f85stealth Posted February 10, 2009 Share Posted February 10, 2009 I need to get a new clutch so I can have my car protuned among the obvious reasons for replacing a clutch. I know the information is out there and I have been searching for the past hour and cant seem to find what I need. Maybe someone can help that knows off the top of their head. What is the weight of the stock 06 legacy gt clutch and flywheel? I would also like to find out the weight of the 06 wrx flywheel. I am trying to find a stage two setup clutch but keep the factory weight, I want no vibration or clutch chatter then I would experience with an oem one. I am not looking to save weight just looking to hold more power. I am considering ACT, Spec, competition clutch, and exedy right now. Link to comment Share on other sites More sharing options...
kevkel33leg05 Posted February 10, 2009 Share Posted February 10, 2009 For the GT the stock flywheel is 23pounds. I have a spec stage2+ clutch and spec LWF(14pounds). I love the setup and it has seen a bunch of track use. The chatter has gotten much quieter now that i have just about 19K on it but in the beginning it was bad the g/f hated it. Most of the aftermarket clutches will produce chatter anyways. I'm not sure of the wrx flywheel weight but its just a little bit lighter then the LGT flywheel also its a single mass flywheel. Link to comment Share on other sites More sharing options...
f85stealth Posted February 10, 2009 Author Share Posted February 10, 2009 For the GT the stock flywheel is 23pounds. I have a spec stage2+ clutch and spec LWF(14pounds). I love the setup and it has seen a bunch of track use. The chatter has gotten much quieter now that i have just about 19K on it but in the beginning it was bad the g/f hated it. Most of the aftermarket clutches will produce chatter anyways. I'm not sure of the wrx flywheel weight but its just a little bit lighter then the LGT flywheel also its a single mass flywheel. Thanks for the info. I am still not sure the benefit of having dual mass versus single. Link to comment Share on other sites More sharing options...
Guest Posted February 10, 2009 Share Posted February 10, 2009 07+ stock fly is NO LONGER dual mass. 05-06 is and weighs ~ 28 lbs. I believe. Link to comment Share on other sites More sharing options...
JoeFromPA Posted February 10, 2009 Share Posted February 10, 2009 Whoa....unclemat? The 07/08 Stock flywheel is no longer dual-mass? How did I miss that? Link to comment Share on other sites More sharing options...
Guest Posted February 10, 2009 Share Posted February 10, 2009 Whoa....unclemat? The 07/08 Stock flywheel is no longer dual-mass? How did I miss that? Because you read and blindly believe what forum people post Link to comment Share on other sites More sharing options...
FASTONE Posted February 10, 2009 Share Posted February 10, 2009 The dual mass systems are designed to transmit less engine vibration to the driveline, and give a better more car like driving experience. They also reduce some of the jarring and stress on the transmission and remainder of the drivetrain. They work fine as long as the engine remains unmodified and the vehicle is not used/abused beyond manufacturers recommendations. The single mass part WILL tend to transmit more engine pulse (vibration) tot he drivetrain, and will seem a bit rougher. But it is straight forward to design a single mass flywheel and clutch package for pretty much any engine torque curve and vehicle loading combo you can come up with. Drives more like a TRUCK, but has much better reliability at extreme use levels. Link to comment Share on other sites More sharing options...
FASTONE Posted February 10, 2009 Share Posted February 10, 2009 i got this: http://legacygt.com/forums/showthread.php?t=55859 and i am very happy Link to comment Share on other sites More sharing options...
JoeFromPA Posted February 10, 2009 Share Posted February 10, 2009 That would explain why my 08 drives like a truck compared to the 05 I test drove years back Link to comment Share on other sites More sharing options...
kevkel33leg05 Posted February 11, 2009 Share Posted February 11, 2009 sorry for the miss information above... Link to comment Share on other sites More sharing options...
f85stealth Posted February 11, 2009 Author Share Posted February 11, 2009 Well it doesn't look like anyone makes an aftermarket dual mass that can hold any more power then stock. So it seems I am looking for the heaviest flywheel clutch combo to keep the noise and chatter down. ACT, Exedy, and spec make options for our vehicles......I am tempted by the Exedy Link to comment Share on other sites More sharing options...
kevkel33leg05 Posted February 11, 2009 Share Posted February 11, 2009 spec clutches will work with the stock dual mass flywheel. Link to comment Share on other sites More sharing options...
Leg Man Posted February 11, 2009 Share Posted February 11, 2009 I have a newb question, an STI makes more power than a legacy, is there any chance that an STI clutch would fit? I don't hear STI's with clutch chatter. Link to comment Share on other sites More sharing options...
