mustangendsley Posted June 2, 2010 Share Posted June 2, 2010 how do the stock clamps work for a 25mm fsb? the bushing is so much bigger than stock 21mm. Link to comment Share on other sites More sharing options...
amp27 Posted June 8, 2010 Share Posted June 8, 2010 i think you have to trim the bushings. gosh learning about full acale cars takes way longer then my little 1/10 scale RC. traxxas stampede Link to comment Share on other sites More sharing options...
Zues Marine Posted June 15, 2010 Author Share Posted June 15, 2010 the bigger bushings fit fine in the stock clamps, if you use the stock bushings, drill the hole larger.. easy Link to comment Share on other sites More sharing options...
Baddog Posted June 18, 2010 Share Posted June 18, 2010 How would a sedan handle with a 25mm FSB? I have the outback 18mm on the rear currently. Link to comment Share on other sites More sharing options...
Zues Marine Posted June 18, 2010 Author Share Posted June 18, 2010 i wouldnt reccomend it without upgrading to a bigger rear as well.. or else youll come out with some insane oversteer Link to comment Share on other sites More sharing options...
Baddog Posted June 18, 2010 Share Posted June 18, 2010 Yeah that's what I was afraid of. I just upgraded to the 18mm rear. It's a decent amount stiffer not as stiff as I thought it would be though. Link to comment Share on other sites More sharing options...
mustangendsley Posted June 22, 2010 Share Posted June 22, 2010 Got everything fixed on the front now and the MSI endlinks fit great. I have the front 25mm bar on soft and Im going to put the rear 25mm on firm. I like the feel of the front dropping and biting and then turn in on the track. Link to comment Share on other sites More sharing options...
subikid90 Posted June 27, 2010 Share Posted June 27, 2010 Will stock FSB and RSB from a 03 WRX wagon fit? I found both for $15! -Subikid90Â 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
fwa2500 Posted June 28, 2010 Share Posted June 28, 2010 you will have to remove the lump under the spare tyre well on you car for there to be enough clearance, but they should work Link to comment Share on other sites More sharing options...
SteveB Posted July 17, 2010 Share Posted July 17, 2010 Ok.... I have a question on the swaybar for my 95 legacy. I noticed a few weeks back that mine has broke. It appears that it became so twisted from my off-road driving abuse that it snapped. The break is to the left of the right side anti-sway bushing. My question-- can I weld it for a short term repair? I'm not in the position that I can afford to buy a replacement right now, and welding was a thought that I was curious about. Thank you. Link to comment Share on other sites More sharing options...
subikid90 Posted July 17, 2010 Share Posted July 17, 2010 I bet you could find a used one for $10-15 around here, craigslist or a junk yard. They are pretty inexpensive to replace used. Sway bars see a lot of force and I think welding would only last a short time. Especially since you go off roading. -Subikid90Â 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
fwa2500 Posted July 29, 2010 Share Posted July 29, 2010 i should have posted this in here before, removed the lump and hammered in the spare tyre well as needed to clear my 22mm whiteline adjustable rsb http://img704.imageshack.us/img704/5323/34866458483401507563736.jpg Link to comment Share on other sites More sharing options...
gershon Posted July 29, 2010 Share Posted July 29, 2010 So I have a 2005 Outback that has a 15mm rear swaybar and it handles like crap. Anyone know if 15 is stock? I bought the car as a rebuilt title and have found mix matched parts on it. Link to comment Share on other sites More sharing options...
gershon Posted July 29, 2010 Share Posted July 29, 2010 So I have a 2005 Outback that has a 15mm rear swaybar and it handles like crap. Anyone know if 15 is stock? I bought the car as a rebuilt title and have found mix matched parts on it. OK so I found that 15 is stock but boy does my car bounce around in the back. Anyone put a Whiteline 20mm on the rear of a OB and like the handling difference? Link to comment Share on other sites More sharing options...
Zues Marine Posted July 30, 2010 Author Share Posted July 30, 2010 ^ i dont think anyone can complain about a beefier swaybar on any car, ha Link to comment Share on other sites More sharing options...
gershon Posted July 30, 2010 Share Posted July 30, 2010 I guess more of what I am wondering is do other people with OB 2005's have so much sway in back it scary? Link to comment Share on other sites More sharing options...
bmwpride Posted September 5, 2010 Share Posted September 5, 2010 Will an 02 wrx sedan rsb fit a 97 lego gt? Link to comment Share on other sites More sharing options...
fwa2500 Posted September 5, 2010 Share Posted September 5, 2010 it will, but it will also require some work. my whiteline bar is for an 02-03 wrx sedan, scroll up a bit to see what i had to do to make it fit  gershon, my stock rear sway was 15mm too and i had a good bit of motion going on back there but i can imagine yours is worse since your 06 weighs a good bit more. you will notice a big difference if you go to a 20 or 22mm bar Link to comment Share on other sites More sharing options...
bmwpride Posted September 5, 2010 Share Posted September 5, 2010 so all that needs to be done, is cut that hump off and make it fit. Now sway bushing should i get to upgrade from the stock ones? Link to comment Share on other sites More sharing options...
fwa2500 Posted September 5, 2010 Share Posted September 5, 2010 cut off the hump and hammer in the spare tyre well a bit so it clears the bar. if you get a whiteline bar it should come with the bushings, im not sure about the other brands though. Link to comment Share on other sites More sharing options...
bmwpride Posted September 8, 2010 Share Posted September 8, 2010 im just using a stock wrx bar. So what replacement bushing should i use Link to comment Share on other sites More sharing options...
fwa2500 Posted September 8, 2010 Share Posted September 8, 2010 if you can find whiteline bushings, get those, they will be better than the stock ones. you will be wanting ones for an 02/03 wrx because the 04+ have a slightly different bushing design Link to comment Share on other sites More sharing options...
bmwpride Posted September 9, 2010 Share Posted September 9, 2010 ok thank you Link to comment Share on other sites More sharing options...
TbirdMan Posted November 3, 2010 Share Posted November 3, 2010 Ok, so an OB RSB should be an upgrade for my GT, how about the front? anything OEM that is less extreme than the 25mm tribecca unit? Link to comment Share on other sites More sharing options...
Zues Marine Posted November 3, 2010 Author Share Posted November 3, 2010 96-99 impreza 2.5L are 20mm Link to comment Share on other sites More sharing options...
