f1anatic Posted April 26, 2010 Share Posted April 26, 2010 I know a friend of a friend who is not on the boards and asked me to inquire here He is considering changing his VF-40 to a VF-52. He is currently pro-tuned Stage 2. What can he do to be able to drive his car - for a few days - before he gets it pro-tuned with the new turbo ? Staying out of boost makes sense but can he physically do anything to prevent that ? Driving a different car is not an option nor can things be arranged in such manner that he can get a pro-tune the same day as the turbo replacement and/or at the same location. Thanks. Link to comment Share on other sites More sharing options...
spartan Posted April 26, 2010 Share Posted April 26, 2010 I would assume that he could run boost right off the wastegate, limiting him to 8-12 psi? Link to comment Share on other sites More sharing options...
Metal2You Posted April 26, 2010 Share Posted April 26, 2010 Does he have an AccessPort, or is it open source tuned? Cobb has AP maps that prevent boost. Valet maps I believe. Link to comment Share on other sites More sharing options...
rao Posted April 26, 2010 Share Posted April 26, 2010 Disconnect the boost control solenoid plug - that will prevent him from going over wastegate boost pressure and throw a CEL. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
fishbone Posted April 26, 2010 Share Posted April 26, 2010 Does he have an AccessPort, or is it open source tuned? Cobb has AP maps that prevent boost. Valet maps I believe. Valet maps also have a rev limiter set to 3K rpms I think. Link to comment Share on other sites More sharing options...
Th3Franz Posted April 26, 2010 Share Posted April 26, 2010 The car will probably go lean, even at only wastegate pressure. I mean, I've seen STI's that swapped TGV-deletes and a ported stock intake manifold, and at cruise just barely dipping into open loop the AFR's wanted to go past 16 before he retuned it. A bigger turbo and driving with an untuned MAF scaling is probably more extreme. -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
f1anatic Posted April 27, 2010 Author Share Posted April 27, 2010 Disconnect the boost control solenoid plug - that will prevent him from going over wastegate boost pressure and throw a CEL. Thanks guys. Where is this boost solenoid ? Link to comment Share on other sites More sharing options...
rao Posted April 27, 2010 Share Posted April 27, 2010 Under the hood It is next to the map sensor, which is located just inboard of the turbo inlet as it goes from the MAF sensor under the intake manifold. You can't get to it easily unless you remove the engine cover. It should take about 5 seconds to remove the plug once the engine cover is off. BTW, I would not recommend trying to see how fast the car is at wastegate pressure, but it will make it as safe as you can until the car is tuned. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
NSFW Posted April 29, 2010 Share Posted April 29, 2010 It's a little gray box, about the size of a pack of matches, with two hoses and two wires going into it. One hose goes to the intake manifold, the other goes to a T fitting between the compressor nipple and the wastegate actuator. Link to comment Share on other sites More sharing options...
f1anatic Posted April 29, 2010 Author Share Posted April 29, 2010 thanks guys. Link to comment Share on other sites More sharing options...
