ignisfts Posted January 6, 2009 Share Posted January 6, 2009 I need to tow my LGT on a dolly with the rear wheels on the ground and front wheels on dolly. The distance is roughly 1 mile. I want to make sure that nothing gets damaged, so what would I need to disconnect in the rear end to make sure it's 100% OK? edit: it's 5MT Link to comment Share on other sites More sharing options...
rao Posted January 6, 2009 Share Posted January 6, 2009 You really shouldn't do that. If you must then disconnect the rear drive shaft, which requires removal of the cat back exhaust and the heat shield. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
vr4Legacy Posted January 6, 2009 Share Posted January 6, 2009 I believe the manual actually states if you need to tow it a short distance you should tow it with all four wheels on the ground. Maybe it would be easier to remove the tow bolt cover and use that and a chain.... you could sit in the car and steer and brake, if it runs using foot brake, if not e-brake should work for a 1 mile trip. I've done this with a few cars I've had... granted they were POS's... but it has worked. (I was less concerned about drivetrain damage, and more trying to save a buck ) Link to comment Share on other sites More sharing options...
ignisfts Posted January 6, 2009 Author Share Posted January 6, 2009 I believe the manual actually states if you need to tow it a short distance you should tow it with all four wheels on the ground. Maybe it would be easier to remove the tow bolt cover and use that and a chain.... you could sit in the car and steer and brake, if it runs using foot brake, if not e-brake should work for a 1 mile trip. I've done this with a few cars I've had... granted they were POS's... but it has worked. (I was less concerned about drivetrain damage, and more trying to save a buck ) Yea, that's exactly what Subaru has to say about towing a manual car: http://www.subaru.com/owners/carcaretips/index.jsp?pageid=towing&navid=TOWING_A_SUBARU I'm just trying to save a buck or two Hopefully disconnecting the drive shaft wont take too much time. I am not sure if towing with a chain is legal/allowed since my car is not registered. Link to comment Share on other sites More sharing options...
987687 Posted January 6, 2009 Share Posted January 6, 2009 You are only going a mile, who cares if it's legal or not. Just make sure there are no cops in that mile stretch of road... Link to comment Share on other sites More sharing options...
Impulse Posted January 6, 2009 Share Posted January 6, 2009 I believe the manual actually states if you need to tow it a short distance you should tow it with all four wheels on the ground. Maybe it would be easier to remove the tow bolt cover and use that and a chain.... you could sit in the car and steer and brake, if it runs using foot brake, if not e-brake should work for a 1 mile trip. I've done this with a few cars I've had... granted they were POS's... but it has worked. (I was less concerned about drivetrain damage, and more trying to save a buck ) if you do this, make sure you have the key in the ignition so the steering dosent lock... Link to comment Share on other sites More sharing options...
NatesGr8 Posted January 6, 2009 Share Posted January 6, 2009 Can you drive the car? i'd say drive it with no plates but be safe and have someone up ahead looking for cops. Link to comment Share on other sites More sharing options...
Grios2.5 Posted January 6, 2009 Share Posted January 6, 2009 Do not tow your vehicle on the dolly unless you plan on disconnecting the rear drive shafts Ive had a few people do this with their WRX's and STI's and bam blown Diff. and now we have to repair the diff. Flat bed it if you can. Link to comment Share on other sites More sharing options...
edkwon Posted January 7, 2009 Share Posted January 7, 2009 why dont you just tow with all 4 wheels on dollys, avoiding the problem entirely Link to comment Share on other sites More sharing options...
PeterJMC Posted January 7, 2009 Share Posted January 7, 2009 if you do this, make sure you have the key in the ignition so the steering dosent lock... Yes... Short Version [ame=http://www.youtube.com/watch?v=Wx-Pz042vyg&feature=channel]YouTube - WRX CRASH INTO WIRE POLE BEING TOWED SHORT VER[/ame] Long Version [ame=http://www.youtube.com/watch?v=nCbk_JZfAMw]YouTube - WRX CRASH WHILST BEING TOWED IN ST. LUCIA[/ame] Link to comment Share on other sites More sharing options...
Scooby Fan Posted January 7, 2009 Share Posted January 7, 2009 Can you drive the car? i'd say drive it with no plates but be safe and have someone up ahead looking for cops. Great advice...maybe rob a few corner stores along the way:eek: Link to comment Share on other sites More sharing options...
