jonnyg113 Posted November 23, 2007 Share Posted November 23, 2007 cant this be done without removing the shifter, how hard is it? Link to comment Share on other sites More sharing options...
jah64 Posted November 23, 2007 Author Share Posted November 23, 2007 I suppose you could but be careful with the metal shavings getting everywhere. Taking the shifter out of the car is very simple. Link to comment Share on other sites More sharing options...
JOE_1985 Posted November 23, 2007 Share Posted November 23, 2007 do like i did and buy someones stock shifter and use it hardest part is getting the snap ring out if u dont have snap ring plyers, i just used a flat head and neddle nose plyers (thankgiving day, cant get tools) Link to comment Share on other sites More sharing options...
jah64 Posted November 27, 2007 Author Share Posted November 27, 2007 Just beware that the stock shifter and the sti short throw shifter have different fulcrum points Link to comment Share on other sites More sharing options...
jonnyg113 Posted December 1, 2007 Share Posted December 1, 2007 thanks for the post. The hardest part for me was finding a re-threading die. After a few of the guys on this thread said they found one at their local hardware store, I though I could do the same. No deal Link to comment Share on other sites More sharing options...
JOE_1985 Posted December 1, 2007 Share Posted December 1, 2007 same here, ieven went to major tool places, no dice i oredered a die from the link on the 1st page,its a really good die, i used wd 40 for cutting lube Link to comment Share on other sites More sharing options...
Instanced Posted January 13, 2008 Share Posted January 13, 2008 This is just a thought, but has anyone thought about just cutting a piece out of the middle and just welding it back together? (That way you wouldn't have to rethread it? i think alot of people have better skills with a hacksaw and a die then they do with a welder... using a die is SUPER easy... welding is not... and i'd rather have my shifter head stripped then the whole thing snapping in half because i can't weld worth *HIT! Link to comment Share on other sites More sharing options...
mccorry Posted May 5, 2008 Share Posted May 5, 2008 thanks for the post. The hardest part for me was finding a re-threading die. After a few of the guys on this thread said they found one at their local hardware store, I though I could do the same. No deal Here is where I got mine..... [ame=http://www.amazon.com/12mm-1-25-Carbon-Hex-Die/dp/B0007CNJ0O?tag=dogpile-20]Amazon.com: 12mm x 1.25 Carbon Hex Die: Home Improvement[/ame] Going to look into this mod in the next week or so.... Link to comment Share on other sites More sharing options...
mccorry Posted May 11, 2008 Share Posted May 11, 2008 Just completed this modification yesterday. MUCH MUCH better. I've got an STi STS, btw. Thanks for the idea and the post, OP! Link to comment Share on other sites More sharing options...
phenryiv1 Posted May 15, 2008 Share Posted May 15, 2008 I have had trouble with the shaft below the factory threading. Did anyone else have to grind down the diameter of the shaft to get the die to take a proper bite? Patrick Looking for spacers or adapters to install aftermarket speakers in the doors of your Legacy? CLICK HERE or PM me! http://www.carstereoadapters.com./ Link to comment Share on other sites More sharing options...
mccorry Posted May 15, 2008 Share Posted May 15, 2008 Nope... I had to grind down the "shoulder" on the shaft.. but after that it was fine. Link to comment Share on other sites More sharing options...
phenryiv1 Posted May 15, 2008 Share Posted May 15, 2008 Hmmm, that is odd...even with cutting fluid, my attempts to add threads were a giant FAIL, as the diameter of the shaft seemed to expand just below the original threading. They seem to be wider than the "teeth" of the threading by nearly a millimeter. Patrick Looking for spacers or adapters to install aftermarket speakers in the doors of your Legacy? CLICK HERE or PM me! http://www.carstereoadapters.com./ Link to comment Share on other sites More sharing options...
mccorry Posted May 15, 2008 Share Posted May 15, 2008 Do you have the correct die? It should be an M12x1.25. Link to comment Share on other sites More sharing options...
JOE_1985 Posted May 15, 2008 Share Posted May 15, 2008 post pics theres a fat part of the shaft i ground down Link to comment Share on other sites More sharing options...
phenryiv1 Posted May 16, 2008 Share Posted May 16, 2008 Do you have the correct die? It should be an M12x1.25. Yes- the threading perfectly matches the stock threading. It just looks like the shaft below the threading is too wide. I'll snap some pics tonight. Patrick Looking for spacers or adapters to install aftermarket speakers in the doors of your Legacy? CLICK HERE or PM me! http://www.carstereoadapters.com./ Link to comment Share on other sites More sharing options...
mccorry Posted May 16, 2008 Share Posted May 16, 2008 Yes... please do. My die slightly cut / cleaned the stock threads then cut perfect new threads from there down. No issues whatsoever. Link to comment Share on other sites More sharing options...
MarkV Posted May 22, 2008 Share Posted May 22, 2008 you think they'd have a rethreading die at a place like true value?, or get lucky at the town harware store? I've Crashed My ROFLChopper into a LOLCanOhttp://legacygt.com/forums/image.php?type=sigpic&userid=16939&dateline=1230531251 Link to comment Share on other sites More sharing options...
MarkV Posted May 22, 2008 Share Posted May 22, 2008 so yea i got lucky with finding the die at my local hardware store and finished the mod, it was absolutley awesome!! feels amazing too, the shifts feel sooooooo good thanks for the awesome walk through I've Crashed My ROFLChopper into a LOLCanOhttp://legacygt.com/forums/image.php?type=sigpic&userid=16939&dateline=1230531251 Link to comment Share on other sites More sharing options...
patrack92314 Posted August 16, 2008 Share Posted August 16, 2008 i did this mod yesterday in my 99 legacy gt it had a metal ring type thing to stop the shifter from going down . so i took a dremal with a cut off wheel and cut around the ring but not through the shaft then i took a dy and made new threads all the way down and then figured out where i wanted it and cut it off .i left mine in the car and just covered the stuff around with a towel . came out very nice. i am very happy with it Link to comment Share on other sites More sharing options...
djkxgo0k Posted August 21, 2008 Share Posted August 21, 2008 anybody have a stock shift rod for sale? =] Link to comment Share on other sites More sharing options...
08specbsubie Posted December 11, 2008 Share Posted December 11, 2008 would this work on my '08 Spec B ? looks great by the way Link to comment Share on other sites More sharing options...
cmason100 Posted February 12, 2009 Share Posted February 12, 2009 do you think you could do this without taking the shifter out of the car? in place with a grinder and a cut off wheel? just wondering. Link to comment Share on other sites More sharing options...
mccorry Posted February 12, 2009 Share Posted February 12, 2009 I wouldn't recommend it. The metal shavings would fall into the pivot and cause issues. It's really easy to get the shifter arm out. Link to comment Share on other sites More sharing options...
strykr Posted March 25, 2009 Share Posted March 25, 2009 anybody know a way to do this without rethreading? Like cutting off the threaded area and trimming down the rod, then reattaching the threaded area? Or any other way? Link to comment Share on other sites More sharing options...
mccorry Posted March 25, 2009 Share Posted March 25, 2009 Nope... you'll need to cut new threads. Send it to me and I'll do it for ya. Link to comment Share on other sites More sharing options...
