GTkansan Posted August 30, 2008 Share Posted August 30, 2008 I get a lot of vibration above 3K rpm in neutral. I think this is because the rag I wiped the shifter grease onto got thrown out before I could reuse it (erg). Of course home depot didnt have anything that I could use. What grease would you all recommend? I guess a graphite or silicone lube (highest density and viscosity I can find?) from pep boys or the like would work to put in under the shifter pivot point? Link to comment Share on other sites More sharing options...
DoubleB Posted September 23, 2008 Share Posted September 23, 2008 I would use some lithium grease. I found some at Lowes, and would be surprised if HD didn't have it. It's cheap too. Link to comment Share on other sites More sharing options...
Underdog Posted September 23, 2008 Share Posted September 23, 2008 I used Mobil 1 all-purpose synthetic grease from autozone. It comes in a tube for a grease gun and the grease is red. The tube itself has the usual Mobil 1 branding on it. I chose the mobil 1 versus the other "all-purpose" greases because it had the widest operating temperature range (down to -40) and was only a few bucks more expensive ($6 versus $4). After having used the STS for a year with the salvaged grease that came on the stock unit, the new grease made a noticeable improvement in shift feel. I used this grease on the lower (ball) pivot as well as the bolt pivot to prevent rattling. Greasing the bolt pivot eliminated the rattle my shifter had while coasting at >3000rpm. I also plan on using this grease on the Kartboy front shifter bushings and rear stay. The Crimson Dynamo Link to comment Share on other sites More sharing options...
JoeFromPA Posted September 25, 2008 Share Posted September 25, 2008 Great info...I'll try that as well, as my stock unit had almost no grease on it to be begin with.... Now I'm going to have to pull out that GODDAMN c-clip again....freaking thing took me 20 minutes last time Joe Link to comment Share on other sites More sharing options...
Underdog Posted September 26, 2008 Share Posted September 26, 2008 Ahh, I have a tip on that snap-ring as well. Use a fine tip needlenose plier rather than snap-ring pliers. Not so fine that the tips bend rather than compress the ring, but narrow enough to fit in the holes. I find it much easier to fit down by the shifter than the bulky snap-ring pliers. The Crimson Dynamo Link to comment Share on other sites More sharing options...
GTkansan Posted September 26, 2008 Author Share Posted September 26, 2008 Thats what I do too. Ive replaced the grease with much better and thicker stuff, and the vibration is better but not gone. Im taking it in to the machine shop tomorrow and grinding down the end so that it will never make contact with the bottom of the well. Link to comment Share on other sites More sharing options...
BigBad Posted September 26, 2008 Share Posted September 26, 2008 I recommend Jegs prothane grease which also come in tubes for the grease gun as well as a smaller jar. Its used for lubing polyurethane bushings which I use it for as well. Its very very sticky and waterproof. I found it to quiet down the shifter even more then even the mobil 1 synthetic I used before. For the C-clip I have a snap ring plier from napa that can be converted with the flick of a switch from external to internal ring formats which worked well for me. Link to comment Share on other sites More sharing options...
JoeFromPA Posted September 26, 2008 Share Posted September 26, 2008 I used a pair of Israeli fine-tip curved needle nose pliers (also good for reaching into naval cavities). Did the job, but I had to "figure out" the technique needed. Joe P.s. I'm aiming to pick-up some grease this weekend; I'll post the results. My wife is really unhappy with the shifting quality of her LGT w/ the Cobb Short Shifter. She hated the stock height and throw, but now she hates the effort, notchiness, etc....and I've adjusted it a number of times. I'm going to now lengthen the throw, raise the height (make it "easier"), apply a gob of grease to the shifter-ball and "grotto" area, and grease up the shift linkage, metal bushings, and shift bolt. In another 1-2 months, I'll do Extra-S fluid in the trans and rear diff. If she's not happy with all that, we're screwed. Link to comment Share on other sites More sharing options...
