post your age here !
08 LGT
STiMikey Tuned GTX3071r PZEV badge
GS TMIC perrin inlet, coated ELH, id1000s, DW65C, iag oil line, group n motor/trans mount, trans bushings, avo sts and bushings, kartboy endlinks, hotchkis sways, blast plates, southbend stage 3 daily clutch, cobb ap v3, ewg, oil catch can
Loss Wages NV
Sent from outer space
Follow me on IG @chefodiycarguy
and @chefo.soriano
  • Replies 401
  • Created
  • Last Reply
I honestly thought I had posted in this thread a long time ago, but apparently not, so here goes for the working people in the house tonight:
56-57 next month. Older than most, not all, but most dirt and even some water.
2005 Subaru Legacy GT 2.55 5EAT Non Limited with (gasp) cloth interior
ENGINE COMPARTMENT
Bored to 100mm, diamond honed, decked and surfaced block by Thirlby Automotive in Traverse City Michigan
STi Forged and Nitrided crank
Manley H Beam rods
CP 100mm Forged pistons
King race bearings
ARP Block bolts, rod bolts, head studs, and basically just about every bolt and stud.
Moroso 6 quart oil pan and pickup-completely studded and I USE A GASKET
Brian Crower Ti Springs and retainers
Supertech valves
Agency Power Equal Length Header-DEI Ti wrapped
Grimmspeed Up pipe-DEI-Ti wrapped
Cobb catted down pipe-DEI Ti wrapped
What started out as Ebay catback-modified with Schoenfeld racing muffler in the mid pipe and entire mid pipe to the Y is DEI Ti wrapped (try it, it works great to adjust the interior sound of the exhaust)
Perrin turbo inlet and post MAF hose
Cobb EBCS
K&N Panel filter
Perrin fuel rails and equal length braided stainless fuel lines
Stewart Warner mechanical "Truth" oil pressure gauge under the hood
Mishimoto aluminum radiator
Custom made (by me) aluminum upper radiator hose spacer
Perrin TMIC heat coated in red and Perrin TBH
A-Spec front strut tower support
All silicone vacuum hoses, all zip tied
JMP Custom VF40 with Thermal Zero blanket and Grimmspeed heat shield
Subtle alternator and radiator covers
New Mishimoto belts
More I'm too tired to list
SUSPENSION
BC BR coilovers with Swift Springs (cmon guys, bust on me, I can take it :p)
Whiteline front LCA bushings front and rear (and I clean up and paint everything I touch so my knuckles, LCA are painted red to match the Perrin sway bars)
Whiteline RCA kit
Perrin 25mm sway bars front and rear
Perrin rear sway bar supports
Perrin heim joint aluminum sway bar end links
Most of the bushings have been replaced with Energy Suspension (met the rep at SEMA several years ago and he made me a hell of a deal on the all I needed-like-less than $100 shipped :))
SSR 18x8x45 Comps with Federal SS595 225/40-18
BRAKES
Stock LGT calipers all around with Ti shims
Custom made front brake vents (by me) that route air directly to the center of the rotor so it cools the FWB and the rotor at the same time from the inside out
Stoptech pads (just removed the Hawk HPS-sick of dust and squeal)
Centric Cryo rotors-flat blanks-all 4
Goodrich stainless brake hoses
Wilwood EXP 600 Plus brake fluid
Grimmspeed master cylinder brace (bought it 3 years ago and never installed it-never needed it)
INTERIOR
Not much here. MOMO pedals to match the wheel and shift knob
Installed the OE Sub under DS
Forgot to add-Block8Head dual vent gauge pod with AEM OP and AFR gauges and cubby pod with Glowshift Boost and Transmission Temp gauges
And...after all...it is Munnday, is it not? :lol:
Car: 2005 SWPLGTU
Mods: AVO 15 lb WGA, AEM cai, Perrin TMIC, STI UP, Strumong divorced upper DP, Perrin lower DP(Single cat for emissions), Cobb heat shield, Modded midpipe, Modded 2.5 Y pipe, Aero Turbine resonators as cans with Pypes dual tips, Prosport Boost gauge in a CasopoliS Cubby pod, 06 LGT tan leather interior minus deck lid and floor carpet, Tint, Factory wheels painted black, Calipers painted red, Hawk HP brakes, Hayden tranny cooler, Cobb Front Sway, Jazzy mod, YourLEDshop white puddles, map, dome(red), trunk, and plate set, shaved trunk, TheGrilleGuy Stiletto Black insert, Remote start.
