Guest Posted August 21, 2009 Share Posted August 21, 2009 Once more again, the bracket CANNOT be fabricated for the rear 08 Brembos, unless a custom rotor is made as well. It wasn't a speculation the rears don't fit. It's a well known fact, bit of searching around would give you an answer. Link to comment Share on other sites More sharing options...
Goyim Posted August 21, 2009 Share Posted August 21, 2009 don't worry about it. all this brake bias crap. GT500 for years run 4pots in front and single in the rear. so do many Steeda set-ups. Steeda just throws 4pots on the front of 'Stangs and send them off. Steeda cars are some of the best track cars out. Link to comment Share on other sites More sharing options...
Guest Posted August 21, 2009 Share Posted August 21, 2009 Yeah, to hell with the brake bias crap. I suggest eliminating rear brakes for extra weight savings.... Link to comment Share on other sites More sharing options...
JSK05LGT Posted August 22, 2009 Author Share Posted August 22, 2009 Unclemat - I read your post on the 12th, no need to repeat it yet again. Im sure eventually someone will develop a custom rotor and bracket for the 08/09 rears, as the brakes are already poping up all over the forums and on eBay, or at least I hope they do :o) Link to comment Share on other sites More sharing options...
KurtP Posted August 22, 2009 Share Posted August 22, 2009 ok, so the key to fitment is to run 08 sti front brakes with 04-05 rears and everything bolts right up to the stock rotors? Link to comment Share on other sites More sharing options...
TPLGT Posted August 22, 2009 Share Posted August 22, 2009 Unclemat - I read your post on the 12th, no need to repeat it yet again. Im sure eventually someone will develop a customer rotor and bracket for the 08/09 rears, as the brakes are already poping up all over the forums and on eBay. Good work ok the brake upgrade. Looking forward to seeing the finished job. The 08 brakes should be able to be fit at some point. Maybe KB or yimi will put together a bracket for them. Rehab is for quitters. Link to comment Share on other sites More sharing options...
Guest Posted August 22, 2009 Share Posted August 22, 2009 Dream on. Link to comment Share on other sites More sharing options...
JSK05LGT Posted August 22, 2009 Author Share Posted August 22, 2009 ok, so the key to fitment is to run 08 sti front brakes with 04-05 rears and everything bolts right up to the stock rotors? You can run the front 08/09 calipers on the factory mounting locations, but you still need an 04 STI rotor (5x100 fitment). DBA makes theses as does quite a few other companies. The 04-07 rears will bolt up, but require a special rotor for the parking brake to work properly, or as Unclemat has posted, you can go through Onkelracing for a set of parking brake shoes, and they will do the trick. After that you just need the Brembo adapter brackets for sale through MachV, or Yimisport and you are good to go! I personally like the black brembos MUCH better than the gold sets :o) Link to comment Share on other sites More sharing options...
JSK05LGT Posted August 22, 2009 Author Share Posted August 22, 2009 Dream on. Oh I will sir, I may make a set of book ends out of the 08 rears I have though :lol::lol: Link to comment Share on other sites More sharing options...
TPLGT Posted August 23, 2009 Share Posted August 23, 2009 Dream on. Whatever. I guess you're leading authority on what will or will not happen in the brembo brake world? Rehab is for quitters. Link to comment Share on other sites More sharing options...
TPLGT Posted August 23, 2009 Share Posted August 23, 2009 You can run the front 08/09 calipers on the factory mounting locations, but you still need an 04 STI rotor (5x100 fitment). DBA makes theses as does quite a few other companies. The 04-07 rears will bolt up, but require a special rotor for the parking brake to work properly, or as Unclemat has posted, you can go through Onkelracing for a set of parking brake shoes, and they will do the trick. After that you just need the Brembo adapter brackets for sale through MachV, or Yimisport and you are good to go! I personally like the black brembos MUCH better than the gold sets :o) Once you get the 08 front and 04 rear set up, let us know how it works out. I am curious as to the difference using the newer fronts. Are they beefier? Rehab is for quitters. Link to comment Share on other sites More sharing options...
Guest Posted August 23, 2009 Share Posted August 23, 2009 Whatever. I guess you're leading authority on what will or will not happen in the brembo brake world? No. If you looked a the new rears and thought for a moment you would also knew the bracket is not possible to due the interference with the trailing arm on Legacy. As simple as that. Once you get the 08 front and 04 rear set up, let us know how it works out. I am curious as to the difference using the newer fronts. Are they beefier? No, they are the same. Link to comment Share on other sites More sharing options...
