lossol Posted February 29, 2012 Author Share Posted February 29, 2012 Here is the exact cable I sell on the website: p/n TTL-232R-3V3-AJ It is a 3.3V USB to SERIAL converter with a 3.5MM PLUG There is a good chance other manufactures are using a similar cable, be careful they are not using the 5V signaling type though. I can only guarantee success with part number I specify. I like the plx interface better too. In fact I'm going to try to support PLX oil senders as well. I believe I have found the bug with the PLX power up issue and will probably have an update to the firmware out by Monday. Also I am 99% sure that plx cable they are selling on the website is available at digikey: Also I believe it's Identical to the programming cable I sell. http://www.plxdevices.com/datalogger.html http://search.digikey.com/us/en/products/TTL-232R-3V3-AJ/768-1098-ND/2285997 or mouser: http://www.mouser.com/ProductDetail/FTDI/TTL-232R-3V3-AJ/?qs=Xb8IjHhkxj4CJ2SCCMHPLQ%3d%3d VBG1 gauges available at www.gtboostgauge.com Link to comment Share on other sites More sharing options...
mmmmspecb Posted February 29, 2012 Share Posted February 29, 2012 Got my tracking info today, should be in by friday... Good stuff! Link to comment Share on other sites More sharing options...
praedet Posted March 2, 2012 Share Posted March 2, 2012 The new firmware works great w/ the PLX! Link to comment Share on other sites More sharing options...
mmmmspecb Posted March 2, 2012 Share Posted March 2, 2012 The new firmware works great w/ the PLX! Where did you get your PLX system from? None of the vendors seem to stock it. Link to comment Share on other sites More sharing options...
jayway Posted March 2, 2012 Share Posted March 2, 2012 The new firmware works great w/ the PLX! Same here! Link to comment Share on other sites More sharing options...
technicalgarage Posted March 4, 2012 Share Posted March 4, 2012 Just got my vbg1 and am loving it. Just curious with the lc-1 readout though. It seems as though it takes a while for the afr display to swing to air (20ish) after letting off to coast in gear when compared to taking a reading from logworks or romraider. In logworks or romraider, it will almost instantly swing to 20, but the vbg slowly swings across through the scale (like 14.7, 15, 16, 17...) before reaching the 20. Is there a built in delay in the vbg1 or is this a limit of the lc-1's analog output (since serial seems to update quickly)? Should I ditch the lc-1 and get a plx:lol:? I'm just concerned that the output is being filtered before being displayed, and that some quick spikes and dips in the afr would not be displayed during quickly changing fueling conditions. The other thing I noticed is that while sitting with the engine off, sometimes vac will show about 5 or 10mmhg instead of 0... I don't really care too much but was just wondering why this happens. Loving the gauge though, I can't believe I waited so long to get one! Link to comment Share on other sites More sharing options...
lossol Posted March 4, 2012 Author Share Posted March 4, 2012 technicalgarage - Thanks for the feedback. I have some answers for you. Is there a built in delay in the vbg1 or is this a limit of the lc-1's analog output (since serial seems to update quickly)? VBG1 provides an optional filtering option called "update rate" menu option # 14. You probably have found that menu option...I have noticed there is a problem with that menu configuration. Apparently I messed up because slow is actually the fastest update rate (minimum filtering) and visa versa. Try re-configuring this option and select slow, this should give you a much faster response. Oops. I will get this updated in the next release of firmware. Thanks for helping to identify this issue. The other thing I noticed is that while sitting with the engine off, sometimes vac will show about 5 or 10mmhg instead of 0... I don't really care too much but was just wondering why this happens. Most of the customer are likely operating with English units of vac and pressure so they probably don't notice this, but since the typical error is specified in the manual is +/- 0.25 PSI when you view mmHg your display unit resolution allows you to see that offset error. 10mmHg = 0.19PSI - in English units that value would display as 0. VBG1 gauges available at www.gtboostgauge.com Link to comment Share on other sites More sharing options...
technicalgarage Posted March 5, 2012 Share Posted March 5, 2012 You were absolutely right about the rate being the issue. I set it to low and it's instantaneous now. I figured that the vac display was simply standard error. Thanks for the clarification. Again, great gauge! Link to comment Share on other sites More sharing options...
mmmmspecb Posted March 5, 2012 Share Posted March 5, 2012 Can anybody else confirm that the cable lossol sells will work and is compatible w/ romraider for logging purposes?? Link to comment Share on other sites More sharing options...
