ssbtech Posted February 3, 2012 Share Posted February 3, 2012 Here's a few so far and I'll try to do a LearningView when I can get the damn program to run on my laptop. https://docs.google.com/spreadsheet/ccc?key=0AjWpEyKowFYVdDNYME4yc25zVFFodFZJdlJxYUdTWHc https://docs.google.com/spreadsheet/ccc?key=0AjWpEyKowFYVdEVkOUdnU1IyVzRXTXlNRlJEcEJwbUE https://docs.google.com/spreadsheet/ccc?key=0AjWpEyKowFYVdFhkcDNKeXVTNHQ3dUFlNnlIbHV4Mnc Link to comment Share on other sites More sharing options...
iNVAR Posted February 3, 2012 Share Posted February 3, 2012 Add in feedback knock correction also. Link to comment Share on other sites More sharing options...
ssbtech Posted February 3, 2012 Share Posted February 3, 2012 Oh crap. I checked all the boxes before taking the laptop to the car, I guess that wasn't available without being connected to the car. I'll try again later. Link to comment Share on other sites More sharing options...
iNVAR Posted February 3, 2012 Share Posted February 3, 2012 The LV's pretty important though. Link to comment Share on other sites More sharing options...
ssbtech Posted February 5, 2012 Share Posted February 5, 2012 Alright, here's my Learning View.. No idea what it means. https://docs.google.com/open?id=0BzWpEyKowFYVM2E2Y2I3MjUtNzdiZS00ZjQyLTljYjUtNDU4NjZkMjQ4Yzhj Link to comment Share on other sites More sharing options...
fishbone Posted February 5, 2012 Share Posted February 5, 2012 AFR correction is on the high side, I think the rule of thumb is it should be under +/- 5% If I understand things correctly the danger is that -7% fuel in the high load. You may be running the risk of leaning out at WOT which is bad. Also that spot of -2.8 in red should be addressed there's some learned knock in that cell. It could be worse I guess. Your IAM (ignition advance modifier) is at 1.0 which is good. Link to comment Share on other sites More sharing options...
ssbtech Posted February 5, 2012 Share Posted February 5, 2012 Ok, so what knob do I twiddle to make it all better? Link to comment Share on other sites More sharing options...
fishbone Posted February 5, 2012 Share Posted February 5, 2012 There are several tables that need to be tweaked in the tune to correct those issues. Don't look at me for suggestions Link to comment Share on other sites More sharing options...
ssbtech Posted February 5, 2012 Share Posted February 5, 2012 Interesting. I've been running this tune/map since I first connected the Access Port some 5 years ago. Link to comment Share on other sites More sharing options...
bmx045 Posted February 6, 2012 Share Posted February 6, 2012 not surprising for an ap map. the load range is 1.3-1.6g/r so it's not in high load range, if it were os tuned i'd probably pull a degree in that area and see if it clears up.... if it continues that it could be noise Link to comment Share on other sites More sharing options...
ssbtech Posted February 6, 2012 Share Posted February 6, 2012 It's actually a TDC map that came on the AccessPort when I bought it. Link to comment Share on other sites More sharing options...
bmx045 Posted February 6, 2012 Share Posted February 6, 2012 soooo....it's tuned to someone elses car? Link to comment Share on other sites More sharing options...
Mega Users seabass07 Posted February 6, 2012 Mega Users Share Posted February 6, 2012 That could be bad if you don't know what mods the previous car had, or if it was scaled for an aftermarket intake. Link to comment Share on other sites More sharing options...
bmx045 Posted February 6, 2012 Share Posted February 6, 2012 moral of the story: never install a tune that was custom tuned for a different car, even if its the same stage level. you'd be much better off starting with a base map from mickeyd or something and working your way up. Link to comment Share on other sites More sharing options...
ssbtech Posted February 6, 2012 Share Posted February 6, 2012 (edited) Way back in the day TDC was selling Access Ports with their own Stage 1 maps on it for a stock car. EDIT: Never mind, looks like it's a COBB map. This is going back 6+ years now. I thought I bought one with the TDC maps pre-loaded, but it looks like I didn't. Edited February 6, 2012 by ssbtech Link to comment Share on other sites More sharing options...
ssbtech Posted February 9, 2012 Share Posted February 9, 2012 Alright, here's my Learning View.. No idea what it means. https://docs.google.com/open?id=0BzWpEyKowFYVM2E2Y2I3MjUtNzdiZS00ZjQyLTljYjUtNDU4NjZkMjQ4Yzhj So any thoughts as to why it is doing this? Link to comment Share on other sites More sharing options...
Mega Users seabass07 Posted February 9, 2012 Mega Users Share Posted February 9, 2012 Have you changed anything recently? Like an air filter? Link to comment Share on other sites More sharing options...
iNVAR Posted February 9, 2012 Share Posted February 9, 2012 Cobb maps are OTS. They're designed for a wide range of vehicles. Not really out of the ordinary for a map to look like that. Link to comment Share on other sites More sharing options...
Mega Users seabass07 Posted February 9, 2012 Mega Users Share Posted February 9, 2012 Except that the Cobb ots map is for stock injectors and intake, and the A/F learning is -7 in the +40g/s. Although they do tend to fluctuate occasionally. Maybe take some more learning views and see if there's a pattern. Mine bounced from -10 to +10 in a day at one point and then fixed itself a day later. I started a thread about it but never really figured it out. Link to comment Share on other sites More sharing options...
iNVAR Posted February 9, 2012 Share Posted February 9, 2012 Yeah, that's the only thing that really stood out...That and the -2.80 but like I said, a little learned knock is what I also saw on my Cobb maps, both stage 1 and 2 when I was running them. SSB, Might want to clean your MAF sensor and see if the trims fix themselves. Link to comment Share on other sites More sharing options...
Mega Users seabass07 Posted February 9, 2012 Mega Users Share Posted February 9, 2012 Good point. Link to comment Share on other sites More sharing options...
Chris GTO TT Posted February 19, 2012 Share Posted February 19, 2012 Flashed Mickyds 08 spec b tune and took a quick log and learning view. Learning view looks good and the logs are in 3rd gear but i let off at 5500 but shows no knock at WOT. There is some FBKC at lower loads and between the two runs. Is this something you guys would be worried about?romraiderlog_20120218_162537.csv 2003 Baja 5MT 2016 Outback 2.5i Premium w/Eyesight Link to comment Share on other sites More sharing options...
fishbone Posted February 19, 2012 Share Posted February 19, 2012 How long have you driven before you pulled the LV? Give it some time/driving cycles to get a more accurate reading. I am seeing similar FBKC as you. Low engine load, under vacuum. I would not worry about it but continue to monitor. Link to comment Share on other sites More sharing options...
Chris GTO TT Posted February 19, 2012 Share Posted February 19, 2012 Oh learning view is fairly short driving so i fully expect it to change later but still figured i'd up load it 2003 Baja 5MT 2016 Outback 2.5i Premium w/Eyesight Link to comment Share on other sites More sharing options...
Chris GTO TT Posted February 19, 2012 Share Posted February 19, 2012 Ok new log. There is 1.41 degrees of FBKC right before i went WOT and that looks a little concerning to me. What if any table would you look at changing to help make that go away? This is my daily driver and safety is the utmost priority on any tune I run I'd gladly leave some power on the table for a safe reliable tune romraiderlog_20120219_083356.csv 2003 Baja 5MT 2016 Outback 2.5i Premium w/Eyesight Link to comment Share on other sites More sharing options...
