ClimberDHexMods Posted June 18, 2010 Share Posted June 18, 2010 Down force I agree with, but I would think reducing the amount of air going under your chassis would be better to cut thru the air at higher speeds. (55plus) I'm no expert, so I'm going to use very basic logic to explain this: All the air needs to go somewhere. Air can go one of 5 ways. Above, below, left, right, and through (for cooling, which ends up going down). A lip should send more air above and through than below vs before the lip. Does this in turn push the nose of the car down a little? It should help a little bit. BUT does it help the car "cut through the air better?" My thought is no, because "cut better" means less resistance (my inference) and this lip adds more resistance. It should LOWER the invisible foggy line at which air is split above and below the vehicle (a very small amount) if that is what you mean. FWIW this lip is basically just a tiny, flexible air splitter. I mention that because there is a lot of good reading on setting up and using air splitters (if you care that much). They are the useful versions of a lip, and I kind of want for no reason http://www.speedzonemotorsports.com/images/P/STI_front-side.jpg [CENTER][B][I] Front Limited Slip Racing Differentials for the 5EAT now available for $1895 shipped, please inquire for details! [/I][/B][/CENTER] Link to comment Share on other sites More sharing options...
SATSFYD Posted June 18, 2010 Share Posted June 18, 2010 I ask these questions because I read too much and have too much faith in the net... see this web site: http://www.recumbents.com/car_aerodynamics/ **There are two types of people in the world, those who build horsepower and those who buy it. Which one are you? Link to comment Share on other sites More sharing options...
DukeTrout Posted June 18, 2010 Share Posted June 18, 2010 Eh, I'm not sure how much weight I'd put into that article. Fluid dynamics are tricky, especially with a shape like a car that is complex and operates at a wide variety of speeds. For example, a lot of people remove the tailgates on pickups in order to improve the aerodynamics, but it actually accomplishes the opposite. There is a cushion of air that forms when the tailgate is there that helps with the form drag. Remove the tailgate and it actually forms a bigger, drag-increasing vortex. Lips could increase or decrease drag. It's too difficult to predict how they will affect things. I would count only on the aesthetic value of a lip, not on any downforce or improvements in airflow. Ich bin echt viel netter, wenn ich nuechtern bin. Echt! Link to comment Share on other sites More sharing options...
speddmn Posted June 27, 2010 Share Posted June 27, 2010 Just slapped mine on...no trimming http://www.flickr.com/photos/51500842@N02/4737212743 http://farm5.static.flickr.com/4077/4737212743_d5ffd49749.jpg Link to comment Share on other sites More sharing options...
thestratomaster Posted June 27, 2010 Share Posted June 27, 2010 ^^ Which one did you buy that you didn't have to trim anything? Link to comment Share on other sites More sharing options...
Meshanks07 Posted June 27, 2010 Share Posted June 27, 2010 I installed mine today. Will post up pics tonight or tomorrow. Link to comment Share on other sites More sharing options...
speddmn Posted June 28, 2010 Share Posted June 28, 2010 Strato, here's the link to the one I bought http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=370392706623 Link to comment Share on other sites More sharing options...
thestratomaster Posted June 28, 2010 Share Posted June 28, 2010 ^^ cool thanks Link to comment Share on other sites More sharing options...
SATSFYD Posted June 28, 2010 Share Posted June 28, 2010 Booo... my work has ebay blocked... booo! **There are two types of people in the world, those who build horsepower and those who buy it. Which one are you? Link to comment Share on other sites More sharing options...
Meshanks07 Posted June 29, 2010 Share Posted June 29, 2010 Some pics from my blackberry Link to comment Share on other sites More sharing options...
tobey457 Posted June 29, 2010 Share Posted June 29, 2010 Looks good, care to share your install notes? Do you have a little twisting in the middle section, or is that just shadowing from the pic? My lip almost seems too wide to fit the bumper (I have the same style lip and an 08 too), so I'm guessing I'm going to have to get creative. Link to comment Share on other sites More sharing options...
