fishbone Posted June 25, 2008 Share Posted June 25, 2008 I had a tranny flush at 36K miles, filled it with Subaru ATF. Ran the car Stage 1 for about 15k miles, I am now at 56K miles. This transmission fluid has been in for 20K miles, 15K on Stage 1. No transmission cooler. Here are some pictures. Do you think it's too dark? My mechanic expressed absolutely no concerns. The transmission shifts like day 1 from what I can tell. As far as smell, the old one smells close to the fresh fluid. When I drained it into the empty jar, the old fluid is what I would describe as dirty cherry red/brown. It's not black, just dark. Can't see through it. Click on the pics of course to get the full-size version. Here's a dip wipe vs a fresh drip from the bottle http://img103.imageshack.us/img103/516/dscf5297ge5.th.jpg Here's fresh vs old http://img103.imageshack.us/img103/4548/dscf5299pv7.th.jpg I shook it a bit here so you could see the color on the sides of the jar http://img185.imageshack.us/img185/750/dscf5300oe2.th.jpg http://img185.imageshack.us/img185/2803/dscf5301ag2.th.jpg http://img185.imageshack.us/img185/8892/dscf5302rt7.th.jpg Do you 5EAT guys mind posting some pics too if you happen to have some or you're about to drain your ATF? Link to comment Share on other sites More sharing options...
wukindada Posted June 25, 2008 Share Posted June 25, 2008 even with the tranny cooler I would switch every 20-25k if modded;) Stage II or under........Tranny cooler & change every 25K Larger turbo...............Tranny cooler....the IPT touch & change every 20K Toyota 6EATS .........SUCK!!!!!! Link to comment Share on other sites More sharing options...
fishbone Posted June 26, 2008 Author Share Posted June 26, 2008 I'm gonna stick with 20K drains from now on but just wanted to get some input on what this fluid looked like to try and see if I abused anything. I should add that I am Stage 2 now and yes, I have a transmission cooler. Link to comment Share on other sites More sharing options...
wukindada Posted June 26, 2008 Share Posted June 26, 2008 Def. dirty..... I always check my tranny fluid every oil change **4K** just as a precaution;):) Toyota 6EATS .........SUCK!!!!!! Link to comment Share on other sites More sharing options...
fishbone Posted June 26, 2008 Author Share Posted June 26, 2008 Does dirty just mean burnt like engine oil, or does dirty mean my clutch packs started eating themselves? Link to comment Share on other sites More sharing options...
derffred Posted June 26, 2008 Share Posted June 26, 2008 That's nothing to worry about. Link to comment Share on other sites More sharing options...
fishbone Posted June 26, 2008 Author Share Posted June 26, 2008 I swear I must be the biggest pussy around here. I went just Stage 2 but in my head I swapped the Boxer for a 12 litre V10 on the stock transmission ... Link to comment Share on other sites More sharing options...
wukindada Posted June 26, 2008 Share Posted June 26, 2008 Does dirty just mean burnt like engine oil, or does dirty mean my clutch packs started eating themselves? neither.....just dirty It's always better to be safe than sorry, think of it as cheap insurance Toyota 6EATS .........SUCK!!!!!! Link to comment Share on other sites More sharing options...
fishbone Posted June 26, 2008 Author Share Posted June 26, 2008 A little off-topic, kinda cool that this fluid should be a cherry red ... Link to comment Share on other sites More sharing options...
rao Posted June 26, 2008 Share Posted June 26, 2008 I swear I must be the biggest pussy around here. I went just Stage 2 but in my head I swapped the Boxer for a 12 litre V10 on the stock transmission ... Stop worrying. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
srgdrum Posted June 26, 2008 Share Posted June 26, 2008 I mean really? Who gets their mandarin oranges in a glass jar? I keed. Regular changes. It's cheap insurance. Me and you both need to save for teh IPT touch per Wuki! And I still need the cooler too. Link to comment Share on other sites More sharing options...
srgdrum Posted June 26, 2008 Share Posted June 26, 2008 I swear I must be the biggest pussy around here.... Nah TUNED200 is here somewhere... Link to comment Share on other sites More sharing options...
hutru01 Posted June 26, 2008 Share Posted June 26, 2008 "the IPT touch" Thats one expensive little touch. Link to comment Share on other sites More sharing options...
srgdrum Posted June 26, 2008 Share Posted June 26, 2008 Thats one expensive little touch. Testify brother! Link to comment Share on other sites More sharing options...
fishbone Posted June 26, 2008 Author Share Posted June 26, 2008 It's $650, but it used to be $1K not long ago IIRC. If you put things in perspective, a TMIC is more expensive than a VB mod and the VB mod goes a longer way. I'd do that first and reinforce the stock TMIC for a Stage 2 set-up. I need to get both but the VB might just have higher priority than the TMIC. Link to comment Share on other sites More sharing options...
