Bolksey85 Posted December 11, 2009 Share Posted December 11, 2009 [ame=http://www.youtube.com/watch?v=YiQ6FcyiPag&feature=player_embedded]YouTube- The Gobstopper - Time Attack -[/ame] ^^^The video. Be prepared to sit back and want to either drive in or get a ride in this monster. Badly. I'm putting a teaser pic in the Exotic/Musclecar thread. Build specs: Gobstopper Specs Body WRC steel arches WRC front and rear bumpers WRC carbon rear spoiler FIA T45 multi point welded in roll cage STi alloy bonnet with RCMS heat extraction vents and gas struts Heated front screen WRC non heated lightweight rear screen Engine 2.0Litre closed deck subaru block RCMS extreme arrow rods RCMS 75mm steel crankshaft RCMS omega flat top pistons (coated) compression ratio 9.5:1 V4 STi cylinder heads with WRC/RCMS O-ring head gaskets and gas rings One piece Nimonic exhaust valves One piece stainless inlet valves RCMS uprated valve springs Plasma nitrided titanium spring caps WRC main and big end bearings WRC R-Profile high wrap cam belt system RCMS modified oil pump to suit R-Profile belt WRC S10 inlet manifold RCMS eight injector kit RCMS 72mm throttle body RCMS 5.5 litre alloy sump WRC short runner exhaust manifold Garret GT 35-40 turbo with speed sensor K&N air filter with RCMS 100mm inlet trumpet RCMS high flow intercooler with twin tube core 70mm stainless steel intercooler pipe work Electronics M800 Motec ECU with traction control,nitrous control,anti-lag paddle shift control,and full engine management control and data login Motec dash with data login Defi gauges for turbo,oil,fuel pressure Interior FIA carbon kevlar recaro seats FIA sabelt 6-point harness Transmission R180 STi rear axle 3.9:1 cwp and plated modena LSD differential GKN rally drive shafts front and rear Torque line carbon fibre propshaft Six speed subaru gearbox casing modified for sequential housing Six speed modena gear kit Subaru 3.9:1 front cwp RCMS sequential system RCMS paddle shift system Plated centre diff with 1:1 uprated output modena gears Plated front modena differential Fuel System FIA spec 26 litre rubber/kevlar bag tank in aluminium cover Twin bosch fuel pumps (200 litre per pump) -8 Goodrich fuel feed pipe -6 Goodrich fuel return pipe -6 fuel cooler with cooling fan on return RCMS 8 injector distribution block 2x SX fuel regulators running at 4 bar static pressure Suspension WRC spec exe-tc fully ajustable dampers High and low speed bump + rebound ajustment STi Rose jointed rear lateral links STi Rose jointed rear trailing links Exe-tc bottom rose jointed upright bushes STi alloy front arms (polished) STi quick-steer steering rack WRC roller bearing single piece steering column Momo suede steering wheel Nitrous NX full wet system 121bs carbon bottle with heater jacket High flow shark nozzle Motec auto control or driver manual system Ajustable from +35bhp to +400bhp Clutch RCMS spec triple plate alloy cover OS GIKEN clutch and flywheel RCMS hydraulic light pressure system Quick release dry brake fluid connection Brakes AP 355mm six pot front (track and road use) AP 304mm four pot front (drag strip use) AP 290mm four pot rear with floating discs RCMS hydraulic carbon handbrake -3 stainless steel goodrich pipe work and fittings Wheels Road/Track use 19x8 forged alloy 1 piece rims Drag strip use 15x8 spun alloy 3 piece rims Power=850 bhp Weight=1120 kgs First event:TOTB july 30th 2006 First show:Max Power Live 29th july 2006 Intended use:street/track/hill climbs/drag strip/time attack There you go,that is the spec list for the Gobstopper,typed by Chris. Hope this answers any questions you may have had,biggest spec list I have seen,its 00:20 and I"m off to bed. Link to comment Share on other sites More sharing options...
Gire Posted December 11, 2009 Share Posted December 11, 2009 Reminds me of my 05 wagon. Only slower. yeah, right. Cool vid. I love the effortless breaking of traction on this dedicated circuit racer. Like dorifto, but way better. Link to comment Share on other sites More sharing options...
KurtP Posted December 11, 2009 Share Posted December 11, 2009 Link to comment Share on other sites More sharing options...
MiniStiGuy Posted December 11, 2009 Share Posted December 11, 2009 Psshh my 5EAT is much faster than that! OEM HID's Rx330 Retro Link to comment Share on other sites More sharing options...
ehsnils Posted December 12, 2009 Share Posted December 12, 2009 He needs stickier tires on that one! Link to comment Share on other sites More sharing options...
Benaaron87 Posted December 30, 2009 Share Posted December 30, 2009 I showed that video to some of my mates with wrx and evo and all the evo boys reckon it's rear wheel drive and believe they could beat it in stock cars so I showed them the parts list and there were 3 very quiet and awe struck men . Haha gobsmacker should be it's name because that's the reaction I got from my mates and +1 on the sticky tires but it would still break traction . It's too much of an animal to be tamed Link to comment Share on other sites More sharing options...
jj808 Posted January 6, 2010 Share Posted January 6, 2010 Ill take 2 please. Link to comment Share on other sites More sharing options...
Gmoe Posted January 6, 2010 Share Posted January 6, 2010 sick Link to comment Share on other sites More sharing options...