Meshanks07 Posted June 29, 2010 Share Posted June 29, 2010 Thanks. The only trimming I did was to the middle piece to fit the curves of the bumper. As for the middle section, it is the light however it is a little pushed down. Haven't had time to try and fix but not too worried b/c it looks good. Link to comment Share on other sites More sharing options...
tobey457 Posted June 30, 2010 Share Posted June 30, 2010 Thanks for the reply. The reason I ask (about the middle section) is like I mentioned, my lip seems about 2-3" wider than my bumper. My thought process was to clamp both ends of the lip (near the wheel well) but I think in doing this, the middle would buckle out slightly, which is where a heat gun might come in handy. The lip just doesn't have a backbone... it's very flexible, which can be a blessing and a curse. It seems any slight fitment issue could stick out like a sore thumb, so I'm trying to do all of my homework. I may try to get mine on over the long weekend. Link to comment Share on other sites More sharing options...
legacychick Posted June 30, 2010 Share Posted June 30, 2010 They way I installed mine was by putting a screw in the middle to hold it up, then having someone hold it in place while I put in the other screws. It seems like it's too wide until you get it started. Link to comment Share on other sites More sharing options...
Meshanks07 Posted June 30, 2010 Share Posted June 30, 2010 If I get a chance over the weekend I'll use my heat gun and see if that will help. Like I said it's not too bad. I plan on heating it up and basically holding it into place until it cools down. Hopefully that will work. Link to comment Share on other sites More sharing options...
Woodstock Posted June 30, 2010 Share Posted June 30, 2010 I used adjustable pliers to hold down things as I screw the lip to the bumper. Link to comment Share on other sites More sharing options...
speddmn Posted June 30, 2010 Share Posted June 30, 2010 FYI if you let it step out just an 8th of an inch or maybe even a bit less so on either side fitment is much easier. It's finished enough to do so and look like it belongs Less bowing Less need to trim (IMO) Link to comment Share on other sites More sharing options...
speddmn Posted June 30, 2010 Share Posted June 30, 2010 You can see the step out i'm talking about in this pic. Also wouldn't recommend starting in the middle and working out as you're going to increase the 'bowing' as you put pressure on the sides... the centermark is going to want to move forward/backwards as you work around. Start at both ends then do the sides (you'll know what i'm talking about once you do it) and work towards the middle... so I did: left corner right corner left back 3 right back 3 left front side right front side and middle last so I could tweak the front edge a bit with everything else secured. http://farm5.static.flickr.com/4138/4740144084_9f23d19724_b.jpg Link to comment Share on other sites More sharing options...
vitaliy_08 Posted June 30, 2010 Share Posted June 30, 2010 ^I agree with speddmm, I was working on this with my brother and he suggested to start at the ends also, and it turned out pretty good. Link to comment Share on other sites More sharing options...
SlowSWP2.5 Posted July 2, 2010 Share Posted July 2, 2010 i have an 07 not sure if this lip will fit or if there is alot of work to make it fit( where to cut if needed). if anyone has a write up would appreciate it. Link to comment Share on other sites More sharing options...
2BJDM Posted July 5, 2010 Share Posted July 5, 2010 I also started at the ends and it turned out perfect. I highly suggest taking a hair blow dryer to the middle section for a couple of mins to soften it up before screwing it in. Link to comment Share on other sites More sharing options...
heferly Posted July 6, 2010 Share Posted July 6, 2010 i have an 07 not sure if this lip will fit or if there is alot of work to make it fit( where to cut if needed). if anyone has a write up would appreciate it. i just got mine (thanks for all the info everyone!)...i have '07, and will try to install next week...i'll let you know what i find! sometimes you eat the bar, and sometimes...well, he eats you Link to comment Share on other sites More sharing options...
speddmn Posted July 7, 2010 Share Posted July 7, 2010 i have an 07 not sure if this lip will fit or if there is alot of work to make it fit( where to cut if needed). if anyone has a write up would appreciate it. unless I'm high there's no material change from 2005 until you hit 2008, correct me if I'm wrong? Link to comment Share on other sites More sharing options...
spartan Posted July 7, 2010 Author Share Posted July 7, 2010 That would be correct, no external difference in the 05-07's. Link to comment Share on other sites More sharing options...
GoRilla Posted July 10, 2010 Share Posted July 10, 2010 Some pics from my blackberry Looks great! Which lip did you buy? Any specific tips for the 08-09? Maryland's Suby friendly Realtor. My favorite suby shop: http://www.IAGPerformance.com Link to comment Share on other sites More sharing options...
