fatbastard Posted July 18, 2006 Share Posted July 18, 2006 OC NY or CA? Link to comment Share on other sites More sharing options...
nike923 Posted July 18, 2006 Share Posted July 18, 2006 Ca Link to comment Share on other sites More sharing options...
mccorry Posted September 19, 2006 Share Posted September 19, 2006 subscribe.... Link to comment Share on other sites More sharing options...
ianfools Posted October 17, 2006 Share Posted October 17, 2006 I cut mine aswell with the STI short shifter from facxtory and i love it its way nicer ....and on CRAZY KENS questions of... What is the maximum length you can cut off before you might have problems/discomfort??? I am sure you will geuss the make of car before i say it but I have a friend who cut his off so you literally have to reach down into the shift boot... yes thats about 4 inches and yes it was a HONDA... SUBIE ALL THE WAY!!!!! Link to comment Share on other sites More sharing options...
undert0e Posted November 1, 2006 Share Posted November 1, 2006 Just completed the install on my 2006 OB and seems to be functioning fine. If I start to have any problems I will go and buy the STS kit. But for nothing its not a bad mod. Took about three hours to complete. Link to comment Share on other sites More sharing options...
vet Posted November 3, 2006 Share Posted November 3, 2006 Modifying the lever arm without modifying the shifting mechanism is slightly less than brilliant. There is a reason STSs aren't just chopped stock units. Well I was planning to do this mod this weekend, now I'm having second thoughts. Is there anyone who's done this who regrets it? Can anyone compare this mod to a real STS in terms of feel? Link to comment Share on other sites More sharing options...
undert0e Posted November 5, 2006 Share Posted November 5, 2006 No regrets here. Gives the car a much better feel. Link to comment Share on other sites More sharing options...
shtbxr22 Posted November 20, 2006 Share Posted November 20, 2006 i can make a better one;)!!! Link to comment Share on other sites More sharing options...
vet Posted November 21, 2006 Share Posted November 21, 2006 i can make a better one;)!!! Care to enlighten us? Link to comment Share on other sites More sharing options...
shtbxr22 Posted November 21, 2006 Share Posted November 21, 2006 What I do is take the shifter out, remove the ball @ the bottom, pull the bushings out, and I take away material, below the flange @ the top, and below the pivot point I add the same amount taken out of the top to the lower portion, or add whatever to the bottom, and take more out of the top if the "customer" wants a lower shift knob height. After that, you need to take the base plate out, and notch it w/ a cut-off wheel. Make the opening so it is an open rectangle, to clear the shift rod, and that would be your custom STS. I make them, so if anyone wants, I have three stock ones standing by.......make an offer Link to comment Share on other sites More sharing options...
undert0e Posted November 22, 2006 Share Posted November 22, 2006 Im kinda confused, how is this thing going to stay in place if you remove the knob? Link to comment Share on other sites More sharing options...
shtbxr22 Posted November 22, 2006 Share Posted November 22, 2006 I weld it back together Link to comment Share on other sites More sharing options...
undert0e Posted November 23, 2006 Share Posted November 23, 2006 Ahh i see Link to comment Share on other sites More sharing options...
vet Posted November 27, 2006 Share Posted November 27, 2006 Be careful when extending the threads with the die. The new threads I cut are really crappy looking. I didn't get the new threads down quite as far as I could have cuz the die started to slip on me and I was close to stripping it. I like the feel of the shorter shifter. Link to comment Share on other sites More sharing options...
johnAWD Posted November 27, 2006 Share Posted November 27, 2006 I think I should try this with my factory installed sti sts. Link to comment Share on other sites More sharing options...
undert0e Posted November 28, 2006 Share Posted November 28, 2006 I miked the shifter before I started threading it and made sure that I was just a hair smaller in the area that I was going to be threading due to the fact that the metal looked pretty porus. Link to comment Share on other sites More sharing options...
shtbxr22 Posted November 28, 2006 Share Posted November 28, 2006 The way I do it, you don't need to make new threads. Link to comment Share on other sites More sharing options...
hutru01 Posted December 20, 2006 Share Posted December 20, 2006 This is just a thought, but has anyone thought about just cutting a piece out of the middle and just welding it back together? (That way you wouldn't have to rethread it? Link to comment Share on other sites More sharing options...
shtbxr22 Posted December 21, 2006 Share Posted December 21, 2006 that would screw up the rubber damper Link to comment Share on other sites More sharing options...
hutru01 Posted December 21, 2006 Share Posted December 21, 2006 that would screw up the rubber damper Where is the rubber damper located? Link to comment Share on other sites More sharing options...
shtbxr22 Posted December 22, 2006 Share Posted December 22, 2006 inside the shift stem above the pivot point Link to comment Share on other sites More sharing options...
hutru01 Posted December 22, 2006 Share Posted December 22, 2006 inside the shift stem above the pivot point Oh, that I did not realize. I thought it was metal throughout. Hmmm, learn something new everyday. Link to comment Share on other sites More sharing options...
Ari_OutbackWagon Posted August 17, 2007 Share Posted August 17, 2007 I remember a thread a while back where someone cut and legthened the shaft below the pivot with a galvanized pipe. I can't find the thread:confused: Link to comment Share on other sites More sharing options...
jonnyg113 Posted November 14, 2007 Share Posted November 14, 2007 shbxr22, are you really trying to make money on this mod? People come hear to learn how to do it themselves. ... in my honest opinion. Link to comment Share on other sites More sharing options...
JOE_1985 Posted November 21, 2007 Share Posted November 21, 2007 just did this, im in my other car right now cause im waiting on brakes for my lgt and ive missplaced my cobb bushings, im eager to see how much better this is over stock, i plan to do the shifter, bushings, and the subaru s gear oil or something similar at the same time. some will say get a professional sts, but me saving 60-100 on this shifter(stock shifter $25, die $19, and lube $2.00 ,had other tools already), just pad for my brake pads and extra towards my rotors i just ordered. I feel brakes on the lgt is more important because stock sucks. Link to comment Share on other sites More sharing options...