Location: Northern Ohio F4's meets or Southern New Jersey near Ft Dix depending on what time of the month it is.
Updated version:
My mod list when it last ran:
*OEM VF46 Turbo
*OEM STi UP
*Stromung Divorced Waste gate shorty front DP + PERIN catted rear DP
*PERRIN TMIC
*GFB GT BOV 50/50
*Cobb Front Sway
*Blitz Air box Grille replacing front half of OEM Air Box
*Mid Pipe Resonator Deleted for 2 bullet style resonators
*2 Aero Turbines used as rear cans
*Custom Angle Cut Pypes Quad Tips
*Kumho Ecsta AST
*2005 Legacy GT Wheels Painted Gloss Black
*2006 Legacy GT Limited Tan Interior Swap
*35% Tint
*Prosport Boost gauge in a CasopoliS Cubby pod
*Jazzy Aux
*TheGrilleGuy Stiletto Black insert
*Black Rally Armor UR flaps W/ white lettering
*YourLEDshop White Puddle, Trunk, License Plate, and Map LEDs and Red Dome LED
*No Name generic 15 Inch Sub in generic build a box and unknown amp(will look and see)
*Shaved trunk badges
*Tune was opensourced by Dynamic Power Solutions in Gaithersburg, Maryland
What I have currently acquired since then for the rebuild is:
*OEM 2008 EJ257 Short Block E25C 704 with BBBB pistons
*OEM VF 52 JmP 11 Blade Billet rebuild
*OEM Engine Gasket Set (2005)
*OEM 05 LL Bean Wood MOMO Wheel
*OEM Timing Belt
*OEM Head Bolts
*OEM 10MM Oil Pump
*OEM Closed Impeller Water Pump
*OEM Oil Cooler
*OEM Oil Control Valves X's 2
*OEM STi I/C sprayer tank
*TIC FU Cam Bolts
*LIC Aluminum Half Moons
*GrimSpeed 3" Down pipe to Factory Cat-Back Exhaust Adapter
*Infamous Performance & Tuning Filtered Turbo Oil Supply Line Kit V2
*AVO Induction Silicone Turbo Inlet
*Mishimoto Radiator Hoses
*Venair 5 Piece Ancillary Silicone Hose Set - Vacuum
*Venair 6 Piece Ancillary Silicone Hose Set - Cooling
*Venair BPV Return Silicone Hose
*Tein Springs
*Mevotech LCA
*Turkeylord Blue Tee replacement
*Lamin-X tinted Tail Light Overlays
http://i90.photobucket.com/albums/k280/merc6/LGT/3528db78-820d-40ef-9ba5-fb47b12fc00f_zps5bi1cbux.jpg~original
http://i90.photobucket.com/albums/k280/merc6/LGT/39F54F8C-AFA3-4A07-8125-FB0880BAF382_zpsvze5ypei.jpg~original
car: '08 Legacy GT spec.B
Mods:
Engine
Prova Intake Ram Air Guide Phase 1 (Very Rare & Discontinued Part)
Zero/Sports 1.3K Radiator/Overflow Caps (Blue)
Beatrush Radiator Cooling Panel
Torque Solution Radiator Stay Bracket (Black Anodized)
IAG performance Custom Dip Stick (Black Anodized)
IAG performance Custom Power Steering Cover (Black Anodized)
IAG performance Custom Windshield Washer Fluid Cover (Black Anodized)
AVO Top Mount Intercooler
AVO Blow Off Valve (Black Anodized)
AVO throttle body hose (Black)
COBB Tuning SF Intake and Airbox (Black)
COBB Post MAF Intake Hose (Black)
COBB Tuning Turbo Heatshield
Redline Hood Struts (Aluminum)
Zero/Sports Cool Action II (TMIC Splitter)
Subaru JDM Legacy Black Engine Component Covers (Battery / ABS )
RTG Engineering Custom Battery Tiedown (Stainless Steel "spec.B")
Grimmspeed Boost Solenoid
Grimmspeed Air Oil Separator
BNR Turbo Stage 2+ (VF40-18G/TD05H)
Infamous Performance & Tuning Filtered Turbo Oil Supply Line Kit (Version 1)
AVO Turbo Back Exhaust (3' Stainless Steel with Hi-Flow Cat)
Deatschwerks Fuel Injectors Top Feed 750cc
Deatschwerks 300lph Fuel Pump w/ Install Kit Universal
