MDKSDMF Posted May 25, 2012 Share Posted May 25, 2012 id say so ^ mine just came in the mail from godspeed. heres pics of what to expect for anyone who is considering. no instructions, need to weld-a-flange. ALSO what flange adapter should i go with: the one HKS provided?(taller) or the godspeed flange (i dont like it too much and it sits almost flush) Link to comment Share on other sites More sharing options...
itsme Posted May 25, 2012 Author Share Posted May 25, 2012 I heard that godspeed started making the XO2 kit. Is that the 12" tall intercooler option? If so you will have to do alot more cutting the the 9" intercooler and maybe even some of the back of your grill. I have an already cut bumper beam if you are interested. Bryan Racer X FMIC for '05-'09 LGTs, '08+ WRX and '10+ LGT,'14+ FXT, and '15+ WRX TMIC Racerxengineering.com Link to comment Share on other sites More sharing options...
MDKSDMF Posted May 29, 2012 Share Posted May 29, 2012 The Core actually measured 10 and 1/4 inch. the inlet is 2.5 the vendor told me on the 12 inch core that the inlet is 3" sooo i can only assume the core pic i took is at a bad angle and that 10 and a 1/4" is the cheap version of 9" ooooo boy.........thank god GTTUNER is coming to help as he has installed quite a few of these Link to comment Share on other sites More sharing options...
MDKSDMF Posted June 7, 2012 Share Posted June 7, 2012 Two questions, can u get away with an avo tb hose? And today a welder told me he couldn't weld my hks flange because he thought the pipe was aluminum. Is he right? Link to comment Share on other sites More sharing options...
itsme Posted June 7, 2012 Author Share Posted June 7, 2012 Two questions, can u get away with an avo tb hose? And today a welder told me he couldn't weld my hks flange because he thought the pipe was aluminum. Is he right? I don't know what the AVO TB hose looks like. The tb is 2.75". The pipe should be aluminum. You just have to find someone that can weld it. Everyone doesn't. Racer X FMIC for '05-'09 LGTs, '08+ WRX and '10+ LGT,'14+ FXT, and '15+ WRX TMIC Racerxengineering.com Link to comment Share on other sites More sharing options...
MDKSDMF Posted June 7, 2012 Share Posted June 7, 2012 bwahahaha soo true. I might have to learn how to weld aluminum just cause the demand also thanks to a previous post i purchased the hump coupler to help my chances of reducing a boost leak or pop off! Link to comment Share on other sites More sharing options...
itsme Posted June 7, 2012 Author Share Posted June 7, 2012 bwahahaha soo true. I might have to learn how to weld aluminum just cause the demand also thanks to a previous post i purchased the hump coupler to help my chances of reducing a boost leak or pop off! if it is made like xo2 kit all the pipes are not beaded. The thing I did when I had the xo2 kit was use rough sandpaper to rough up the pipe ends to give the hose something to grip on. Some used hairspray to get hoses to hold. Racer X FMIC for '05-'09 LGTs, '08+ WRX and '10+ LGT,'14+ FXT, and '15+ WRX TMIC Racerxengineering.com Link to comment Share on other sites More sharing options...
MDKSDMF Posted June 7, 2012 Share Posted June 7, 2012 thankyou, i was thinking about doing just that as well as also having a bead welded on ends of the flange pipe as i know that one tends to pop under boost. sand paper and hairspray for sure on every connection. Link to comment Share on other sites More sharing options...
MDKSDMF Posted June 11, 2012 Share Posted June 11, 2012 installed the FMIC. definately get what you pay for. i ended up using my AVO hose in place of the hump cupler. It worked out great. I still have to notch out the bumber beam and touch up the bumper skin where i cut it. we did it at my friends body shop so we are probably gonna fiber glass in some fog covers since i cut them out. Everything held up under boost. It was tricky figuring out the routing of the piping. Also my core measured 10 1/4 tall not 9" as advertised. and the hks C clip was a pita but i got it to work wit snap ring pliers (angled work best) Link to comment Share on other sites More sharing options...
