Max Capacity Posted February 23, 2012 Share Posted February 23, 2012 Oh yea, to get the car that high I used pieces of 4x4 blocks and 2x4 blocks. I have the big 6 ton stands from Harbor fright. I've been doing this kind of work on cars since the mid 1970's. I guess I would also teach guy's to bring the car up slowly. Don't try and go the whole way in one shot. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
jhawk222 Posted February 23, 2012 Share Posted February 23, 2012 I just picked up a Pittsburgh Automotive Low Profile 2 Ton Rapid pump floor jack with a lift range of 2.5 to 24 inches. I got lucky a guy was selling on ebay local to me. Link to comment Share on other sites More sharing options...
MrHellrais3R Posted February 23, 2012 Share Posted February 23, 2012 I got a 2 1/2 ton low pro jack that has a 2 1/2"-3" clearance and is dual piston. 8 pumps and it's at 20". All for the low low price of $80. God I love harbor freight lol. Link to comment Share on other sites More sharing options...
jhawk222 Posted February 23, 2012 Share Posted February 23, 2012 http://contact.ebay.com/ws1/eBayISAPI.dll?ShowEmailAuctionToFriend&rt=nc&item=160740970359 Here's another jack, only lifts to 18 ins. though. Link to comment Share on other sites More sharing options...
MrHellrais3R Posted February 23, 2012 Share Posted February 23, 2012 http://www.harborfreight.com/merchandising-promotions/floor-jacks-and-jack-stands/2-ton-low-profile-heavy-duty-floor-jack-rapid-pump-68050.html Here's the jack I have. I got it when it was on sale. I guess I was wrong, not 20" max but 23" almost 24" lift. Link to comment Share on other sites More sharing options...
frank_ster Posted February 24, 2012 Share Posted February 24, 2012 there Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
Mr. Sinister Posted February 24, 2012 Share Posted February 24, 2012 ^ Jackstands? Link to comment Share on other sites More sharing options...
charlie_sheen Posted February 24, 2012 Share Posted February 24, 2012 there i hear your mechanic there can be a real bitch Link to comment Share on other sites More sharing options...
frank_ster Posted February 24, 2012 Share Posted February 24, 2012 ^ Jackstands? if your worried i can install those annoying ratchet locks on the side. Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
Mr. Sinister Posted February 24, 2012 Share Posted February 24, 2012 Pass. I'll just make my own using 2X4s. Link to comment Share on other sites More sharing options...
jhawk222 Posted February 25, 2012 Share Posted February 25, 2012 http://www.harborfreight.com/merchandising-promotions/floor-jacks-and-jack-stands/2-ton-low-profile-heavy-duty-floor-jack-rapid-pump-68050.html Here's the jack I have. I got it when it was on sale. I guess I was wrong, not 20" max but 23" almost 24" lift. Same one I got...in your original post you said 20" so I thought you had a different jack. I love this jack:wub: Link to comment Share on other sites More sharing options...
MrHellrais3R Posted February 25, 2012 Share Posted February 25, 2012 Same one I got...in your original post you said 20" so I thought you had a different jack. I love this jack:wub: For $80, I love this jack. I havent touched my "crapsman" since I got it. Link to comment Share on other sites More sharing options...
OutbackXT05 Posted February 28, 2012 Share Posted February 28, 2012 Cant go wrong with the good old harbor frieght low pro jacks. Mines still going strong and gets under anything. Ony issues are cars with body kits where the jack hits the kit before the jack point. Link to comment Share on other sites More sharing options...
Max Capacity Posted February 28, 2012 Share Posted February 28, 2012 Cant go wrong with the good old harbor frieght low pro jacks. Mines still going strong and gets under anything. Ony issues are cars with body kits where the jack hits the kit before the jack point. That's why you drive the car up on a 2x6 before you try and jack it up. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Max Capacity Posted February 28, 2012 Share Posted February 28, 2012 there Only you would think of that.... LOL 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
OutbackXT05 Posted March 1, 2012 Share Posted March 1, 2012 I just made a little spacer out of mdf to get around it. Works good for cars which the pinch lift points too so it doesnt bend them. Link to comment Share on other sites More sharing options...
maniaxzero Posted March 1, 2012 Share Posted March 1, 2012 Had the little black craftsman. Had to pump forever to get the car up but lasted like 5 years before it started leaking. http://www.sears.com/shc/s/p_10153_12605_00950523000P?pid=00950523000&aff=Y&i_cntr=1330636458556&sid=I0084400010000100600#reviewsWrap Then I got this aluminum one from harbor freight. Works good when it works. Took far less pumps than the craftsman and its very lightweight. However, I had to replace it twice(good thing I got the replacement plan). First time was a defect with the handle, the ball spring was no good. Took it back right after. Now the second one I got lasted a total of 5 months before it crapped out and wouldnt hold pressure. Keep in mind I only used the jack prolly like 4 times in 5 months. http://www.harborfreight.com/rapid-pump-15-ton-compact-aluminum-racing-jack-68053-html-7814.html So i took it back to harbor freight, and the manager made me a deal. I paid $13 more and got the 3 ton heavy duty one. She told me this one is alot more dependable. But it is heavy as shit. Like over 75 pounds. Havent opened it yet, only time will tell if it will last. http://www.harborfreight.com/automotive-motorcycle/floor-jacks/3-ton-heavy-duty-floor-jack-with-rapid-pump-68048.html Link to comment Share on other sites More sharing options...
