LegacyLexTek Posted April 3, 2009 Share Posted April 3, 2009 so i installed my gimmick racing ewg today. was wondering if anyone has done this install. i went for a ride i usually hit 20 lbs of boost. i was hitting 25 lbs. also was wondering if anyone has had any issues if you tighten the bracket to hold the stock internal closed if you tighten it to much the metal ring around the door shatters and you have metal pieces in the exhaust. anyways if you want to do this intall call josh at importimageracing.com he is great, the sound is great, the fit is great, and the parts are sick. Link to comment Share on other sites More sharing options...
GTTuner Posted April 3, 2009 Share Posted April 3, 2009 You may need your WGDC tables tweaked for that. Recirc or dumped? Link to comment Share on other sites More sharing options...
LegacyLexTek Posted April 3, 2009 Author Share Posted April 3, 2009 dumped. Link to comment Share on other sites More sharing options...
itsme Posted April 3, 2009 Share Posted April 3, 2009 I have no problem with the ring. Racer X FMIC for '05-'09 LGTs, '08+ WRX and '10+ LGT,'14+ FXT, and '15+ WRX TMIC Racerxengineering.com Link to comment Share on other sites More sharing options...
j255c Posted April 3, 2009 Share Posted April 3, 2009 25psi on what turbo what gas 06 TB EVO IX SE stock turbo monster subaru hater Link to comment Share on other sites More sharing options...
LegacyLexTek Posted April 6, 2009 Author Share Posted April 6, 2009 ok so the kid that installed my ewg screwed it up and i had to fix it the other day, last time anyone touches my car but me. the noise was the internal flapper not being closed tight, he had the vacuum line off the turbo so i was spiking to high boost levels. i run 93 octane i fixed the car now i am at 16 psi and i just ordered the new springs for the wastegate, to get back to 20 psi, this post is now garbage Link to comment Share on other sites More sharing options...
itsme Posted April 6, 2009 Share Posted April 6, 2009 Why are you getting a new spring for you IWG. Just make a tab to hold IWG shut. I made one myself. Which EWG are you using? I went with the Synapse Synchronic EWG and I have it run back into the exhaust. I don't have the I remove IWG diaphram. http://i167.photobucket.com/albums/u156/itsmebryan/153356.jpg http://i167.photobucket.com/albums/u156/itsmebryan/153603.jpg Racer X FMIC for '05-'09 LGTs, '08+ WRX and '10+ LGT,'14+ FXT, and '15+ WRX TMIC Racerxengineering.com Link to comment Share on other sites More sharing options...
korpsepatrol Posted April 6, 2009 Share Posted April 6, 2009 Is this on a stock turbo? 2008 6mt Legacy Gt Spec B DGM - Not so Stock/Work in progress 2006 5mt Legacy Gt OBP - Sold 2005 5eat Legacy Gt OBP - RIP R.I.P Coxx Link to comment Share on other sites More sharing options...
itsme Posted April 6, 2009 Share Posted April 6, 2009 no it's a 20g 2.4 inlet 7cm hotside Racer X FMIC for '05-'09 LGTs, '08+ WRX and '10+ LGT,'14+ FXT, and '15+ WRX TMIC Racerxengineering.com Link to comment Share on other sites More sharing options...
korpsepatrol Posted April 6, 2009 Share Posted April 6, 2009 Oh i thought he was running it on a stock turbo... 2008 6mt Legacy Gt Spec B DGM - Not so Stock/Work in progress 2006 5mt Legacy Gt OBP - Sold 2005 5eat Legacy Gt OBP - RIP R.I.P Coxx Link to comment Share on other sites More sharing options...
itsme Posted April 6, 2009 Share Posted April 6, 2009 Oh i thought he was running it on a stock turbo... My bad I thought you were talking to me. I don't think the OP has a stock turbo because I have never heard of a stock turbo push that much boost. Mine bearly hit 18.5 with a fmic Racer X FMIC for '05-'09 LGTs, '08+ WRX and '10+ LGT,'14+ FXT, and '15+ WRX TMIC Racerxengineering.com Link to comment Share on other sites More sharing options...