MDKSDMF Posted June 11, 2012 Share Posted June 11, 2012 http://i46.photobucket.com/albums/f145/rurouni_xgt/IMG_1210.jpg http://i46.photobucket.com/albums/f145/rurouni_xgt/IMG_1232.jpg when u cut out the lower fin on ur bumper did u mold in plastic to fill the void or did u just leave it? did it make the bumper more flimsy. im in the same boat whereas i want maximun air to hit the core. Link to comment Share on other sites More sharing options...
MDKSDMF Posted June 21, 2012 Share Posted June 21, 2012 also do most member weld their adapter into the tb pipe or do they weld on a 1 inch pipe and use a coupler to join the flanges...that way u can change around flanges and BOVs Link to comment Share on other sites More sharing options...
BuiltLGT Posted June 24, 2012 Share Posted June 24, 2012 Does anyone know the max PSI this FMiC is able to run ? I'm wanting to run 20-22 on pump 93 oct .i thought i read before it was 30psi but just wondering .. Link to comment Share on other sites More sharing options...
MDKSDMF Posted June 24, 2012 Share Posted June 24, 2012 im running a solid 15 right now, i figure it will hold 18 to 20 psi thru redline easily when tuned. supporting fuel mods are a must to hold 20 on a 16g. i wouldnt boost higher than 18 maybe 19 on a vf40/46 IMO Link to comment Share on other sites More sharing options...
imblaze89 Posted January 25, 2013 Share Posted January 25, 2013 so where do you buy these kits for cheap? Link to comment Share on other sites More sharing options...
imblaze89 Posted January 30, 2013 Share Posted January 30, 2013 are these kits still available? cant even find a website for X02 Link to comment Share on other sites More sharing options...
MDKSDMF Posted February 2, 2013 Share Posted February 2, 2013 Ya man it's an eBay kit.. Sorry I haven't been on here in a while but I drive a ram truck now! I sold/gave my gt to my girlfriend so it is still going strong. You should b able to fit an Godspeed or x02 fmic out there Link to comment Share on other sites More sharing options...
wurkenman Posted February 8, 2013 Share Posted February 8, 2013 Here is a link to the one I installed on my car. http://legacygt.com/forums/showthread.php/legacy-gt-bl9-ebay-bolt-fmic-191657.html?t=191657 If you want to do this kit, be prepared to invest in some shop tools or get to be good friends with someone who has some. That being said, I would do it again for the money. Holding 20PSI no problem. If you woke up today, you have another chance to do it right. Link to comment Share on other sites More sharing options...
imblaze89 Posted February 16, 2013 Share Posted February 16, 2013 ok im looking at the passenger side just below where the bumper beam mounts there is like a pice of pipe or something sticking out a couple inches and is welded to the frame.. Did this get in your way at all it seems like it is pushing my hot side pipe out to far.. What is the purpose of the little tube did you remove it? Link to comment Share on other sites More sharing options...
wurkenman Posted February 16, 2013 Share Posted February 16, 2013 That is for your tow hook to thread in to. It did not get in my way at all. If you woke up today, you have another chance to do it right. Link to comment Share on other sites More sharing options...
wpgspecb Posted April 8, 2013 Share Posted April 8, 2013 Ya man it's an eBay kit.. Sorry I haven't been on here in a while but I drive a ram truck now! I sold/gave my gt to my girlfriend so it is still going strong. You should b able to fit an Godspeed or x02 fmic out there BROTHER FROM ANOTHER MOTHER!!!!!!!! DUDE.. SAME BOAT. have a 2005 Dodge Ram 3500 work truck with fuel card... sold Specb to my brother.. Link to comment Share on other sites More sharing options...
MDKSDMF Posted November 30, 2014 Share Posted November 30, 2014 ya mine held 20 psi all day. never popped a coupler. id buy the kit all day. but i was a subaru tech and have a associates in automotive tech from UTI so i can wrench and my buddies all mod and race so we have air tools and lifts. its not like installing a short ram lol! but with patience and some pictures from others it fits well and works great. i like the newer racer x and some others tho Link to comment Share on other sites More sharing options...
Anthony I Posted April 10, 2017 Share Posted April 10, 2017 Does anyone have a link for this kit can't seem to find it Link to comment Share on other sites More sharing options...
