team23jordan Posted August 26, 2011 Share Posted August 26, 2011 damn!! was that a stock G8 GXP? Perrin BIG maf intake Perrin Turbo Inlet HKS SSQV BOV Megan Racing header with UP (ceramic coated) HKS DP (WRX) DMH E-cutout Custom 3" catback UTEC Link to comment Share on other sites More sharing options...
NSFW Posted September 1, 2011 Author Share Posted September 1, 2011 I asked the owner of the GXP what he'd done to the car, and he said "intake, exhaust, and a tune." I guess that's their equivalent to our stage-2 setup. The forum just ate my post with the data log and comments on it. Link to comment Share on other sites More sharing options...
NSFW Posted September 1, 2011 Author Share Posted September 1, 2011 OK, the log is attached. Noteworthy stuff in the log: * Max MAF = 338 g/s * Max load = 3.2 g/rev * Max boost = 21.8psi * Redline boost = 21psi (it dipped to 20.8 along the way) * IAT = 91 to 95 * Min AFR = 11.2 * AFR was around 12.0 at peak power. Usually that's bad, but... * Knock sum did not increment, so no harm done. * There are two FLKC cells with -1 corrections, those must have happened on the way to the dyno day. * Peak boost happened at 4700. * WGDC stays flat at 80% because I was using an MBC. That pull was done in 3rd gear on the dyno. Subsequent pulls were done in 4th but then I had low boost and only 350whp. My tune was pulling WGDC in response to 'high' ECT (207F or so). I've since revised the WGDC compensation to allow full WGDC up to 210F. On the street I hit 20 psi at around 3800 RPM in 3rd gear. The 'target boost' values in the log are what I get in a 4th-gear pull on the road.377whp.csv Link to comment Share on other sites More sharing options...
TRSCobra Posted September 2, 2011 Share Posted September 2, 2011 You got 377whp with the stock mufflers? Any idea on another 1/4 mile run? Link to comment Share on other sites More sharing options...
NSFW Posted September 3, 2011 Author Share Posted September 3, 2011 Yep, stock mufflers. I want to get out to the track at least once more this season. How about September 23rd? Link to comment Share on other sites More sharing options...
TRSCobra Posted September 3, 2011 Share Posted September 3, 2011 I might show up to watch, since my clutch won't handle another drag launch. What time do you usually get there? Link to comment Share on other sites More sharing options...
NSFW Posted September 3, 2011 Author Share Posted September 3, 2011 I'm going to be there when the racing starts at 4. Link to comment Share on other sites More sharing options...
LittleBlueGT Posted September 6, 2011 Share Posted September 6, 2011 I also got a 1.384 60' time. That was (still is) a huge surprise, I didn't think my car could do that. I was thinking about this the other day. The 9 second Subarus are pulling 1.4-1.6 60 foot times, the 11 sec ones are doing mostly 1.7-1.8 with the odd 1.6. I really don't think you did a 1.384 60 foot time. Full tune of 68HTA, KSTech 73 MAF, Racer X FMIC and ID1000s................by the DataLog Mafia!!! Link to comment Share on other sites More sharing options...
TRSCobra Posted September 6, 2011 Share Posted September 6, 2011 23rd, huh? I'll try to be there! Link to comment Share on other sites More sharing options...
Tommyh Posted September 7, 2011 Share Posted September 7, 2011 I really don't think you did a 1.384 60 foot time. LGBT meet NSFW. He doesn't make shit up. Martin Luther - "Who loves not women, wine and song remains a fool his whole life long." EL4NFZT7 Link to comment Share on other sites More sharing options...
NSFW Posted September 7, 2011 Author Share Posted September 7, 2011 LGBT meet NSFW. He doesn't make shit up. It's all good. I have a theory on what made it possible and will try for another in October. Basically, PIR's track had exactly the right amount of traction/wheelspin, and I had one launch where I screwed up and was bouncing off the rev limiter when I launched. My other launches that night were fairly consistent but I had that one great outlier and I think that's what did it. We'll see, if the traction is similar in October. Link to comment Share on other sites More sharing options...
NSFW Posted September 21, 2011 Author Share Posted September 21, 2011 I still haven't figured out what caused the 12:1 AFR on the dyno day - all of my theories have been wrong so far. Now I'm guessing that the fuel pump is dying, because it does lean out somewhat in proportion to fuel flow - it's leanest right around peak MAF. I need a second pump to find out for sure, but that's not something I can get fixed before Friday, so no drag racing for me this week. Link to comment Share on other sites More sharing options...
TRSCobra Posted September 21, 2011 Share Posted September 21, 2011 :( Link to comment Share on other sites More sharing options...
LittleBlueGT Posted September 22, 2011 Share Posted September 22, 2011 It's all good. I have a theory on what made it possible and will try for another in October. Basically, PIR's track had exactly the right amount of traction/wheelspin, and I had one launch where I screwed up and was bouncing off the rev limiter when I launched. My other launches that night were fairly consistent but I had that one great outlier and I think that's what did it. We'll see, if the traction is similar in October. I am interested in your theories, cause that launch makes no sense, unless lots of cars there get launches in that ball-park. Full tune of 68HTA, KSTech 73 MAF, Racer X FMIC and ID1000s................by the DataLog Mafia!!! Link to comment Share on other sites More sharing options...