Kartboy 12MM Black Exhaust Hanger
COBB Tuning Accessport V3 (Silver Face)
Drivetrain
Mishimoto Oil Drain Plug M20x1.5 Subaru (Magnetic)
IAG performance Custom Master Clutch Cylinder Reservoir Cover (Black Anodized)
COBB Tuning Front Shifter Bushing (6MT)
COBB Tuning Rear Shifter Bushing (6MT)
Suspension
Bilstein Struts
H & R Lowering Springs
STI Flexible Lower Arm Bar (Stainless Steel & Adjustable)
STI JDM Front Strut Tower Brace
RalliTEK front sway bar
AVO Rear Sway Bar w/HD Brackets
Cusco Rear Strut Tower Bar Type OS
AVO Rear Underbody Braces
Kartboy Front and Rear Endlink Combo
Brakes
IAG performance Custom Master Cylinder Cover (Black Anodized)
Grimmspeed Master Cylinder Brace
Prova Master Cylinder Reservoir (Orange Sweat Band)
StopTech BBK Front 4 Piston Caliper (Black)
StopTech Slotted 2 Piece 332 x 32mm Rotor (Front)
StopTech Street Performance Brake Pads Front
StopTech Slotted 2 Piece 328 x 28mm Rotor (Rear)
StopTech BBK Rear 2 Piston Caliper (Black)
StopTech Street Performance Rear Brake Pads
Techna-Fit Stainless Steel Brakelines (Red Teflon Covered)
Exterior
STI JDM Black "STI" Grill Emblem (w/Black S401(STI)Emblem Customized for Grill)
RBS by Rommel, Grill Surround (Painted QSM) w/1" Red Pinstripe
GrillCraft Front Upper Grill Black
K2 Gear Wet Carbon Subaru Emblem (Grill & Trunk)
GrillCraft Front Lower Grill Black
Bayson R Front Lip
STI JDM V Limited Front Lip Spoiler Rubber Underskirt
STI Front Lip STI Badge
STI JDM Pin Stripe (Dark Gray Stripe w/Dark Cherry STI Logo)
Prova Blue Wide-View Door Mirrors
Subaru OEM LGT JDM Rain Visor
Subaru OEM mud flaps
No Brand Rear Window Roof Spoiler
Lamin-X Tail Light Tint (Smoke)
K2 Gear Trunk Spoiler (Painted QSM)
STI JDM Black "tuned by STI" Rear Emblem (w/Black S401(STI)Emblem)
TRF Custom Legacy Rear Diffuser
3m 35% Window Tint (All Around)
Griots Garage License Plate Frame (Matte Black 4 Hole w/Smoked Cover, Front & Rear)
Interior
DAMD D Shaped Steering Wheel (Black Leather & Black Stitch)
Liberal Navigation Sun Visor
Prova SI-Drive Dial (Black Anodized, Rare & Discontinued Part)
STI JDM Style Leather Shift Knob w/ Cherry Red Pattern 6MT
Subaru OEM Short Throw Shifter STI 6MT
Escort Passport 9500IX Radar Detector (Red Display & Hardwired)
Subaru JDM Dual Console Box (Black Center Console Extension)
Subaru OEM Carpeted Floor Mat Set Black (Spec-B mats w/gray Edges)
Subaru JDM STI Side Sill Door Plate Set
IAG performance Driver Floor Mat Holder Bracket (Black Anodized)
Subaru "Franklin" the Subaru Dog (Tan & Rides in the Back Seat)
Subaru 08 JDM Legacy Carpeted Non Slip Trunk Mat
Weather Tech Front/Rear Molded All Weather Floor Mats (Black)
Wheels/Tires
Summer SetUp
O.Z.Racing Leggera HLT, British Racing Gray (18x8+48)
Hankook Ventus S1 noble2 XL Tires (235/40ZR-18)
Muteki Lug Nuts Close End (Black)
Winter Set Up
O.Z.Racing Ultraleggera, Matte Graphite Silver (18x8+48)
Dunlop SP Sport 3D XL Winter Tires (235/40R-18)
Electrical and Lighting
Subaru OEM Fog Lights (JDM Ion Plasma "Multicoat" )
Hella Supertone Horn Kit Pair (Silver w/ Subimods Bracket & Wiring Harness)
Audio/Video/Security
BlendMount Radar Detector Rearview Mirror Mount (Matte Black)
Tom Tom Navigation System (Matte Black)
“Wisdom Is Your Reward for Surviving Your Own Stupidity!”
