mvigneau Posted March 16, 2005 Share Posted March 16, 2005 Well, here is the PDF of my iPod mini installation. I hope you enjoy because it took me a long time with a lot of hard work. Anyways. Get it here: http://www.pimpmyauto.com/Docs/iPod%20Mini%20installation.pdf No Silent CD Aux-In Solution Link to comment Share on other sites More sharing options...
rao Posted March 16, 2005 Share Posted March 16, 2005 Looks great. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
Ken S Posted March 16, 2005 Share Posted March 16, 2005 Very nice work! Ken Link to comment Share on other sites More sharing options...
mwiener2 Posted March 16, 2005 Share Posted March 16, 2005 Ewwww. Sticky My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
domphz Posted March 16, 2005 Share Posted March 16, 2005 good job Link to comment Share on other sites More sharing options...
jp928 Posted March 17, 2005 Share Posted March 17, 2005 So what are the part nos/models of the connectors I will need to make up a lead I can splice into please? TIA, jp Link to comment Share on other sites More sharing options...
mvigneau Posted March 17, 2005 Author Share Posted March 17, 2005 I am actually waiting to receive samples from others and will be offering them in the For Sale Section if you are interested and don't want to have to make your own. Just a thought. But the part numbers from Hirose are: GT13-2428/1.6-2.9SCF GT13SC-2/1S-R GT13SC-2/1S-HU GT13-2428/1.6-2.9PCF GT13SC-2/1PP-R GT13SCN-2/1PP-HU No Silent CD Aux-In Solution Link to comment Share on other sites More sharing options...
jp928 Posted March 17, 2005 Share Posted March 17, 2005 I am already on your list for a cable pair, but I am in Oz, so postage may be an issue, and getting impatient. If I can find the connectors here, I should be able to get some made up and move on. If I cant find them, I will just wait. Can I assume that the above list describes a male and female pair, and the internal pins as separate items in them? Thanks, jp Link to comment Share on other sites More sharing options...
wayne53 Posted March 17, 2005 Share Posted March 17, 2005 Looks very good, I like it a lot! -Tyler Link to comment Share on other sites More sharing options...
mvigneau Posted March 17, 2005 Author Share Posted March 17, 2005 Yes...It is everything needed to make the subaru male and female ends of the cable. Internal Pins, Outside Casing and Locking mechanism (male and female). No Silent CD Aux-In Solution Link to comment Share on other sites More sharing options...
JonFo Posted March 19, 2005 Share Posted March 19, 2005 I am actually waiting to receive samples from others and will be offering them in the For Sale Section if you are interested and don't want to have to make your own. Just a thought. Great Job! Count me in as being interested in buying a built set. Jonathan Link to comment Share on other sites More sharing options...
mvigneau Posted March 20, 2005 Author Share Posted March 20, 2005 Please add your name to the list located at: http://legacygt.com/forums/showthread.php?t=9307 No Silent CD Aux-In Solution Link to comment Share on other sites More sharing options...
bemani Posted March 23, 2005 Share Posted March 23, 2005 So you can't control the AC?? Link to comment Share on other sites More sharing options...
mvigneau Posted March 23, 2005 Author Share Posted March 23, 2005 I can still control the AC. It just hides the actual temperature that it is set at (I use the auto). I can remove the iPod (without pausing it), change the setting and plug the iPod back in within 3 seconds so I am not too worried about it. No Silent CD Aux-In Solution Link to comment Share on other sites More sharing options...
phamilton Posted April 16, 2005 Share Posted April 16, 2005 Do you have to turn the FM Modulator off when you want to listen to the radio? Are you still looking for people to purchase the antenna connections? Look great! I have been considering the use of an FM Modulator myself, this thread was very informative. Link to comment Share on other sites More sharing options...
mvigneau Posted April 16, 2005 Author Share Posted April 16, 2005 The FM Modulator automatically turns off after 20 seconds. If you want to purchase an Antenna adapter...add your name to the list located at the other topic. No Silent CD Aux-In Solution Link to comment Share on other sites More sharing options...
tu11ym0n Posted April 26, 2005 Share Posted April 26, 2005 Well, here is the PDF of my iPod mini installation. I hope you enjoy because it took me a long time with a lot of hard work. Anyways. Get it here: http://www.pimpmyauto.com/Docs/iPod%20Mini%20installation.pdf i guess i'm dense but I didn't see anything in the PDF that shows how to install the FM modulator to the antenna. is this an easy process provided one has one of your cables? where is the antenna located and what needs to be removed in order to access it? thanks! Link to comment Share on other sites More sharing options...
mvigneau Posted April 26, 2005 Author Share Posted April 26, 2005 You have to remove the radio and it is on the right side of the Lower Portion. It is easy to install just disconnect the 2 connectors in the car and connect each side to the other side of my cables and the other side of my cables to your FM Modulator. No Silent CD Aux-In Solution Link to comment Share on other sites More sharing options...
jp928 Posted July 5, 2005 Share Posted July 5, 2005 In case others are looking for more Ipod stuff, go to http://accessory.subaru.co.jp/index.html select "best selection for Legacy" then entertainment tab - there are several items there flagged with "ipod", and what looks like a Kenwood ipod interface - ipod with cable attached going into a small box, then cable out to some sort of connector..... jp Link to comment Share on other sites More sharing options...
tu11ym0n Posted July 5, 2005 Share Posted July 5, 2005 In case others are looking for more Ipod stuff, go to http://accessory.subaru.co.jp/index.html select "best selection for Legacy" then entertainment tab - there are several items there flagged with "ipod", and what looks like a Kenwood ipod interface - ipod with cable attached going into a small box, then cable out to some sort of connector..... jp direct link: http://accessory.subaru.co.jp/legacy/customize/main.html Link to comment Share on other sites More sharing options...
ADaniels Posted September 1, 2005 Share Posted September 1, 2005 I'm still not clear on the FM modulator. Basically are you hacking into the antenna, and forcing your IPOD to play via the antenna? In order to listen to the radio do you have to unplug your ipod? Link to comment Share on other sites More sharing options...
mvigneau Posted September 2, 2005 Author Share Posted September 2, 2005 Yep...it force the iPod to play via the antenna. After 20 seconds of not playing, the radio will come back. There are also FM Modulators that actually have an input selector switch. No Silent CD Aux-In Solution Link to comment Share on other sites More sharing options...
johnnysubaru Posted September 4, 2005 Share Posted September 4, 2005 Very nice job indeed! Sure hope they'll come out with something for the Outback 2.5i 'cause that looks like a lot of work! Slightly off topic, but if you're not happy with your Motorola v710 (like I am) KirklandPackard & Verizon just settled a class action lawsuit from angry 710 users where I believe they'll refund your money for the phone (and accessories) if you bought it before 2/01/05. Details will be available later this month... http://www.kirtlandpackard.com/v710/ Link to comment Share on other sites More sharing options...
mvigneau Posted September 17, 2005 Author Share Posted September 17, 2005 Check out my solution and price list!!! Works great and no CD playing needed!! :) http://www.legacygt.com/forums/showthread.php?t=18870 No Silent CD Aux-In Solution Link to comment Share on other sites More sharing options...
jonnyg113 Posted February 8, 2006 Share Posted February 8, 2006 What happens when your Ipod breaks and you decide to get a new one that doesnt fit!!!! OMG.... Sorry, not to hate, thats just what happend to my roomate who did the same thing in his GTi. Really nice install though. Commend the.... Link to comment Share on other sites More sharing options...