NSFW Posted September 23, 2011 Author Share Posted September 23, 2011 For one launch I lifted off the clutch too late, so I bounced off the rev limiter first, and I suspect that was the 1.38 one. I don't know for sure because I quit looking at the 60' times after the first few launches. (Basically I was either getting good launches (1.7 - 1.9) or terrible ones (2.2 - 2.5) and I didn't need a time slip to know the difference, so I didn't look at anything other than ET and trap until after I was done.) So my theory is that I should just use the factory rev limiter for launch control - floor it, bounce off the limiter, release the clutch. if Portland's traction is the same in October (enough wheelspin to avoid bogging, enough traction to avoid sit-and-spin) then hopefully I will get another exceptional 60' time. I have to get my AFR problem figured out first though. Going to try a new fuel pump and see if that's the root cause. I'm also ordering new axles, but I don't know if they will be here in time. Hopefully I won't need them. Link to comment Share on other sites More sharing options...
NSFW Posted October 26, 2011 Author Share Posted October 26, 2011 I replaced the fuel pump with an Aeromotive Stealth 340, and my AFRs are back on track. Also installed a fuel pressure sensor, since that would have helped me figure this out a lot quicker. I still need to get the sensor wired up, but at least the under-hood work is done. PLX says fuel will corrupt their fluid pressure sensor, so you should only use it for water and oil pressure. So I put a T in my fuel line, with the sensor at the bottom of a hose about a foot long, and filled the hose with water. So the sensor is measuring water pressure, but the water getting that pressure from fuel. Fuel floats, so I'm betting that the sensor will always be bathed in water. The car idled a bit rough for the first minute or so, probably from water getting into the fuel, but it runs great now. Also flashed my own launch-control & flat-foot-shifting patch this morning, and it works. I haven't launched with it or shifted with it, but the rev limiter works like it's supposed to. At a standstill, with the clutch in, it's around 4000 RPM. Above a few miles per hour, with the clutch in, fuel cut is 7200 RPM and fuel resume is 4000, so it won't bounce off the limiter while I'm shifting (but I can hold the throttle wide open, so boost won't be lost). With the clutch out, it's the normal 7200/7100 rev limiter. Only catch is, I've been reading so much about broken axles in the last few days that I'm afraid to really try this LC/FFS stuff. I should have new axles on hand soon, but I don't really want to need them... Anyone want to buy an AVO fuel pump, cheap? Link to comment Share on other sites More sharing options...
NSFW Posted October 31, 2011 Author Share Posted October 31, 2011 If Portland's traction is the same in October (enough wheelspin to avoid bogging, enough traction to avoid sit-and-spin) then hopefully I will get another exceptional 60' time. [...] I'm also ordering new axles, but I don't know if they will be here in time. Hopefully I won't need them. Drag racing got rained out, so the mystery remains. Link to comment Share on other sites More sharing options...
NSFW Posted September 2, 2012 Author Share Posted September 2, 2012 Wow, it's been almost a year since my last post here. I haven't done much other than just drive the car, so there hasn't been anything to share. But I put in an alternator cover and radiator shroud from Subtle Solutions yesterday... (I removed the Subtle stickers because they were not quite subtle enough.) Link to comment Share on other sites More sharing options...
Tracer-X Posted September 3, 2012 Share Posted September 3, 2012 Isn't this a photo of Subydude555's car??? Jump on it, Let's do it, Ride it, My Pony... EL4NFZT7 Link to comment Share on other sites More sharing options...
NSFW Posted September 19, 2012 Author Share Posted September 19, 2012 Last Friday I finally got my car onto a road course for some lapping. It was a little scary but it went pretty well. By the time the first session ended I had a pretty good idea of where to brake and when to turn, so the fear subsided and the fun took over. The temperature gauge started to creep up, but I got it down by letting up on the throttle in between turns. And I slid off the track once, but didn't slide far, and got back on at the next gap in traffic, no harm done. Can hardly wait to try it again. Link to comment Share on other sites More sharing options...
boxkita Posted September 21, 2012 Share Posted September 21, 2012 Addicting, isnt it? Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
NSFW Posted September 22, 2012 Author Share Posted September 22, 2012 Yeah. I'm thinking I might want to get some more experience with a car that would be easier to replace, though. I'm still having nightmares about what would have happened if someone else had slid off the same corner before I got out of the way. Link to comment Share on other sites More sharing options...
RyanGT Posted September 22, 2012 Share Posted September 22, 2012 That's easy to avoid....just don't run in the same group with boxkita. I hear that he's all about Drama at the track. . . I have enough drama for now..... Link to comment Share on other sites More sharing options...
NSFW Posted August 26, 2013 Author Share Posted August 26, 2013 It's been almost a year, so here's an overdue update... I have a clutch problem, which I wrote about at NASIOC since there are more people over there with Exedy Twin clutches (since that clutch is only available for 6MTs). http://forums.nasioc.com/forums/showthread.php?t=2523834 So I've bought an ACT HDSS and LWFW. The 6MT version is rated for a lot more torque than the 5MT version, so it might last. Or it might not. I'm gonna try. While I'm running that clutch I'm going to try to fix the Exedy's weakness: http://forums.nasioc.com/forums/showthread.php?t=2531853 I'm going to have the clutch swap done at Maxwell Power, and while they're at it I'm going to have an equal-length header installed: http://www.killerbmotorsport.com/index_files/Header.htm It's at SwainTech right now getting coated. When I have it in mind hands I'll schedule the work at Maxwell. I'm also going to have four EGT sensors installed (one next to each exhaust port), and two IAT sensors (one next to the throttle body for speed-density, and one next to the compressor outlet, just out of curiosity). I have been thinking more and more about getting a built motor, since a higher redline would be a lot of fun, and it's kind of surprising that the stock motor has lasted this long. But that would be $thousands, and the stock motor just keeps on running strong, so I'm keeping it. (Knock on wood.) Link to comment Share on other sites More sharing options...
boxkita Posted August 26, 2013 Share Posted August 26, 2013 I wanted the holy header, but just couldn't swing it after the second engine rebuild. A built motor with a higher redline is alot of fun, especially as you already have the transmission to support it (broke mine for the 2nd time). Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
