16psibrick Posted June 24, 2008 Share Posted June 24, 2008 well, its acutally been a few weeks since i finished the installation on my own car, but with the crazy work schedule, i havent had any chance to organize the pics i took and upload them until now. so anyway, lets get started... Goals: 1. achieve a decent level of sound quality (than previous system) 2. keep everything hidden completely under the floor 3. throw in aspects of my skillset into the install so i can demonstrated to potential clients what certain things can look like (i.e. wiring neatly through grommits, routed plexi, led edge lit plexi, etc etc) Before i dive into the current install, a quick revisit to the previous install. which was extremely simple. pioneer avic-z1 to a single DLS A5 3 channel amp, whcih powered a set of DLS nobeliums in kicks upfront, and a single idmax10 in the back, with an audiocontrol DQT providing the tuning. the car sounded decent in a normal sense, but paled terribly when compared to the SQ systems people were building. Coupled with the fact that more and more clients seem to be interested in going in that direction, i figured it was finally time to ditch the old and build something a little bit more proper... so here was the old cargo area set up: http://simplicity.elitecaraudio.org/legacy88.jpg as you can see, a single idmax10, the A5 amp, and two passive xovers took up the entire space. so...this is where the challenges for the new install began...this time, in the SAME space, i needed to fit roughly TWICE the stuff, if not more and here are the big pieces thats going into the back: http://simplicity.elitecaraudio.org/me1.JPG so...lets take stock: IDQ10 sub DLS A4 4 channel amp (bridged for midbass) DLS A5 3 channel amp (tweets, and subwoofer) Zapco DSp6-SL processor and add to that: .75-.8 cubfeet sub enclosure two D-blocks on display two barrier strips on display a slew of edge lit plexi borders....etc... so all that in this space...and have to look decent (though cosmetics was never the driving factor in this setup) http://simplicity.elitecaraudio.org/me21.JPG so quite the headache then, setting this limitation on myself...you may wonder why? well...i guess i will let the pictures do the talking. This is my car on a weekly or bi-weekly basis: http://simplicity.elitecaraudio.org/me2.JPG infact, this is a light load normally, there would be a few more sheets of wood and carpet in there. so this is why my install in the back must not take up ANY space other than the spare tire well rounding out my equipment list is a Rockford Fosgate 8250Ti headunit and Seas Lotus Reference 6.5" two way set Link to comment Share on other sites More sharing options...
16psibrick Posted June 24, 2008 Author Share Posted June 24, 2008 lets do the headunit portion. Becuase the legacy GT has a one piece circuit board with AC and stereo, its very difficult and expesnive to try and install a headunit into the stock location. IN addition, i intend to leave the stock system completely intact (as before), so i can provide A/B demo to potential clients if needed. so the other solution is to mount the headunit in the stock cubby spot in the upper/center dash, between the AV vents... so firstly, the wires needed for the new headunit, along with an antenna adapter, was extended to the upper cubby spot, i used female/male quick disconnects for easy removal and service of the new headunit: http://simplicity.elitecaraudio.org/me3.JPG next here is the Denford's wiring harness organized and protected: http://simplicity.elitecaraudio.org/me4.JPG what you see on the left is the stock ac/vent cubby piece, with the cubby removed, and on the right is the JDM AVO singl din dash adapter piece that allows a headunit to be fitted, it needs to be trimmed a bit and parts of the dash structures needs to be cut off, but its a great solution for the legacy GT. http://simplicity.elitecaraudio.org/me5.JPG here are the two pieces mated together: http://simplicity.elitecaraudio.org/me6.JPG here of course, is the unit itself: http://simplicity.elitecaraudio.org/me7.JPG and the rcas all bundled up and protected, as i will not be using them. the unit has simblink style balanced Din outputs, that i will be tapping directly into to connect with the DSP6. http://simplicity.elitecaraudio.org/me8.JPG here are hte brackets for the AVO kit attached to the unit: http://simplicity.elitecaraudio.org/me9.JPG remote wire techflexed and ready to go: http://simplicity.elitecaraudio.org/me10.JPG the simblink cable similarly done: http://simplicity.elitecaraudio.org/me11.JPG all the wires lead out to the spot and ready to mount headunit: http://simplicity.elitecaraudio.org/me12.JPG and the headunit secured with all the wires attahced: http://simplicity.elitecaraudio.org/me13.JPG here are an assortment of other wires that are techflexed for running to the back of the car: http://simplicity.elitecaraudio.org/me15.JPG http://simplicity.elitecaraudio.org/me16.JPG http://simplicity.elitecaraudio.org/me17.JPG and a few quick shots of the wiring as it goes to the back of hte car: http://simplicity.elitecaraudio.org/me18.JPG http://simplicity.elitecaraudio.org/me19.JPG http://simplicity.elitecaraudio.org/me20.JPG Link to comment Share on other sites More sharing options...
