c_W_j Posted June 15, 2010 Share Posted June 15, 2010 What is this? Why is it making a humming sound? Where can I find pdf engine diagrams? Winner gets a cookie! http://i439.photobucket.com/albums/qq120/CWJ/IMGP5322crop.jpg Link to comment Share on other sites More sharing options...
kaz98gt Posted June 15, 2010 Share Posted June 15, 2010 are you sure it's not the pcv valve right above it? or the crankcase vent right below it? or it could be the air intake vacuum hose immediately below the electrical clip. Link to comment Share on other sites More sharing options...
c_W_j Posted June 15, 2010 Author Share Posted June 15, 2010 Well, Bill from Broken Motorsports and I (mostly him) picked around in it. He basically checked all those things, but the hum went away when that part was unplugged. Ironically, I was going to remove and check the piece last week without realizing that's where the sounds was coming from (I thought it was coming from the clutch slave cylinder), but those 12 year old screws are mighty soft. Any idea what that part is? Link to comment Share on other sites More sharing options...
Stang70Fastback Posted June 15, 2010 Share Posted June 15, 2010 That is the top of the Idle Air Control Valve. It's just an electromagnet really that controls the valve underneath to regulate the air coming into the engine at idle. Where's my cookie? Link to comment Share on other sites More sharing options...
Platinum_Racing Posted June 16, 2010 Share Posted June 16, 2010 Damnit, I wanted a cookie.... Link to comment Share on other sites More sharing options...
Bassnectar Posted June 16, 2010 Share Posted June 16, 2010 you need to order a gasket, and then you can clean the idle air control valve and most likely stop the hummz Link to comment Share on other sites More sharing options...
c_W_j Posted June 16, 2010 Author Share Posted June 16, 2010 Ah Thanks, gents. Cookie was for all 3 questions, Stang. If somebody can tell me where to get engine a pdf service manual, I'll let you split it two or three ways Link to comment Share on other sites More sharing options...
Zues Marine Posted June 16, 2010 Share Posted June 16, 2010 i have all the factory service manuals 95-99 in pdf, ill upload when i get home Link to comment Share on other sites More sharing options...
c_W_j Posted July 4, 2010 Author Share Posted July 4, 2010 to update... finally got around to removing IAC for cleaning, tried alcohol, reattached, drove for a couple miles and.... P0507 shows up now. and I realized the hummmmmm is from the airbox, not the IAC. it's actually idling fine and speeds up when the IAC sensor is unplugged, so I think I somehow didn't put the TPS back on right or one of the hoses is loose. meh. Happy 4th. Link to comment Share on other sites More sharing options...
98quiksilvergt Posted July 4, 2010 Share Posted July 4, 2010 Alldatadiy.com i use it and I love it! They give you part #'s, labor times, and sometimes part prices. Also technical service bulletins. I think it's 20.00 a year or something like that. I haven't had to renew it yet so, I don't remember. It's awesome! Diagrahms, schematics..... Well worth it!!! Link to comment Share on other sites More sharing options...
Reuben Posted July 5, 2010 Share Posted July 5, 2010 Pfffft, you give cookies for identifying the ICV? Do i get one if i point out the TPS? And ICV's don't make a sound. And a hmmmm from the airbox is totally and utterly normal, it gets 10 times louder if you use a pod filter. That my boy is induction noise! You might want some new gaskets for that sucker now btw... Link to comment Share on other sites More sharing options...
c_W_j Posted July 5, 2010 Author Share Posted July 5, 2010 Pfffft, you give cookies for identifying the ICV? Do i get one if i point out the TPS? And ICV's don't make a sound. And a hmmmm from the airbox is totally and utterly normal, it gets 10 times louder if you use a pod filter. That my boy is induction noise! You might want some new gaskets for that sucker now btw... A properly closed airbox doesn't hum like this - as evidenced when I pressed down on the box and hum went away. I also wouldn't call induction noise a "hum". More look "vroom". Maybe "whoosh". Such was the case on my last vehicle with an open airbox (with securely fastened filter. Now, send me a set of airbox clips and send you a whole batch of cookies. Link to comment Share on other sites More sharing options...
Reuben Posted July 5, 2010 Share Posted July 5, 2010 My ex's car. You could hear it's hum a mile away. HMMMMMMMMMMMMMMMMMMMMMMMMM. But yeah, i think you're onto it, airbox clips. Link to comment Share on other sites More sharing options...
c_W_j Posted July 5, 2010 Author Share Posted July 5, 2010 and, in the final bit of fun.....i'm not so much missing clips as I am in need of a top half an airbox that doesn't have the tab holes at the back broken off. but, hey, the CEL went off... Link to comment Share on other sites More sharing options...