ShadowImg Posted March 5, 2012 Share Posted March 5, 2012 Can anybody else confirm that the cable lossol sells will work and is compatible w/ romraider for logging purposes?? What are you plugging the other end into? I can confirm it will not be compatible with an OBD2 port, or an AccessPort. I don't believe you can datalog off the VBG1 itself, though that's an interesting feature request. Link to comment Share on other sites More sharing options...
mmmmspecb Posted March 5, 2012 Share Posted March 5, 2012 What are you plugging the other end into? I can confirm it will not be compatible with an OBD2 port, or an AccessPort. I don't believe you can datalog off the VBG1 itself, though that's an interesting feature request. From the PLX module to a laptop. I don't have the PLX unit yet so my ignorance may be showing... How is everybody else here logging their AFR wideband data? Link to comment Share on other sites More sharing options...
mmmmspecb Posted March 5, 2012 Share Posted March 5, 2012 Seems like nobody carries or stocks PLX stuff. Especially when all I want is the module and wideband w/o any additional gauges. I may just have to go direct. Link to comment Share on other sites More sharing options...
ShadowImg Posted March 5, 2012 Share Posted March 5, 2012 You can buy it all straight from PLX, I think most of us did. Link to comment Share on other sites More sharing options...
mmmmspecb Posted March 5, 2012 Share Posted March 5, 2012 You can buy it all straight from PLX, I think most of us did. Done. I may wait until it comes in before installing the VBG1 and do all the wiring at one time. Link to comment Share on other sites More sharing options...
jayway Posted March 6, 2012 Share Posted March 6, 2012 Can anybody else confirm that the cable lossol sells will work and is compatible w/ romraider for logging purposes?? I was able to update the firmware on my VBG1 using the $$$ PLX usb serial cable. With that said maybe we can assume one of the cheaper cables that lossol sells may just work to datalog the PLX. You should be the guinea pig. If it works ill be pissed that I spent so much on a damn cable:spin: Link to comment Share on other sites More sharing options...
lossol Posted March 6, 2012 Author Share Posted March 6, 2012 jayway - you are probably right. Yeah like I said before I am almost 100% sure about this: It is a simple virtual communication port - also plx specifies that their interface is 3.3 Volts. These cables come in two different voltage levels. 3.3 and 5. VBG1 operates on the 3.3 v signals Also I am 99% sure that plx cable they are selling on the website is available at digikey: Also I believe it's Identical to the programming cable I sell. http://www.plxdevices.com/datalogger.html http://search.digikey.com/us/en/products/TTL-232R-3V3-AJ/768-1098-ND/2285997 or mouser: http://www.mouser.com/ProductDetail/FTDI/TTL-232R-3V3-AJ/?qs=Xb8IjHhkxj4CJ2SCCMHPLQ%3d%3d VBG1 gauges available at www.gtboostgauge.com Link to comment Share on other sites More sharing options...
jproy12 Posted March 7, 2012 Share Posted March 7, 2012 Small update on my end, have one of the first beta units of the latest version, and still going strong! When having a small question or when in doubt, Andy replies to his emails extremely fast, for the ones that are hesitating, don't, this is the "boost gauge" to have! JP Link to comment Share on other sites More sharing options...
lossol Posted March 7, 2012 Author Share Posted March 7, 2012 Thanks for the feedback JP. Any updates from the 5th Gen LGT beta testers? VBG1 gauges available at www.gtboostgauge.com Link to comment Share on other sites More sharing options...
praedet Posted March 7, 2012 Share Posted March 7, 2012 One interesting thing w/ the PLX is every so often (usually in cruise on the HWY) the PLX readout will go from a single decimal place, to 2 decimal place. I don;t know why and it seems random, but always cruise in vacuum... Link to comment Share on other sites More sharing options...
lossol Posted March 7, 2012 Author Share Posted March 7, 2012 so it would go from 14.7 to 14.70 ? VBG1 gauges available at www.gtboostgauge.com Link to comment Share on other sites More sharing options...
praedet Posted March 7, 2012 Share Posted March 7, 2012 More random, usually xx.x2 or xx.x8... Link to comment Share on other sites More sharing options...
lossol Posted March 7, 2012 Author Share Posted March 7, 2012 Too quick or rare to snap a pic or a vid? VBG1 gauges available at www.gtboostgauge.com Link to comment Share on other sites More sharing options...
praedet Posted March 7, 2012 Share Posted March 7, 2012 I'll try... Link to comment Share on other sites More sharing options...
ShadowImg Posted March 7, 2012 Share Posted March 7, 2012 I still randomly have an alarm going off, and I turned everything off but overboost (which is set at 20psi). I'm definitely not legitimately hitting 20psi at any point (stock turbo, stage 1 OTS, peaking at ~15psi), and I've never seen a BP after saying anything over 16.x PSI. Any thoughts on how I can figure out what alarm I'm setting off and what the value was that triggered it? Link to comment Share on other sites More sharing options...
lossol Posted March 7, 2012 Author Share Posted March 7, 2012 Sorry ShadowImg - didn't know this issue was still in existence. I will try and get it fixed... Do you know what version you are running? 1.05b? Does it go off during boost or vac? Anyone else see this issue and if so what version are you running? VBG1 gauges available at www.gtboostgauge.com Link to comment Share on other sites More sharing options...