Guest Posted February 15, 2009 Share Posted February 15, 2009 That would explain why my 08 drives like a truck compared to the 05 I test drove years back Diesel trucks usually have dual-mass flywheels... Link to comment Share on other sites More sharing options...
rtbrjason Posted February 15, 2009 Share Posted February 15, 2009 I have a newb question, an STI makes more power than a legacy, is there any chance that an STI clutch would fit? I don't hear STI's with clutch chatter. See post 14 here: http://www.legacygt.com/forums/showthread.php?t=94537 Link to comment Share on other sites More sharing options...
LittleBlueGT Posted February 16, 2009 Share Posted February 16, 2009 So is the PP the same on the 07+ lgts? In-other-words, is the 05-06 DMF the same dimensionally as the 07+ fly? Full tune of 68HTA, KSTech 73 MAF, Racer X FMIC and ID1000s................by the DataLog Mafia!!! Link to comment Share on other sites More sharing options...
Guest Posted February 16, 2009 Share Posted February 16, 2009 So is the PP the same on the 07+ lgts? In-other-words, is the 05-06 DMF the same dimensionally as the 07+ fly? Part numbers for disc/pressure plate also changed, so I don't know if they are the same dimensionally. Check if same Spec aftermarket clutch fits all 05-09 years. Link to comment Share on other sites More sharing options...
Guest Posted February 16, 2009 Share Posted February 16, 2009 Actually 07+ LGT fly is same as........... <drum roll>............ 06+ WRX (also same on 08 WRX). Link to comment Share on other sites More sharing options...
kevkel33leg05 Posted February 16, 2009 Share Posted February 16, 2009 I looked on specs website and their clutches only go up to 07 models. But the part numbers are the same for a 05 06 and 07. So are you sure the the flywheel wasn’t changed over in 08+ models? Or is the 07 legacy stock flywheel part number the same as a 06 wrx stock flywheel part number? Link to comment Share on other sites More sharing options...
f85stealth Posted February 16, 2009 Author Share Posted February 16, 2009 That brings up a good question couldn't we use a stock 05 STI clutch, since they were 5 speed? It holds the power most of us stage 2 guys are at... Bullyclutch in canada also makes an aftermarket dual mass clutch that supposed to be pretty good with close to 400tq ratings.... im seriosuly considering that over ACT I like the sound of designed for the legacy better then this wrx conversion stuff..... I wish I knew someone who had one... Link to comment Share on other sites More sharing options...
JoeFromPA Posted February 16, 2009 Share Posted February 16, 2009 Diesel trucks usually have dual-mass flywheels... Did I say it drives like a diesel truck? NO! Link to comment Share on other sites More sharing options...
LittleBlueGT Posted February 16, 2009 Share Posted February 16, 2009 That brings up a good question couldn't we use a stock 05 STI clutch, since they were 5 speed? It holds the power most of us stage 2 guys are at... Bullyclutch in canada also makes an aftermarket dual mass clutch that supposed to be pretty good with close to 400tq ratings.... im seriosuly considering that over ACT I like the sound of designed for the legacy better then this wrx conversion stuff..... I wish I knew someone who had one... The ACT is a "WRX conversion", but apparently Subaru did that conversion as well in 07. Full tune of 68HTA, KSTech 73 MAF, Racer X FMIC and ID1000s................by the DataLog Mafia!!! Link to comment Share on other sites More sharing options...
Guest Posted February 16, 2009 Share Posted February 16, 2009 That brings up a good question couldn't we use a stock 05 STI clutch, since they were 5 speed? It holds the power most of us stage 2 guys are at... No USDM STI was ever 5-speed!!! Link to comment Share on other sites More sharing options...
kevkel33leg05 Posted February 16, 2009 Share Posted February 16, 2009 That brings up a good question couldn't we use a stock 05 STI clutch, since they were 5 speed? It holds the power most of us stage 2 guys are at... Bullyclutch in canada also makes an aftermarket dual mass clutch that supposed to be pretty good with close to 400tq ratings.... im seriosuly considering that over ACT I like the sound of designed for the legacy better then this wrx conversion stuff..... I wish I knew someone who had one... 04+ sti's are 6 speed. So if your 5 speed you cant use sti stock clutch and flywheel. I think bully clutch makes a clutch that works with the stock "dual mass" flywheel. I've just never heard of a "dual mass clutch" And just like it’s been said the 06 wrx flywheel is now in the LGT. So its not to much a “wrx swap” anymore. And everyone seems to like that set up with the act clutch. and one more recap you can use spec clutch with stock dual mass flywheel. People also have good things to say about spec clutches and thier LWF...me being one of them. Link to comment Share on other sites More sharing options...
JoeFromPA Posted February 16, 2009 Share Posted February 16, 2009 So now my question is: When my 2008 clutch wears out, can I have my (apparently single mass) flywheel re-surfaced and just install an ACT HD clutch that would pair with an 06+ SM WRX Flywheel? If so, this means that when my clutch goes out it's going to cost alot less to replace, because I can re-use the stock flywheel. Joe Link to comment Share on other sites More sharing options...