FrozenNorthLGT Posted January 7, 2009 Share Posted January 7, 2009 And, based on that video, make sure the tow vehicle driver has at least half a brain and knows where their rear view mirror is located. There is no reason that a competent driver wouldn't have immediatly noticed that. Link to comment Share on other sites More sharing options...
taskforcefreddy Posted January 7, 2009 Share Posted January 7, 2009 Call a local tow company and throw $50 at them to tow you with a 4 wheel dolly setup. Link to comment Share on other sites More sharing options...
Vi3tguysoflyy91 Posted January 7, 2009 Share Posted January 7, 2009 i honestly don't think thats a good idea man =/ i think an extra buck can get you a good flatbed and avoid all that trouble to disconnect everything Link to comment Share on other sites More sharing options...
johnAWD Posted January 7, 2009 Share Posted January 7, 2009 If it were me, the car wouldn't move unless on a flatbed. Link to comment Share on other sites More sharing options...
wengermi Posted January 7, 2009 Share Posted January 7, 2009 if it was me and the car moves then i would drive the car with a person trailing behind me. if it doesn't run and its really just down the street then just get a couple of friends to push it. i've done that before. Link to comment Share on other sites More sharing options...
Backlash Posted January 7, 2009 Share Posted January 7, 2009 and, based on that video, make sure the tow vehicle driver has at least half a brain and knows where their rear view mirror is located. There is no reason that a competent driver wouldn't have immediatly noticed that. +100000000 Link to comment Share on other sites More sharing options...
Molal24 Posted January 7, 2009 Share Posted January 7, 2009 And, based on that video, make sure the tow vehicle driver has at least half a brain and knows where their rear view mirror is located. There is no reason that a competent driver wouldn't have immediatly noticed that. +1. I also don't see the need to go 50 through S's when you're towing a car. Link to comment Share on other sites More sharing options...
Penguin Posted January 7, 2009 Share Posted January 7, 2009 Get a flat bed trailer that you can get all 4 wheels off the ground. The time and hassle saved in not having to disengage the rear drive shaft then reengage it later will more than pay for the trailer rental. Link to comment Share on other sites More sharing options...
lvethesnow Posted January 7, 2009 Share Posted January 7, 2009 flat bed car trailer ftw. i used a penske one when i moved from ma to co. defintely worth the extra bucks. History does not entrust the care of freedom to the weak or timid People sleep peacefully at night cause rough men stand ready to do violence on there behalf Link to comment Share on other sites More sharing options...
987687 Posted January 7, 2009 Share Posted January 7, 2009 What sort of road do you have to tow it that is a mile? Through the city? Along a nice flat straight back road with no traffic on it? For me, if it was the city I'd have someone tow it professionally for me. Along a nice back road? I'd probably tow it SLOWLY and CAREFULLY with someone sitting in the towing car watching back to make sure nothing bad happened. Link to comment Share on other sites More sharing options...
vr4Legacy Posted January 7, 2009 Share Posted January 7, 2009 That's the thinking that will end up costing you a grand or two in repairing the damage No truer words have ever been spoken.... Link to comment Share on other sites More sharing options...
NatesGr8 Posted January 7, 2009 Share Posted January 7, 2009 Great advice...maybe rob a few corner stores along the way:eek: hey its the cheapest solution imo. he could also call the police himself and ask them to follow him, a mile isn't far at all, he could also get 5 buddies together and have them push it the mile. Link to comment Share on other sites More sharing options...
Jacks GT Posted January 8, 2009 Share Posted January 8, 2009 http://co104w.col104.mail.live.com/att/GetAttachment.aspx?tnail=11&messageId=4c983295-0ab7-490d-b5de-d2af23ea1e88&Aux=44%7C0%7C8CB38B5F607D0B0%7C Scuby on a trailer Link to comment Share on other sites More sharing options...
wengermi Posted January 8, 2009 Share Posted January 8, 2009 i just checked the rates online for you area for a uhaul car trailer (not a dolly) and its 50 bucks. if you have a friend with a full sized truck then this would be an affordable solution. Link to comment Share on other sites More sharing options...
