raloi Posted May 20, 2009 Share Posted May 20, 2009 I've noticed that my car seems to have lost its 'get up and go' ..... not as responsive as it once was . Just turning 47,000 miles, Cobb Stage 1 ...... have tried resetting ecu with no luck ..... ideas ???? Link to comment Share on other sites More sharing options...
rnstein69 Posted May 20, 2009 Share Posted May 20, 2009 has it been a gradual change to becoming not as responsive? myabe try to change the air filter, change tranny and rear diff fluid, spark plugs etc? Link to comment Share on other sites More sharing options...
Scotty Posted May 20, 2009 Share Posted May 20, 2009 I think you need your butt dyno recalibrated. You are probably just used to your car now. Go drive something underpowered for a week. Link to comment Share on other sites More sharing options...
executor485 Posted May 20, 2009 Share Posted May 20, 2009 My first place to check would be the vacuum lines... Check the T under the intercooler, make sure the lines from the T are still hooked to their proper locations, and while your there, may as well ziptie them as well. I was lacking a LOT of get up and go when my hose popped, put it back on and the car was happy again If I pass you on the right, I'm flipping you off. Link to comment Share on other sites More sharing options...
BLKGT5 Posted May 20, 2009 Share Posted May 20, 2009 Most likely a boost leak, check piping clamps and vacuum lines, then check IC for end tank separation. Link to comment Share on other sites More sharing options...
Beanboy Posted May 20, 2009 Share Posted May 20, 2009 temps climbing? -B http://www.standardshift.com Link to comment Share on other sites More sharing options...
ehsnils Posted May 20, 2009 Share Posted May 20, 2009 Oil consumption? Bad turbo? Link to comment Share on other sites More sharing options...
DarkLegacy Posted May 20, 2009 Share Posted May 20, 2009 Check your TB hose... Link to comment Share on other sites More sharing options...
sschmelcke Posted May 20, 2009 Share Posted May 20, 2009 def temps climbing. my car feels so slow now that its around 80. which is why i am getting protuned tomorrow Link to comment Share on other sites More sharing options...
Val Demar Posted May 20, 2009 Share Posted May 20, 2009 It seems on some days my car is less responsive than on others. Been wondering for a while if it is all in my head or a result of different temperature, atmospheric pressure, fuel, engine problems, etc. Link to comment Share on other sites More sharing options...
snow05gtRI Posted May 21, 2009 Share Posted May 21, 2009 temperature and humidity can be the bane of our car's existence. however, take a few logs using your AP to see if everything is still running proper. Link to comment Share on other sites More sharing options...
Jerboa113 Posted May 21, 2009 Share Posted May 21, 2009 oh yea on a hot day my car is a DOG. when winter comes along it puts a huge smile on my face when I get on it. "The penalty good men pay for indifference to public affairs is to be ruled by evil men." - Plato Link to comment Share on other sites More sharing options...
Val Demar Posted May 21, 2009 Share Posted May 21, 2009 ...take a few logs using your AP Bummer, I forgot to check if dealer included it when I acquired my car, now can't find it. Do you think SOA can send one for free if I call them up? Link to comment Share on other sites More sharing options...
snow05gtRI Posted May 21, 2009 Share Posted May 21, 2009 haha...you confused me for a minute there... that was directed to the original poster, raloi, since he stated he was Cobb Stage 1 Link to comment Share on other sites More sharing options...
mightyS Posted May 21, 2009 Share Posted May 21, 2009 Use your Cobb AP to see what boost you are making. Mine could hit 15.4 at stage 1. That will let you know if you have leaks. I've noticed the car computer learns to accelerate slower over time. Normally I don't push the car hard unless I am at a track. I have to punch it and take it to 6500-7000 rpm. Then it is incredibly fast again. Link to comment Share on other sites More sharing options...
snow05gtRI Posted May 21, 2009 Share Posted May 21, 2009 Use your Cobb AP to see what boost you are making. Mine could hit 15.4 at stage 1. That will let you know if you have leaks. I've noticed the car computer learns to accelerate slower over time. Normally I don't push the car hard unless I am at a track. I have to punch it and take it to 6500-7000 rpm. Then it is incredibly fast again. yeah, i've actually felt that my car is more peppy after resetting the ECU....but then again it could be because it hasn't learned to pull timing in certain spots yet to slow it down...if that even happens. Link to comment Share on other sites More sharing options...
j255c Posted May 21, 2009 Share Posted May 21, 2009 Temps rising and you're used to it. I think my car feels slow now, its not cool. Only thing that reminds me is how my brakes are completely inadequate at speeds. 06 TB EVO IX SE stock turbo monster subaru hater Link to comment Share on other sites More sharing options...
Val Demar Posted May 21, 2009 Share Posted May 21, 2009 I've noticed the car computer learns to accelerate slower over time. Normally I don't push the car hard unless I am at a track. I have to punch it and take it to 6500-7000 rpm. Then it is incredibly fast again. Yup, I forgot about it. Once I push my car around one day it will feel much sportier the next day or 2. I guess newer models have a sort of manual ECU overdrive in the form of SI-drive. Link to comment Share on other sites More sharing options...
Noeladams Posted May 21, 2009 Share Posted May 21, 2009 I think you need your butt dyno recalibrated. You are probably just used to your car now. Go drive something underpowered for a week. lol, go rent a civic for a day Link to comment Share on other sites More sharing options...
Jerboa113 Posted May 21, 2009 Share Posted May 21, 2009 just get a 2.5i loaner. "The penalty good men pay for indifference to public affairs is to be ruled by evil men." - Plato Link to comment Share on other sites More sharing options...
Noeladams Posted May 21, 2009 Share Posted May 21, 2009 just get a 2.5i loaner. my wife has a 06 2.5i lol. can you say night / day lol. Although it has a quick response just lacks the umph that my 05 gt has. Link to comment Share on other sites More sharing options...
sschmelcke Posted May 21, 2009 Share Posted May 21, 2009 just get a 2.5i loaner. great idea actually. i drive my wifes 2.5i and the hop into mine. feels like going from a honda to a vette Link to comment Share on other sites More sharing options...
sschmelcke Posted May 21, 2009 Share Posted May 21, 2009 my wife has a 06 2.5i lol. can you say night / day lol. Although it has a quick response just lacks the umph that my 05 gt has. yeah off the line from about 0-3 mph i think she can take me. Link to comment Share on other sites More sharing options...
Jerboa113 Posted May 21, 2009 Share Posted May 21, 2009 I had an outback 2.5i for 2 days. When I got back in my car I found it was like going from sittingin a beanbag chair.. to sitting in a chair made of rock. Everything was more solid.. handling, stopping steering, suspension stifness.. about the only thing that was the same was the dash between the 2. "The penalty good men pay for indifference to public affairs is to be ruled by evil men." - Plato Link to comment Share on other sites More sharing options...
Brad023 Posted May 21, 2009 Share Posted May 21, 2009 i was used to my car until i pulled my motor and drove a 98 eclipe arround for 3 weeks now my lgt feels insane. Link to comment Share on other sites More sharing options...
