HipsterDoofus Posted September 2, 2009 Share Posted September 2, 2009 As compared to a normal sedan? Am i totally making myself open to flaming or what? Im just curious. Link to comment Share on other sites More sharing options...
subaruski Posted September 2, 2009 Share Posted September 2, 2009 you have a hood scoop Link to comment Share on other sites More sharing options...
HipsterDoofus Posted September 2, 2009 Author Share Posted September 2, 2009 you have a hood scoop ....are you serious? Isnt it totally non functional? Link to comment Share on other sites More sharing options...
HipsterDoofus Posted September 2, 2009 Author Share Posted September 2, 2009 its not any quicker? no extra ponies? nothing of the sort? that kind of depresses me Link to comment Share on other sites More sharing options...
legacyCT Posted September 2, 2009 Share Posted September 2, 2009 Well the regular sedans were non-turbo'd.. So we have the turbo platform, and the hood scoop is functional because the car has a TMIC which the ambient air flowing through the opening cools the topmount thus cooling the charge. Same concept as a FMIC just well ontop.. Im new to the subies especially the GT as well. Others im sure can chime in with more. Link to comment Share on other sites More sharing options...
Beanboy Posted September 2, 2009 Share Posted September 2, 2009 Not functional on his... Notice the year. 2.5L versus 2.2L I believe. Maybe some tire/wheel differences. -B http://www.standardshift.com Link to comment Share on other sites More sharing options...
Max Capacity Posted September 2, 2009 Share Posted September 2, 2009 Different wheels, I think the brakes and steering wheel. I can look in the second drawer in the nightstand on the right side of my bed when I get home. I have the Subaru showroom brochure there from my 98GT wagon, if it's really that important to you. I'll try and remember... yea like that's going to happen. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Max Capacity Posted September 2, 2009 Share Posted September 2, 2009 Not functional on his... Notice the year. QUOTE] Hey, be nice to him, he's from W.Hartford CT LOL OMG, Nate is that you? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Beanboy Posted September 2, 2009 Share Posted September 2, 2009 cars101 helps, will list specs. -B http://www.standardshift.com Link to comment Share on other sites More sharing options...
leggtnut Posted September 2, 2009 Share Posted September 2, 2009 From memory, the GT back then got BBS wheels, some ground effects, different final drive, different steering wheel, but I think not much else. Check http://www.cars101.com. You will find it in the archives. Ben (2014 Outback SAP w/ eyesite, 2014 Tribeca Limited, 2006 LGT limited sedan) Subaru Ambassador PNW Link to comment Share on other sites More sharing options...
HipsterDoofus Posted September 2, 2009 Author Share Posted September 2, 2009 looking at it right now, thanks! Link to comment Share on other sites More sharing options...
HipsterDoofus Posted September 2, 2009 Author Share Posted September 2, 2009 Standard legacy Sedan Engine: Phase II 2.2L 4 cylinder boxer engine Horsepower: 142 hp at 5600 rpm, 149 ft. lbs torque at 3600 rpm Fuel system: multi-port sequential fuel injection with distributorless electronic ignition Fuel economy: city/highway 22/29 all models regular unleaded, 15.9 gal. tank Brakes: Brighton model: power 10.1" front disk. Rear drum L models: 4 channel Anti-Lock Brakes - 4 disk, 10.1" front, 10.5" rear. Steering: engine rpm sensing variable assist rack and pinion Link to comment Share on other sites More sharing options...
HipsterDoofus Posted September 2, 2009 Author Share Posted September 2, 2009 Lgt engine: 2.5-l 4 cylinder, dohc boxer engine horsepower: 165 hp at 5600 rpm, 162 ft. Lbs torque at 4000 rpm fuel system: Multi-port sequential fuel injection with distributorless electronic ignition fuel economy: City/highway 21/27 manual transmission, 21/26 automatic transmission regular unleaded, 15.9 gal. Tank brakes: 4 channel anti-lock brakes - heavy duty, dual caliper piston, 10.7" front disk,10.5" rear. Wheels: 16' alloy with 205/65r-16 tires steering: Variable assist rack and pinion Link to comment Share on other sites More sharing options...
sactojesse Posted September 2, 2009 Share Posted September 2, 2009 From memory, the GT back then got BBS wheels, some ground effects, different final drive, different steering wheel, but I think not much else. Check http://www.cars101.com. You will find it in the archives. They weren't BBS wheels, just cast alloy snowflake rims I believe. Link to comment Share on other sites More sharing options...
leggtnut Posted September 2, 2009 Share Posted September 2, 2009 I could easily be wrong, but I remember that the some of the 96 - 2004 GT's had BBS wheels, just couldn't remember which. Ben (2014 Outback SAP w/ eyesite, 2014 Tribeca Limited, 2006 LGT limited sedan) Subaru Ambassador PNW Link to comment Share on other sites More sharing options...
pillboy Posted September 2, 2009 Share Posted September 2, 2009 Obviously the badge. Since you took it off, no more GT. It is still ugly. Link to comment Share on other sites More sharing options...
HipsterDoofus Posted September 2, 2009 Author Share Posted September 2, 2009 Obviously the badge. Since you took it off, no more GT. is it still ugly? Link to comment Share on other sites More sharing options...
GTTuner Posted September 2, 2009 Share Posted September 2, 2009 I never understood the non functional hood scoop. Must have been cool in Japan at the time. Link to comment Share on other sites More sharing options...
leggtnut Posted September 2, 2009 Share Posted September 2, 2009 I think that the hood scoop was left in the USDM models. I believe that Japan still had a trubo option durring those years, correct me if i am wrong. Ben (2014 Outback SAP w/ eyesite, 2014 Tribeca Limited, 2006 LGT limited sedan) Subaru Ambassador PNW Link to comment Share on other sites More sharing options...
HipsterDoofus Posted September 2, 2009 Author Share Posted September 2, 2009 oh well, at least it satiated my curiosity still kind of a downer though Link to comment Share on other sites More sharing options...
SilverLeg Posted September 2, 2009 Share Posted September 2, 2009 The hood scoop functions by allowing soap to get in and clean the intercooler during washing, you'd never want a dirty intercooler, that would be bad... . Link to comment Share on other sites More sharing options...
Guest heightsgtltd Posted September 2, 2009 Share Posted September 2, 2009 BBS wheels were definitely at least an option on those cars Link to comment Share on other sites More sharing options...
johnAWD Posted September 2, 2009 Share Posted September 2, 2009 [tongue in cheek] The GT is really really fast. Esp the spec b. Just ask around. [/tongue in cheek] Link to comment Share on other sites More sharing options...
leggtnut Posted September 2, 2009 Share Posted September 2, 2009 oh well, at least it satiated my curiosity still kind of a downer though Hey, at least you now know that you get ~23HP more than the non 98LGT Ben (2014 Outback SAP w/ eyesite, 2014 Tribeca Limited, 2006 LGT limited sedan) Subaru Ambassador PNW Link to comment Share on other sites More sharing options...
legacyCT Posted September 2, 2009 Share Posted September 2, 2009 Not functional on his... Notice the year. QUOTE] Hey, be nice to him, he's from W.Hartford CT LOL OMG, Nate is that you? Yes its me!! I didnt see he had a 98.. my B! Link to comment Share on other sites More sharing options...
