June 16, 2010 I used to notice that but I haven't noticed it since I swapped the clutch and flywheel(lwfw). I think it had to do with letting the clutch out a certain way- I must have altered my clutch modulation with the new one. Link to comment Share on other sites More sharing options...
define Posted June 16, 2010 Author Share Posted June 16, 2010 Is it PULLING itself to 2krpm or is it coasting UP to 2krpm on a slight downgrade possibly? For comparison: My car will idle at 500rpm in 1st and pull the car no problem on a flat surface, feet off the pedals. Never increases or decreases revs. Oh, it's definitely PULLING the car up to 2k. It happened yesterday at work. The driveway to my work is noticeably uphill. After the gate opened, I started moving forward a bit and the car began lurching on its own. I had to hit the brakes since there was cross traffic. Interesting to see so many others with the same experience. Link to comment Share on other sites More sharing options...
Underdog Posted June 16, 2010 Share Posted June 16, 2010 Same experience here, even with the new WRX FW and ACT clutch. It is very easy to drive around once you know about it. Even so, it still bugs me. The Crimson Dynamo Link to comment Share on other sites More sharing options...
JBamin Posted June 16, 2010 Share Posted June 16, 2010 if the engine is on and the car is in gear and u slowly release the clutch just about every vehicle known to man will do what your saying.. this is nothing out of the ordinary. none the less you should properly show your wife how to stop the vehicle. put the car in neutral or have the clutch pedal pressed if you are sitting still. Link to comment Share on other sites More sharing options...
define Posted June 16, 2010 Author Share Posted June 16, 2010 if the engine is on and the car is in gear and u slowly release the clutch just about every vehicle known to man will do what your saying.. this is nothing out of the ordinary. none the less you should properly show your wife how to stop the vehicle. put the car in neutral or have the clutch pedal pressed if you are sitting still. Ok, so you haven't experienced it...calm down. This isn't just the engine idle carrying the car forward. This is the engine/ecu applying throttle on its own. As in, the speed of the engine and thus the vehicle increases even when going uphill, without any throttle manipulation at all. Engaging first gear without throttle should either lug along slowly or stall out in the case of a hill. And for those following, I reproduced it a few times this morning and it always goes up to ~2200rpm before it cuts out and returns to idle. Link to comment Share on other sites More sharing options...
Vitamin_G Posted June 16, 2010 Share Posted June 16, 2010 Why does this bring to mind images of power lines and a Prius? Link to comment Share on other sites More sharing options...
SCSpecB Posted June 16, 2010 Share Posted June 16, 2010 I think its a rebadged toyota.... ....being cereal tho, thats odd. Fortunately haven't had that issue. Link to comment Share on other sites More sharing options...
dingbang Posted June 17, 2010 Share Posted June 17, 2010 mine does the same thing...it almost feels like the accelerator is sticking after you release clutch and press down the power pedal a little bit. if i left off the pedal immediately after i give it a little gas, it does surge a tad. used to it now Link to comment Share on other sites More sharing options...
Vitamin_G Posted June 17, 2010 Share Posted June 17, 2010 +1 for 5eat conversion Link to comment Share on other sites More sharing options...
snow05gtRI Posted June 17, 2010 Share Posted June 17, 2010 i'm still blaming the DBW system. Link to comment Share on other sites More sharing options...
define Posted June 17, 2010 Author Share Posted June 17, 2010 Well, it's certainly a great place to start. If the throttle plate is being held open, it sure as hell isn't because my foot is asking it to be I guess I could data log a few of these events and try to see what's going on. Link to comment Share on other sites More sharing options...