16psibrick Posted June 24, 2008 Author Share Posted June 24, 2008 I always felt that each install, especially the stealth ones, is like a jigsaw puzzle, you get an overall picture and slowly piece it together by making the individual components. The most important aspect IMO, is the overall picture in my head, without that, then i really am lost. so...tackling this install is sorta like working with a really small puzzle in terms of overall size, yet having many many pieces to it... so the first thing is to figure out the one component that takes up the most amount of space, and pretty much will dictate how the entire install will be fitted, in that is, the sub box. after some quick measuring, it quickly became apparent that the ONLY way for everything to fit int he well is to make a pancake flat subbox. luckily, i had a very large spare tire well here is the well after the old system was removed: http://simplicity.elitecaraudio.org/me21.JPG http://simplicity.elitecaraudio.org/me22.JPG so i used a box and measured out about .9 cub feet with peanuts: http://simplicity.elitecaraudio.org/me23.JPG and put it into the well, and as you can see, it stacked up about 2" high when laying flat: http://simplicity.elitecaraudio.org/me24.JPG then the height was mapped, the buttom bluetapped, and the line draw across to mark the heigh for glassin' http://simplicity.elitecaraudio.org/me25.JPG so here is after 8-10 layers of 3/4 oz mat goes on: http://simplicity.elitecaraudio.org/me26.JPG http://simplicity.elitecaraudio.org/me27.JPG and here is the top baffle piece made: http://simplicity.elitecaraudio.org/me28.JPG and the bottom mold piece trimmed. http://simplicity.elitecaraudio.org/me29.JPG some dampening while i am at it: http://simplicity.elitecaraudio.org/me30.JPG and sorry about htis part, cause i skipped a few steps and didnt take pics, but here is the box with the top part joined with the bottom and test fitted in the spare tire well: http://simplicity.elitecaraudio.org/me31.JPG i took a second measurement with kitty litter and found the internal air space to be around .8 or so, which is right around where i wanted it to be Link to comment Share on other sites More sharing options...
16psibrick Posted June 24, 2008 Author Share Posted June 24, 2008 one thing i decided very early on to do, despite the fact that it was going to make my already crowded install even more difficult, was to show case some clean wiring via barrier strips and distribution blocks, as well as to use some edge lit plexi to set things off. The reason i wanted to include these aspects into the car is not really my own preference, but i wanted the ability to demonstrate some of my installation skill set to a potential client...as it is much easier and effective, for example, to show what edge lit plexi looks like than trying to describe it... so anyway, here is the start of the construction of the U shaped piece that would make up the side walls of the install...hard to explain, i guess just follow the pics. each side piece is acutally made out of three pieces, first the two sides were lined up wtih the custom routed center plexi pieces, and holes were drilled onto the back MDF where wires will be passing through. http://simplicity.elitecaraudio.org/me32.JPG and then, the frontal piece is made out of 1/2" mdf as well, and an opening was routed out, and slanted, to match the opening on the plexi piece: http://simplicity.elitecaraudio.org/me33.JPG then, skipping over a bunch of steps where i forgot to take pics lol, here is the bulk of the pieces test fitted together, and marked, the frontal portion of the U is pre drilled also for the wires of the DSP6 to pass through, you can tell by the markings on the floor piec where each piece will go: http://simplicity.elitecaraudio.org/me34.JPG then the side pieces, including hte plexi border and the back piece with the grommits, are test fitted: http://simplicity.elitecaraudio.org/me35.JPG http://simplicity.elitecaraudio.org/me36.JPG http://simplicity.elitecaraudio.org/me37.JPG and mounted ontop of the subbox, to check for clearances...so pretty tight already, without any of hte wires ran yet :o http://simplicity.elitecaraudio.org/me38.JPG next come the vinyl part...i chose to do the back in two tone black and silver CF vinyl, again, not neccessarily for my own preference, but to those of some of my customers in the recent past. Its very easy to explain what suede or single color vinyl looks like, but its kinda hard to pass on what the CF vinyl looks like in real life, plus it blends well with the black and silver theme i have on the rest of hte car hehe... so here is the U piece: http://simplicity.elitecaraudio.org/me39.JPG and covered in black CF vinyl: http://simplicity.elitecaraudio.org/me40.JPG the back of the side pieces: http://simplicity.elitecaraudio.org/me41.JPG covered in silver CF vinyl and grommits installed: http://simplicity.elitecaraudio.org/me42.JPG the side plexi clouded: http://simplicity.elitecaraudio.org/me43.JPG and million (RGB) led strips attached to the outter edge: http://simplicity.elitecaraudio.org/me44.JPG the thin floor piece also covered in silver CF vinly: http://simplicity.elitecaraudio.org/me45.JPG Link to comment Share on other sites More sharing options...