JSK05LGT Posted August 23, 2009 Author Share Posted August 23, 2009 Once you get the 08 front and 04 rear set up, let us know how it works out. I am curious as to the difference using the newer fronts. Are they beefier? You know, now that I look at it, the rears do look beefier, I cant tell (nor do I have anything to properly measure with) I think it is just the housing that appears larger. I will absolutely keep you posted on feel and performance, as well as more pictures Link to comment Share on other sites More sharing options...
JSK05LGT Posted August 23, 2009 Author Share Posted August 23, 2009 Unclemat - so they dont work on Legacy's, have you done any other research that would lead you to believe these rears would work on anything other than the 08-09 STI? Im seriously interested, because I dont want to keep them collecting dust, and would like to sell them, hell at my asking price, im basically giving them away. Link to comment Share on other sites More sharing options...
JSK05LGT Posted August 23, 2009 Author Share Posted August 23, 2009 <---- i love the black brembo look! Link to comment Share on other sites More sharing options...
TPLGT Posted August 23, 2009 Share Posted August 23, 2009 Yeah the black Brembos are sweet. Did you have the rears painted to match yet? Why don't you sell them on nabisco? Rehab is for quitters. Link to comment Share on other sites More sharing options...
JSK05LGT Posted August 23, 2009 Author Share Posted August 23, 2009 Yes sir, they should be ready to go, im going up to MachV tomorrow to throw them on, I will get the pics and share :o))) Link to comment Share on other sites More sharing options...
atc5 Posted August 23, 2009 Share Posted August 23, 2009 I like mine with my carbon fiber rotors http://i219.photobucket.com/albums/cc93/atc5photos/CIMG3886.jpg Link to comment Share on other sites More sharing options...
Guest Posted August 23, 2009 Share Posted August 23, 2009 Unclemat - so they dont work on Legacy's, have you done any other research that would lead you to believe these rears would work on anything other than the 08-09 STI? Im seriously interested, because I dont want to keep them collecting dust, and would like to sell them, hell at my asking price, im basically giving them away. They will work 08-09 non-STI Impreza. You are wasting yours and everybody's else time trying to sell them here. Link to comment Share on other sites More sharing options...
JSK05LGT Posted August 24, 2009 Author Share Posted August 24, 2009 They will work 08-09 non-STI Impreza. You are wasting yours and everybody's else time trying to sell them here. Unclemat - Thanks for the info, but are you naturally this negative, or do you just try really hard? While I appreciate your knowledge, it seems that most of your posts are just about why or how things wont work or dont. Work on your delivery a little bit, and remember not everyone has your experience, or enough time to search the 1000's of posts available on the net. In return I will stop trying to sell them here and wasting the members time. Link to comment Share on other sites More sharing options...
JSK05LGT Posted August 24, 2009 Author Share Posted August 24, 2009 I like mine with my carbon fiber rotors http://i219.photobucket.com/albums/cc93/atc5photos/CIMG3886.jpg VERY NICE ALAN! Those look amazing! Link to comment Share on other sites More sharing options...
TPLGT Posted August 24, 2009 Share Posted August 24, 2009 Unclemat - Thanks for the info, but are you naturally this negative, or do you just try really hard? While I appreciate your knowledge, it seems that most of your posts are just about why or how things wont work or dont. Work on your delivery a little bit, and remember not everyone has your experience, or enough time to search the 1000's of posts available on the net. In return I will stop trying to sell them here and wasting the members time. Bwaaahahahaha. You put it nicely. Hey Unclemat, go back and re-read most of your posts... Rehab is for quitters. Link to comment Share on other sites More sharing options...
JSK05LGT Posted August 24, 2009 Author Share Posted August 24, 2009 Im not trying to be rude, but I made a mistake on the purchase of the rears and didnt do my research, in my sale thread I clearly state that someone with an 08-09 STI should purchase, hoping someone might have a legacy and an STI here on the forums and would like the price, im not trying to waste anyones time. Link to comment Share on other sites More sharing options...
Waxiboy Posted August 24, 2009 Share Posted August 24, 2009 I like mine with my carbon fiber rotors http://i219.photobucket.com/albums/cc93/atc5photos/CIMG3886.jpg Maybe carbon ceramic? Link to comment Share on other sites More sharing options...
Waxiboy Posted August 24, 2009 Share Posted August 24, 2009 They will work 08-09 non-STI Impreza. Do you think this will work in a 2009 FXT? Link to comment Share on other sites More sharing options...
