SkiDaddy Posted July 24, 2008 Share Posted July 24, 2008 I use my '06 5MT LGT for pulling my dirt bike trailer in various dirt or sand parking areas and need to maintain my current ground clearance. At 73,000 the OEM shocks & struts are needing replacement, so I need a little guidance as to which brand to use. The car is mostly a freeway commuter, so I don't want to stiffen it up much if any. Would I be better off w/KYB or Monroe shocks & struts as direct replacements? Should I use OEM shocks & struts or aftermarket KYB, or is there any difference? Thanks. Link to comment Share on other sites More sharing options...
Guest Posted July 24, 2008 Share Posted July 24, 2008 Get some Bilsteins with SpecB springs. Way better handling and stock ground clearance. You could also try Konis with stock springs. Link to comment Share on other sites More sharing options...
Underdog Posted July 24, 2008 Share Posted July 24, 2008 +1 to unclemat's advice. I'm using the Konis with Swift springs (which are waaay too low for your application) and I've been toying with the idea of going to something with less of a drop/rate. Stock springs would be great, but I like the reduced roll/pitch/dive and even the stance I have now. I'm looking for something in the middle like Cobbs, Pinks, Rallitek, or Crucial springs which have less drop and a milder rate (relatively). Although, I might just save the cash and switch to coilovers someday... The Crimson Dynamo Link to comment Share on other sites More sharing options...
SkiDaddy Posted July 24, 2008 Author Share Posted July 24, 2008 But I don't want a stiffer ride, it's mostly a freeway cruiser to/from work. Link to comment Share on other sites More sharing options...
Guest Posted July 24, 2008 Share Posted July 24, 2008 It's not stiffer. And stiffer does not mean less comfortable. Stock suspension sucks. It is less comfortable than my Bilstein coilovers, which have like 70% stiffer springs. It's all about dampening to spring match. And USDM SpecB Bilsteins ride better and nicer than stock LGT. If someone thinks otherwise he needs his head and butt checked. Link to comment Share on other sites More sharing options...
Spoonwacker Posted July 24, 2008 Share Posted July 24, 2008 I know there's a local member who does TSD rallies in his LGT, and I'm pretty sure he uses Bilstein HDs on stock springs. sorry...this forum practically blows goat nuts so im not always on here.Team Pony Express POSTED FROM MY COMPUTER USING A WEB BROWSER Link to comment Share on other sites More sharing options...
SkiDaddy Posted July 24, 2008 Author Share Posted July 24, 2008 Bilstein HD - IS that heavy duty? Link to comment Share on other sites More sharing options...
Spoonwacker Posted July 24, 2008 Share Posted July 24, 2008 Yeah - AFAIK, it's the only Bilstein you can get without going through a Subaru dealer (or importing from Japan), which means they're significantly cheaper, but very high quality. I use them on Swift springs, which have a lot of drop, but the Bilsteins damp the ride very nicely. sorry...this forum practically blows goat nuts so im not always on here.Team Pony Express POSTED FROM MY COMPUTER USING A WEB BROWSER Link to comment Share on other sites More sharing options...
boostsr20 Posted July 24, 2008 Share Posted July 24, 2008 Bilstein will also do custom valving if you really want something stiff but the regular HD's are much better than stock. Link to comment Share on other sites More sharing options...
SkiDaddy Posted July 25, 2008 Author Share Posted July 25, 2008 Who has the best pricing on these? Link to comment Share on other sites More sharing options...
NSFW Posted July 25, 2008 Share Posted July 25, 2008 Consider Tokico shocks and struts, too. They're adjustable. I haven't installed mine yet so I can't comment on the ride, but since they're adjustable I'm optimistic about being able to make the ride well with whatever springs I end up with. http://www.fastwrx.com carries them for the LGT. Link to comment Share on other sites More sharing options...
SkiDaddy Posted August 8, 2008 Author Share Posted August 8, 2008 OK, if I use Bilstein HDs I'll also need Spec B upper mounts. Who has good prices on these on the east coast? Link to comment Share on other sites More sharing options...
HansGT Posted August 8, 2008 Share Posted August 8, 2008 check here....everything you need except springs.... http://www.5-starperformance.com/servlet/the-987/Bilstein-Legacy-GT-Suspension/Detail Just email Jeremy. Link to comment Share on other sites More sharing options...
SkiDaddy Posted August 8, 2008 Author Share Posted August 8, 2008 check here....everything you need except springs.... http://www.5-starperformance.com/servlet/the-987/Bilstein-Legacy-GT-Suspension/Detail Just email Jeremy. Great link Han! Now all I need is a good source for Spec B springs..... Link to comment Share on other sites More sharing options...
ilh Posted August 8, 2008 Share Posted August 8, 2008 I believe you can buy the set of USDM SpecB springs from them for $160ish. At least that is about what they cost the last time I priced them online (perhaps from the same site). Link to comment Share on other sites More sharing options...
HansGT Posted August 8, 2008 Share Posted August 8, 2008 Great link Han! Now all I need is a good source for Spec B springs..... same source. they are a dealership. Link to comment Share on other sites More sharing options...
hutru01 Posted August 8, 2008 Share Posted August 8, 2008 Bilstein HDs are pretty stiff IMHO. Link to comment Share on other sites More sharing options...
HansGT Posted August 8, 2008 Share Posted August 8, 2008 ^ yeah more than the standard USDM spec B Bilsteins which are pretty comfy from what I've seen. He may want to look into finding some used. Link to comment Share on other sites More sharing options...
hutru01 Posted August 8, 2008 Share Posted August 8, 2008 ^ I don't particularly like them to be honest. I mean handling is amazing, but potholes/dips in the road, not so much. Link to comment Share on other sites More sharing options...
