lepich Posted October 30, 2008 Share Posted October 30, 2008 Have a strange problem: while driving slowly, there is a noise from the rear, sounds exactly like a brake noise. However, when I brake just a little, noise is gone. Looks like rear pads (Bobcat) are touching rotor.. And there is no springs on a rear pads that suppose to push pads back (like on fronts) when you release a brake. Anyone had this issue? How rear pads can not to touch rotor, if no spring? Have to clue. Checked everything, applied new grease.. does not work. BTW, pads are good, replaced 15k miles ago. quiet while braking. There are no bad people, just differeent. Link to comment Share on other sites More sharing options...
lepich Posted October 31, 2008 Author Share Posted October 31, 2008 Bumpy There are no bad people, just differeent. Link to comment Share on other sites More sharing options...
Max Capacity Posted October 31, 2008 Share Posted October 31, 2008 Have you tried bedding in the brakes ? If all is fine like you say, try this. Get the car up to 55mph or so, stand on the brakes to the point of ABS kicking in but do not stop the car only slow to about 10mph, do that 4 or 5 times with in a 1/2 mile. Then drive for couple of miles to let the brakes cool. See if that helps. Could be you just have dust built up on the pads. BTW I just did this after a put new OEM rear disc on and new rear ceramic pads. It stopped the shimmy from the front brakes during normal braking. The brakes feel better then they have in a long time. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
lepich Posted November 3, 2008 Author Share Posted November 3, 2008 Thanks, I'll try that. I doubt it will work, as my problem start appearing after several hard braking: I was datalogging, which involves relatively hard braking from 90 mph to 40, as I was going too fast for a 45 spd limit road.. Before, brakes were quiet. I'll try to bed it again, will see. There are no bad people, just differeent. Link to comment Share on other sites More sharing options...
magnetic1 Posted November 4, 2008 Share Posted November 4, 2008 The pads will always remain in contact a little bit when you release the brakes. You can remove the pads and make sure the areas where the "ears" of the pads contact the bracket are clean and free of dirt, grime, etc. Free Sonax Cleaner Deal http://www.brakeswap.com Carbotech, Hawk, PFC, DBA Rotors, Motul, Wilwood, Castrol... Great service. No bumping required ! Link to comment Share on other sites More sharing options...
lepich Posted November 4, 2008 Author Share Posted November 4, 2008 ^ Oh.. When I've removed brakes to check what is happening, it was dirty all around these ears.. I DID NOT clean it (did not think it might be the problem), just applied some grease. But now I see your point, the dirt may prevent pad to back off when you release barekes. I'll clean them tomorrom. Thank you for the advise. There are no bad people, just differeent. Link to comment Share on other sites More sharing options...
ilh Posted November 4, 2008 Share Posted November 4, 2008 I would remove the pads and thoroughly clean out all of the sliding areas and then regrease. Link to comment Share on other sites More sharing options...
lepich Posted November 13, 2008 Author Share Posted November 13, 2008 Quick update for the history: Cleaning did help a lot, tiny squize sounds still appear sometime, but overal it is quiet now. There are no bad people, just differeent. Link to comment Share on other sites More sharing options...