SeeeeeYa Posted June 26, 2008 Share Posted June 26, 2008 It's $650, but it used to be $1K not long ago IIRC. If you put things in perspective, a TMIC is more expensive than a VB mod and the VB mod goes a longer way. I'd do that first and reinforce the stock TMIC for a Stage 2 set-up. I need to get both but the VB might just have higher priority than the TMIC. ^^^ Link to comment Share on other sites More sharing options...
hutru01 Posted June 26, 2008 Share Posted June 26, 2008 It's $650, but it used to be $1K not long ago IIRC. If you put things in perspective, a TMIC is more expensive than a VB mod and the VB mod goes a longer way. I'd do that first and reinforce the stock TMIC for a Stage 2 set-up. I need to get both but the VB might just have higher priority than the TMIC. The VB upgrade is a must for anyone who is 5EAT and Stage II+. Better to be safe than sorry. If you go Stage III+, you will need a IPT rebuild. Link to comment Share on other sites More sharing options...
fishbone Posted June 26, 2008 Author Share Posted June 26, 2008 Seeyaa, would you mind answering a question if you happen to know? What exactly does IPT do to the VB for the price. I know that this was answered somewhere but there are so many IPT topics now, I can't find it I know the end result, faster and firmer shifts, but how? Do they also increase the line pressure? My shop also does tranny rebuilds and they said that $649 for a VB is not bad at all for an import AT. Link to comment Share on other sites More sharing options...
hutru01 Posted June 26, 2008 Share Posted June 26, 2008 fishbone: For more details, everything is in here. http://www.importperformancetransmissions.com/subaruauto.shtml Also, if you want to call them, they are really nice and friendly. They are a top notch company with great customer service. This is from personal experience also, not just hearsay. Link to comment Share on other sites More sharing options...
fishbone Posted June 26, 2008 Author Share Posted June 26, 2008 Yep, I went to that site but the break-down doesn't mention which are included in the VB, just shows the break-down/run-down of stuff done for a complete AT overhaul. I ask because some people said here "well, it's only a calibration" while others said certain mechanical parts are either replaced with high-performance ones or treated/reinforced. Later edit: called IPT, you were right, Ty is very friendly He said that quite a lot of stuff is involved in the IPT so it makes the price sound even better. They replace springs, recalibrate stuff, reconfigure hardware parts, etc. The line pressure is also increased so the clutch packs hold firmer and the tranny overall is able to take a lot more power. I asked for a ballpark figure of the stock max rated torque, he said it should be somewhere around 350-370lb-ft "at the rear wheels". He must have forgotten we are awd He also said that as far as the stock tranny holding up, "it depends. Some can hold more power, while others have seen premature wear and tear and other issues". Either way, the IPT VB will prolong the life of the transmission and between the VB and a complete overhaul, there really is nothing else. He also said that the re-learning curve of the TCU takes about 200 miles of driving, so at first it may feel/act a bit strange, but it will eventually settle. I also asked for what kind of feedback people have gotten as far as daily driving this, he said that the shifts will change overall, regardless if the tranny is or is not under load. I know there's another topic here somewhere where IPT VB users have offered their input. Link to comment Share on other sites More sharing options...
hutru01 Posted June 26, 2008 Share Posted June 26, 2008 He also said that the re-learning curve of the TCU takes about 200 miles of driving, so at first it may feel/act a bit strange, but it will eventually settle. He was right on the money about that too. I spoke to Ty throughout the whole process when I had my transmission up there. (Now granted, I did a full rebuild) For the first 200 miles, he said to drive it at different rates of speed, and not necessarily "just taking it easy". It was a little finicky at first, but after a week or so of driving, it was like no other automatic I have ever driven. To this day, it shifts beautifully and exchanges every bit of the power that I am pushing to the wheels. No slippage whatsoever. Link to comment Share on other sites More sharing options...
fishbone Posted June 26, 2008 Author Share Posted June 26, 2008 I also found a much more detailed account here as far as the WHAT http://legacygt.com/forums/showpost.php?p=1397854&postcount=69 How many miles you got on your car and then on your IPT, hutru? Are you Stage 2+ or 3? Link to comment Share on other sites More sharing options...
hutru01 Posted June 26, 2008 Share Posted June 26, 2008 How many miles you got on your car and then on your IPT, hutru? Are you Stage 2+ or 3? I just surpassed 60K miles. The IPT rebuild was done in March at about 56K miles. (So about 4-5K miles ago) I am Stage III+ I guess? List of mods below on my cardomain site. Link to comment Share on other sites More sharing options...
fishbone Posted July 13, 2008 Author Share Posted July 13, 2008 Gotta revive this one quick. Checked the fluid level and when cold it's at the hot max, yet when hot, it's about where it's supposed to be. Is that normal? Maybe has something to do with the tranny cooler? Do levels have to be right on the money, or is there some tolerance? This damn dipstick is so hard to read. Link to comment Share on other sites More sharing options...
DrewLGT Posted July 13, 2008 Share Posted July 13, 2008 Gotta revive this one quick. Checked the fluid level and when cold it's at the hot max, yet when hot, it's about where it's supposed to be. Is that normal? Maybe has something to do with the tranny cooler? Do levels have to be right on the money, or is there some tolerance? This damn dipstick is so hard to read. i think the tranny fluid is supposed to be checked with the motor running, and the trans in neutral to get an accurate reading. Link to comment Share on other sites More sharing options...