ClimberDHexMods Posted March 22, 2012 Author Share Posted March 22, 2012 I got my new Torin (Big Red (though it's black)) 2-ton long reach floor jack Northern Tool Item# 1448026. http://www.northerntool.com/shop/tools/product_200349257_200349257 Got it for under $200, and this time bought the extended warranty for $21. Weighs 160lbs. I probably won't use it much except for transmission swaps, and when my aluminum jack fails. I didn't measure the hump height (arm pivot point height), but will do so and also measure new ride height after lengthening KW coilovers up to more reasonable height (damn you suspension geometry). Will buy wood or tiles to roll up onto for use with it if not too much thickness required, which I need to do anyways after measuring out the garage for my alignment checkup positioning (ideal to have 4 corners level). Looking forward to keeping up my own alignments now that I know how easy it is to do If I could get an ideal long reach jack like AC Hydraulics instead for twice the price, I probably would. But for triple what I paid, I personally probably wouldn't. Doesn't make the car any better or dramatically easier to work on. $400 also buys some nice snap-on tools. [CENTER][B][I] Front Limited Slip Racing Differentials for the 5EAT now available for $1895 shipped, please inquire for details! [/I][/B][/CENTER] Link to comment Share on other sites More sharing options...
ClimberDHexMods Posted March 22, 2012 Author Share Posted March 22, 2012 This is the one I also have and broke when the saddle slipped and it shock loaded it. http://www.harborfreight.com/15-ton-lightweight-aluminum-racing-jack-with-rapid-pump-68054.html 1.5 ton, goes up to 17.25" for me, and fits under my lowered car I just toss it back in the box it came in with foam casing, and put it in my trunk. Light weight One of the pistons got stuck, so I pulled the roller c-clip and roller pin, and pulled out the stuck piston, then swapped pistons side to side. Now both are sliding free again, and jack appears to work. I am a fool for not buying the extended warranty on this item. I never thought I would say that. Hopefully it keeps working now. I'm never getting under it even for a second without a jack stand. One jack fail episode is plenty, thankfully not a bad one at that. [CENTER][B][I] Front Limited Slip Racing Differentials for the 5EAT now available for $1895 shipped, please inquire for details! [/I][/B][/CENTER] Link to comment Share on other sites More sharing options...
ClimberDHexMods Posted April 3, 2012 Author Share Posted April 3, 2012 Saw this in email today, but of course they price it just high enough to make it feel like you're being stupid with your money if you buy it: http://www.tciauto.com/tc/transmission-jack-adapter.html?AID=3236 http://tciauto.compperformance.com/media/catalog/product/cache/11/image/435x375/9df78eab33525d08d6e5fb8d27136e95/8/9/896500_web_1.jpg [CENTER][B][I] Front Limited Slip Racing Differentials for the 5EAT now available for $1895 shipped, please inquire for details! [/I][/B][/CENTER] Link to comment Share on other sites More sharing options...
Max Capacity Posted April 3, 2012 Share Posted April 3, 2012 I used this one when I had to pull my tranny last year. http://www.harborfreight.com/450-lb-capacity-transmission-jack-39178.html You need to get the car up pretty high, but with blocks of 4x4's it's not that hard to do with two floor jacks. I got the wagon up high enough that I could put the tranny on the jack than roll it under the front of the car. I have 4 of the 6 ton jackstands too. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
ClimberDHexMods Posted April 3, 2012 Author Share Posted April 3, 2012 I have the same one, used it for two swaps. Mine has gotten a bit unstable in that it will lean to the left or right; the scissor aspect does not have a provision to keep it from leaning. So I have to take care to keep it vertical as I raise it. I also should come up with an anti-slip solution, such as a sheet of rubber, as the painted top of it allows me to swivel the Trans around whether intended or not. My ideal would be to just hoist and lower the front of the car frame up above and lower onto a stationary engine/Trans, but this does not appear popular outside of American cars. [CENTER][B][I] Front Limited Slip Racing Differentials for the 5EAT now available for $1895 shipped, please inquire for details! [/I][/B][/CENTER] Link to comment Share on other sites More sharing options...
ClimberDHexMods Posted April 11, 2012 Author Share Posted April 11, 2012 I would buy this in a heartbeat if I didn't already have my jack needs met: http://www.northerntool.com/shop/tools/product_200345429_200345429?cm_mmc=Housefile-_-NOWONSALE-_-buyonline1-_-Title&cm_lm=dhettena@gmail.com&state=TX&hotline=&market=DAL [CENTER][B][I] Front Limited Slip Racing Differentials for the 5EAT now available for $1895 shipped, please inquire for details! [/I][/B][/CENTER] Link to comment Share on other sites More sharing options...
Boulderguy Posted April 12, 2012 Share Posted April 12, 2012 ^^ same one is at Costco for $100. Not on the website tho. Link to comment Share on other sites More sharing options...
Max Capacity Posted April 12, 2012 Share Posted April 12, 2012 ^^^ I was looking at that one the other day myself. Saw something like it at Harbor Fright over the weekend. Told the GF if I ever need another heavy floor jack that would be it. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