Present: 2008 Spec.B QSM and 2019 Ascent Limited CWP
Past: '04 WRX Wagon; '98,'02,'05,'11 Outback's
car: 2005 Obsidian Black Pearl LGT Limited 5 spd
Mods:
Borla Exhaust
JDM Double Din Kit w/Pioneer Appradio 4
07 WRX rims painted metallic black
Agency Power STS
Perrin Rear Sway Bar
OEM STI 5 speed shift knob
Cusco Front Strut Tower Brace
6000k HID's
http://i1370.photobucket.com/albums/ag250/redx721/7E575B7B-5259-4397-858E-458EB4E08EBC_zpsqiwrswcq.jpg
I am completely jealous of all of you with the perfect front bumpers and hoods. How do you avoid stone chips and road wear? My car has 93K on it and the front is truly not in very good shape. I see your photos up close and your bumper covers and front edges look great.
YOU BASTARDS ! !
Ooops...did I say that out loud?:redface: Sorry. :lol:
car: 05 LGT limited Wagon 5 MT
location: Bay Area most of the year. Somewhere on the ocean during the summer and a couple months of the year in the PNW.
Mods:
Engine:
Grimmspeed Light Weight Crank Pulley anodized blue
Competition Clutch Stage 2 clutch with Single Mass Light Weight Flywheel
Catless up pipe
Catless down pipe
Borla resonated catback
PTP Turboblanket blue
Cobb Heatshield
BMB TMIC bulletproof kit
Cryotune stage 2
Grimmspeed Intake waiting to go on.
Suspension & Wheels & Brakes:
ISC N1 Coilovers
Whiteline 20mm rear sway bar w/polybushings and side locks
Whiteline 24mm front sway bar w/ polybushings and side locks
AVO Rear Sway Bar Brackets
Whiteline KCA313 Roll center/bump steer kit
Rota Gravel wheels 18x8.5 et44 w/Goodyear eagle F1 235/40
Hawk HPS pads
Centric slotted rotors
Exterior:
Hella Horns sanded down and painted blue.
DIY mesh grille
6000k HID low beams & Fogs w/35w ballast
Cleared and blacked out headlights
JDM taillights
MachV wagon wing
JDM spats front and rear
15% tint on rear windows
25% tint on front windows
5% tint on sunroof
Interior:
Momo shift knob
Weathertech floor mats
08 Headunit
08 factory underseat sub
AVO double din waitint to be installed when I find a good radio I like
2005 Vader Wagon
Material Tests on Ringland Failure Piston
I should have held off and purchased a wagon instead of the spec.B
YOU BASTARDS ! !
I know that feel. My front needs TLC to the point I contemplated JDM front swap instead of just painting the bumper and hood to call it a day.
I also updated my post to the 2015 version everyone is doing now.
YOU BASTARDS ! !
I know the feeling. The pictures that I've posted of my lgt make my front bumper and hood look very nice. In reality, they need some tlc :(. Although I'm almost 160k (currently at 159.7k), I've been considering getting the hood and bumper redone, however, I don't really want to spend the money at the moment lol :spin::p
Car: 2009 Subaru Legacy Spec.B (QSM)
Mods: stock (for now)
Sent from my HTC6500LVW using Tapatalk
Wow! How did you afford such a car at such a young age!
2005 Vader Wagon
a dealership in my area posted it for sale not knowing how special it was. so i jumped on the occasion. i was planning on getting an 2012 impreza hatch (5spd), but one day on cars.com a spec.b popped up (it was my dream first car). it was a stretch to afford it, but in the end it was worth it. My family helped me get the money for it and i can slowly pay them back. I've only had the car for 6 days and i'm absolutely in love. I sometimes feel guilty that its a pretty sweet ride for a 17 year old, but im glad that i had the opportunity.
here's a link a photo: For legacygt forum
on a side note: @magnusonsubie, your wagon is absolutely gorgeous
Man that's awesome! I picked my wagon up for a steal of a deal too but I got it when I was 19. Drive safe and keep it looking good!
Thanks for the kind words about my wagon! I appreciate it!
2005 Vader Wagon
thank you! I'll be safe don't worry.
Congrats! Do yourself a favor and read up on what not to do to these cars if you haven't already.
