cfdrumr Posted January 19, 2009 Share Posted January 19, 2009 Here are my first logs for stage 1. The 2nd gear logs are 2k-redline The 3rd gear logs are only up to 5k or so because of traffic. I see a lot of knock correction but ill let you guys tell me... http://www.box.net/shared/ay6kidz77z Link to comment Share on other sites More sharing options...
cfdrumr Posted January 19, 2009 Author Share Posted January 19, 2009 anyone? not even 1 view! INFAMOUS1....HELP! haha Link to comment Share on other sites More sharing options...
Bolksey85 Posted January 19, 2009 Share Posted January 19, 2009 1, you're logging too much stuff. 2, your IAM isn't at 1 yet. 3, the knock correction is positive which isn't a bad thing, IIRC. Link to comment Share on other sites More sharing options...
cfdrumr Posted January 19, 2009 Author Share Posted January 19, 2009 thanks Im going to go out to dinner and maybe when i come back i will get 2.8 million replies...MAYBE Link to comment Share on other sites More sharing options...
Bolksey85 Posted January 19, 2009 Share Posted January 19, 2009 Find an empty stretch and give it one hard run to redline in 3rd and that should set the IAM to 1. If not, try and cruise at 30-50% and maybe another redline run before you log. Link to comment Share on other sites More sharing options...
cfdrumr Posted January 19, 2009 Author Share Posted January 19, 2009 im really lost...iam? Link to comment Share on other sites More sharing options...
Bolksey85 Posted January 19, 2009 Share Posted January 19, 2009 A lot if not all is explained in here:http://www.cobbtuning.com/info/?ID=3487 Link to comment Share on other sites More sharing options...
boostsr20 Posted January 19, 2009 Share Posted January 19, 2009 Your IAM needs to reach 1 before you start logging. Yours is at .575 so its not running the full timing on the map among other things. Link to comment Share on other sites More sharing options...
cfdrumr Posted January 19, 2009 Author Share Posted January 19, 2009 so i just need to drive more and harder for it to reach 1? Link to comment Share on other sites More sharing options...
boostsr20 Posted January 19, 2009 Share Posted January 19, 2009 Yes, usually a couple boost cycles gets it there. Link to comment Share on other sites More sharing options...
cfdrumr Posted January 19, 2009 Author Share Posted January 19, 2009 and is this every time i turn on the car or every time i flash the ECU? Link to comment Share on other sites More sharing options...
Bolksey85 Posted January 19, 2009 Share Posted January 19, 2009 Whenever the ECU is reflashed. Once it gets to 1.0, it shouldn't move unless a good amount of knock is detected. Link to comment Share on other sites More sharing options...
cfdrumr Posted January 19, 2009 Author Share Posted January 19, 2009 ill go drive it hard and get some more logs up later...so far do the logs look ok? Link to comment Share on other sites More sharing options...
enthusiast Posted January 19, 2009 Share Posted January 19, 2009 ill go drive it hard and get some more logs up later...so far do the logs look ok? Umm you should make sure your car is not doing bad things first. Get learning view installed and running on your laptop.Get the right parameters to log. If you read the posts on romraider and this very sight you will get an idea on what to log. Some you might try are:Engine Load (4-Byte)* (g/rev)Engine Speed (rpm)Ignition Total Timing (degrees)Knock Sum* (count)Manifold Relative Pressure (psi)Primary Wastegate Duty Cycle (%)Requested Torque* (raw ecu value)Turbo Dynamics Integral (2-byte)** (absolute %) [*]I would do some 2K-4K runs do a learning view after and post the logs and the learning view. [*]Then if everything is ok then do some WOT runs. IAM will not necessarily go to 1 if you have a lot of knock or other things. I usually just "drive" (normal) my car until it fully warmed up then check it (IAM). My mod list Link to comment Share on other sites More sharing options...
cfdrumr Posted January 19, 2009 Author Share Posted January 19, 2009 I just picked the parameters that I saw other ppl logging. Shall I add those to the ones I already logged? Link to comment Share on other sites More sharing options...
itsme Posted January 19, 2009 Share Posted January 19, 2009 call me on my cell I'm help infamous put on a turbo Racer X FMIC for '05-'09 LGTs, '08+ WRX and '10+ LGT,'14+ FXT, and '15+ WRX TMIC Racerxengineering.com Link to comment Share on other sites More sharing options...
enthusiast Posted January 19, 2009 Share Posted January 19, 2009 No throw out the others and use these. Seriously you really do not need to log things you can just check once like: IAM, ATM pressure, Intake air temperature, etc. Vehicle speed is worthless. Ignition total timing, MRP corrected, mass airflow can be added to the list I gave you above. The less you log the better resolution you get. My mod list Link to comment Share on other sites More sharing options...
cfdrumr Posted January 19, 2009 Author Share Posted January 19, 2009 call me on my cell I'm help infamous put on a turbo bryan...what r u talking about? Link to comment Share on other sites More sharing options...
cfdrumr Posted January 19, 2009 Author Share Posted January 19, 2009 not to sound demanding...what exactly needs to be logged? I want to make sure its a good tune on my car! haha Link to comment Share on other sites More sharing options...
itsme Posted January 19, 2009 Share Posted January 19, 2009 you said you needed help from infamous and I'm with infamous helping him install his new turbo Racer X FMIC for '05-'09 LGTs, '08+ WRX and '10+ LGT,'14+ FXT, and '15+ WRX TMIC Racerxengineering.com Link to comment Share on other sites More sharing options...
cfdrumr Posted January 19, 2009 Author Share Posted January 19, 2009 OH...how is that going? i lost your cell number when i got my new phone! :o PM it to me...Are you busy tmrw? I still need to get that UP done...i know everyone says im crazy but im going to wait on the DP... Link to comment Share on other sites More sharing options...
itsme Posted January 19, 2009 Share Posted January 19, 2009 pm sent Racer X FMIC for '05-'09 LGTs, '08+ WRX and '10+ LGT,'14+ FXT, and '15+ WRX TMIC Racerxengineering.com Link to comment Share on other sites More sharing options...
cfdrumr Posted January 19, 2009 Author Share Posted January 19, 2009 your the guy bryan! Link to comment Share on other sites More sharing options...
Infamous1 Posted January 19, 2009 Share Posted January 19, 2009 Your car is pulling a lot of timing. It is not the fact that the IAM is not 1 yet. The car did actually get to 1 at some point then it started pulling timing back due to knock. From what I have seen this map simply may be too aggressive for CA91. I cannot get anywhere near the midrange timing numbers on stg 1 cars I have road tuned. You also could have something not mechanically sound with your car. Reset the ecu, let the car warm up then do a few hard throttle burst. Once you have confirmed the IAM is at 1 then began logging the following: Engine Speed (rpm) Engine Load (Direct)* (g/rev) Ignition Timing (degrees) Knock Sum Manifold Rel. Pressure (4-byte) (psi) Mass Air Flow (g/s) Primary Wastegate Duty Cycle (%) Throttle Opening Angle (%) Also post your current mods list as well. Link to comment Share on other sites More sharing options...
cfdrumr Posted January 19, 2009 Author Share Posted January 19, 2009 shamar...do you have less aggresive base map i should try? Link to comment Share on other sites More sharing options...