16psibrick Posted June 24, 2008 Author Share Posted June 24, 2008 so here comes the pain...i mean...wires here is the bulk of the rack sitting together, all vinyled, and all the preliminary wires ran and lead out. a keen eye will notice that the barrier strip closer to the camera is empty, and indeed it is there solely for cosmetic balancing purposes, as there are TWO D blocks on the driver side, there should be TWO barrier strips as well on the passenger side)... so as you can see, a ton of wires already and not even counting the ones that comes from the CAR, these are just the ones running to and from the rack itself here is an all around view of this: http://simplicity.elitecaraudio.org/me46.JPG http://simplicity.elitecaraudio.org/me47.JPG http://simplicity.elitecaraudio.org/me48.JPG http://simplicity.elitecaraudio.org/me49.JPG to prevent any bare MDF to show through any joints between the silver floor piece and the black side walls, the box was painted black at those areas...most likely this made zero difference, but i am a bit anal sometimes http://simplicity.elitecaraudio.org/me50.JPG a grounding spot was chose on the driver side and the metal ground bare: http://simplicity.elitecaraudio.org/me51.JPG so now the real fun begins, as the wiring coming from the front of hte car joins the fray... its really hard to explain just how many wires are on the PASSENGER side of the install, 3 simblink calbes in, 3 simblink out adapting to 3 rca cables...speaker wires.. etc etc...took a while to get things at least somewhat organized and the space taken up minimized... i will just let the next few pics do the talking: http://simplicity.elitecaraudio.org/me52.JPG http://simplicity.elitecaraudio.org/me53.JPG http://simplicity.elitecaraudio.org/me54.JPG next comes the mounting of the various components into the well... i had a good friend of mine make me two spacer blocks out of aliuminum, this will provide a very solid footing for the A4 amp that will be suspending over the smaller A5 amplifier: http://simplicity.elitecaraudio.org/me55.JPG so first up is the DLS ultimate A5 big three 3 channel amplifier. this unit will send 85 watts a piece to my tweeters upfront, and power the subwoofer with 780 watts at 1ohm, all class AB not ehte wires for the dsp6 was ran as well. http://simplicity.elitecaraudio.org/me56.JPG http://simplicity.elitecaraudio.org/me57.JPG here is a brighter pic to give you a closer look at the wiring leading to the A5 http://simplicity.elitecaraudio.org/me58.JPG Link to comment Share on other sites More sharing options...
16psibrick Posted June 24, 2008 Author Share Posted June 24, 2008 then, the A4 4 channel was installed, this amp is briedged and powers the midbasses with about 250 watts rms. http://simplicity.elitecaraudio.org/me59.JPG and the wiring: http://simplicity.elitecaraudio.org/me60.JPG and then, we skip a head a few more steps...and now the sub and the DSP6 are wired up as well, so this is the raw install finished, wihtout any of the top cosmetic panels: http://simplicity.elitecaraudio.org/me61.JPG http://simplicity.elitecaraudio.org/me62.JPG http://simplicity.elitecaraudio.org/me63.JPG so naturally, the next thing to do is to make the top floor... first, a piece was cut with the opening shaped the way i wanted, and apiece of plexi was routed to match the opening: http://simplicity.elitecaraudio.org/me64.JPG the mdf piece was then slant routed and sanded, and opening was cut onto the upper right hand corner for my logo http://simplicity.elitecaraudio.org/me65.JPG then, two side pieces were built matching the shape of hte stock foam floor pieces...here is everything back together in the car before vinyling: http://simplicity.elitecaraudio.org/me66.JPG so next, the main MDF floor piece: http://simplicity.elitecaraudio.org/me67.JPG was covered in black CF vinyl as well: http://simplicity.elitecaraudio.org/me68.JPG the piece of clouded plexi attached: http://simplicity.elitecaraudio.org/me69.JPG and the led strips were attached to the outside edges and then black tape was put down to prevent any light "leakage" http://simplicity.elitecaraudio.org/me70.JPG so this basically is where i stopped taking pics of hte progress in the back, as you can pretty well imagine, the two side little pieces were covered in black vinyl as well, and thats it...time to move onto the front. Link to comment Share on other sites More sharing options...