snow05gtRI Posted April 8, 2009 Share Posted April 8, 2009 whats the difference between dumping the EWG under the car or dumping it into the DP? I know into the DP will probably be quieter...but is there anything else? Link to comment Share on other sites More sharing options...
itsme Posted April 8, 2009 Share Posted April 8, 2009 just quiter is all I know. Racer X FMIC for '05-'09 LGTs, '08+ WRX and '10+ LGT,'14+ FXT, and '15+ WRX TMIC Racerxengineering.com Link to comment Share on other sites More sharing options...
LegacyLexTek Posted April 8, 2009 Author Share Posted April 8, 2009 if you dump, it makes guys with V8's tweek out when you blow by them. i had a kid in a mustang follow me to a gas station to ask me what the hell that noise was Link to comment Share on other sites More sharing options...
lethal.adv Posted April 8, 2009 Share Posted April 8, 2009 do you have an aftermarket mbc or bcs? Also, did you have the car tuned after the install? Link to comment Share on other sites More sharing options...
itsme Posted April 8, 2009 Share Posted April 8, 2009 do you have an aftermarket mbc or bcs? Also, did you have the car tuned after the install? Prodrive EBCS and yes had the car tuned. I brought the wastegate duty cycles way down. Now I'm peaking at @20.5psi 3400 rpms and tapper to 20 psi at 7000k on 91 cali pump gas. Racer X FMIC for '05-'09 LGTs, '08+ WRX and '10+ LGT,'14+ FXT, and '15+ WRX TMIC Racerxengineering.com Link to comment Share on other sites More sharing options...
PSZCZ.lgt Posted April 8, 2009 Share Posted April 8, 2009 i wanna hear it!!! Link to comment Share on other sites More sharing options...
lethal.adv Posted April 8, 2009 Share Posted April 8, 2009 Prodrive EBCS and yes had the car tuned. I brought the wastegate duty cycles way down. Now I'm peaking at @20.5psi 3400 rpms and tapper to 20 psi at 7000k on 91 cali pump gas. I was actually asking the Original Poster since he's having some issues. Congrats though :edit: nvm I think he resolved it Link to comment Share on other sites More sharing options...
frkkevin Posted April 9, 2009 Share Posted April 9, 2009 i wanna hear it!!! No launch.. you can hear it as I drive by.. after the cam is at the back of my car all you hear is exhaust.. I could make a vid of it tho MVI_0973.flv video by frkkevin - Photobucket@@AMEPARAM@@http://vid535.photobucket.com/player.swf?file=http://vid535.photobucket.com/albums/ee359/frkkevin/MVI_0973.flv@@AMEPARAM@@vid535@@AMEPARAM@@535@@AMEPARAM@@ee359/frkkevin/MVI_0973 512whp/465ftlb 2005 5EAT Legacy (Build Log) Videos - - Link to comment Share on other sites More sharing options...
a.lim Posted May 11, 2009 Share Posted May 11, 2009 ^ do you have it plumbed back down your down pipe or is that dumped outside? I'm wondering how much horsepower it yields when you plumb it back down the downpipe. Link to comment Share on other sites More sharing options...
frkkevin Posted May 11, 2009 Share Posted May 11, 2009 its not plumbed back in 512whp/465ftlb 2005 5EAT Legacy (Build Log) Videos - - Link to comment Share on other sites More sharing options...
a.lim Posted May 12, 2009 Share Posted May 12, 2009 your ewg is barely noticeable. any more videos? Link to comment Share on other sites More sharing options...
NSFW Posted May 13, 2009 Share Posted May 13, 2009 I'm guessing it sounds like straight pipe with no muffler, because that's basically what it is. Am I right? Link to comment Share on other sites More sharing options...