16psibrick Posted June 24, 2008 Author Share Posted June 24, 2008 so...onto the front stage construction...and here i got really lazy with the camera so i apologize in advance. i was determined to make the biggest kicks possible given the space and cosmetic restrictions, to make for the smoothest midbass extension...so a relatively large back mold was taken, integrating the stock kick panel pieces into them: http://simplicity.elitecaraudio.org/me71.JPG here is the mold out of hte car after drying overnight: http://simplicity.elitecaraudio.org/me72.JPG then the baffle was trimmed and some dampening attached: http://simplicity.elitecaraudio.org/me73.JPG two MDF baffles with flush mount rings were carefully aimed and attached to the back molds: http://simplicity.elitecaraudio.org/me74.JPG and here again, skipping a few steps where mold cloth was attahced, and resined and reinforced, here are the kicks, ready to covered in black suede: http://simplicity.elitecaraudio.org/me75.JPG the Seas mid is wired up and ready to go: http://simplicity.elitecaraudio.org/me76.JPG i covered the kicks with black suede, and did a silver CF vinly trim around the speakeres, and here is passenger side kick pretty much finished. http://simplicity.elitecaraudio.org/me77.JPG and of course the same thing with the driver side: http://simplicity.elitecaraudio.org/me78.JPG http://simplicity.elitecaraudio.org/me79.JPG and finally, a two piece grille was made to protect and hide the speakres: http://simplicity.elitecaraudio.org/me80.JPG Link to comment Share on other sites More sharing options...
16psibrick Posted June 24, 2008 Author Share Posted June 24, 2008 now unto the tweeter mounts. first, a ring baffle was carefully aimed and attached tot he stock A pillar: http://simplicity.elitecaraudio.org/me81.JPG then mold cloth was used and resined: http://simplicity.elitecaraudio.org/me82.JPG and finally, bondoed and sanded smooth, ready to be wrapped: http://simplicity.elitecaraudio.org/me83.JPG a major issue was trying to find a matching material for the stock A pillar, its this beigeish color and essentially grille cloth, i went through distributor after distributor, no one carried it, so i decided to try something a bit risky, but worth the effort, and that is, to carefully peel off the stock material, and rewrap the new panel with it, hoping that i can line it up correctly and that it stretches enough to cover the new, bulging shape... so here it goes: http://simplicity.elitecaraudio.org/me84.JPG and the first onetook a coupla tries but in the end, i managed to make it work http://simplicity.elitecaraudio.org/me85.JPG tweeter mounted and ready to go! http://simplicity.elitecaraudio.org/me86.JPG and the other one as well: http://simplicity.elitecaraudio.org/me87.JPG took a while but now i have a perfect match to the stock headliner material while i was at it, i decided to make my seas reference tweeter a little different, i took a sponge brush, eld the tweeter upside down, and stubbled it into a silver metalic color...one of those "i am bored, what can i do now" kind of deals hehe but i do beleive i have the only pair of silver Seas reference tweeters around? finally, the top floor covering panel was made, its a piece of 1/4" mdf with grille mesh secured on top, the wood was covered with black CF vinyl on the bottom side, and the part where the mesh is seen through the opening is covered with black grille cloth: http://simplicity.elitecaraudio.org/me88.JPG here is hwat it looks like from the bottom side, and then the top side was wrapped again with factory matching carpet http://simplicity.elitecaraudio.org/me89.JPG okay, so this basically is all the buildup pics that i have...sorry that i missed quite a few steps here and there but hopefully you can fill in the gaps yourself hehe Link to comment Share on other sites More sharing options...
16psibrick Posted June 24, 2008 Author Share Posted June 24, 2008 Finally, lets take a look at what all the work has amassed to, I wont be explaning anything here, and will just let the pics do the talking. Sorry about my crappy camera if the lighting seems off or is blurry…thanks! http://simplicity.elitecaraudio.org/lgt1.JPG http://simplicity.elitecaraudio.org/lgt2.JPG http://simplicity.elitecaraudio.org/lgt3.JPG http://simplicity.elitecaraudio.org/lgt4.JPG http://simplicity.elitecaraudio.org/lgt5.JPG http://simplicity.elitecaraudio.org/lgt6.JPG http://simplicity.elitecaraudio.org/lgt7.JPG http://simplicity.elitecaraudio.org/lgt8.JPG http://simplicity.elitecaraudio.org/lgt9.JPG http://simplicity.elitecaraudio.org/lgt10.JPG Link to comment Share on other sites More sharing options...
16psibrick Posted June 24, 2008 Author Share Posted June 24, 2008 http://simplicity.elitecaraudio.org/lgt11.JPG http://simplicity.elitecaraudio.org/lgt12.JPG http://simplicity.elitecaraudio.org/lgt13.JPG http://simplicity.elitecaraudio.org/lgt14.JPG http://simplicity.elitecaraudio.org/lgt15.JPG http://simplicity.elitecaraudio.org/lgt16.JPG http://simplicity.elitecaraudio.org/lgt17.JPG http://simplicity.elitecaraudio.org/lgt18.JPG http://simplicity.elitecaraudio.org/lgt19.JPG http://simplicity.elitecaraudio.org/lgt20.JPG http://simplicity.elitecaraudio.org/lgt21.JPG http://simplicity.elitecaraudio.org/lgt22.JPG and finally, a quick video of the LEDs cylcing through their colors http://www.icixsound.com/iv/view_video.php?viewkey=c0c690931222ff4467bb thats all folks Link to comment Share on other sites More sharing options...
rao Posted June 24, 2008 Share Posted June 24, 2008 That's abbreviated As always your work looks top notch. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
ean611 Posted June 24, 2008 Share Posted June 24, 2008 Gorgeous install!! Looks like you don't have to worry about door acoustics with kick panels Link to comment Share on other sites More sharing options...
biz77 Posted June 24, 2008 Share Posted June 24, 2008 Bing, looks great as usual. I'm happy you were able to get the original a-pillar fabric back-on, but sorry you weren't able to find a suitable replacement. I'm still rolling with the black micro-suede, but have grown to like it. Link to comment Share on other sites More sharing options...
el5y Posted June 24, 2008 Share Posted June 24, 2008 Nice Install! But your windshield is cracked Link to comment Share on other sites More sharing options...
snowfiend Posted June 24, 2008 Share Posted June 24, 2008 man, those front kick panel speakers would be broken within a week in my car haha Link to comment Share on other sites More sharing options...
dragonman586 Posted June 24, 2008 Share Posted June 24, 2008 Awesome work man! Link to comment Share on other sites More sharing options...
16psibrick Posted June 24, 2008 Author Share Posted June 24, 2008 man, those front kick panel speakers would be broken within a week in my car haha now thats a statement i have herad time and again, yet i have built over 200 pairs and have never had one broken by a foot... to get an idea how strong it is, i can stand my 200lb body on it and it will hold fine, if your foot can kick through 14 guage steel mesh on the grilles, then you must be doing it on purpose by aiming at it and stomping at it hehe... its one of hte most durable parts of a stereo install acutally... Link to comment Share on other sites More sharing options...
snowfiend Posted June 24, 2008 Share Posted June 24, 2008 now thats a statement i have herad time and again, yet i have built over 200 pairs and have never had one broken by a foot... to get an idea how strong it is, i can stand my 200lb body on it and it will hold fine, if your foot can kick through 14 guage steel mesh on the grilles, then you must be doing it on purpose by aiming at it and stomping at it hehe... its one of hte most durable parts of a stereo install acutally... never would have thought that Link to comment Share on other sites More sharing options...
16psibrick Posted June 25, 2008 Author Share Posted June 25, 2008 the worst abuse a pair of kicks i built ever took was in my first car, a toyota truck all jacked up, used to go off roading in the mud, snow, and soetimes the entire grille would be literally covered one or both lol...rest my foot on it sometime, three years with that, just oince in a while took the grille off at hte carwash and pressure washed it, wiped off the speaker, good to go Link to comment Share on other sites More sharing options...
16psibrick Posted June 25, 2008 Author Share Posted June 25, 2008 Bing, looks great as usual. I'm happy you were able to get the original a-pillar fabric back-on, but sorry you weren't able to find a suitable replacement. I'm still rolling with the black micro-suede, but have grown to like it. yeah, that was a last ditch thing, thank god the stock glue they used was easy to peal off...i think if i couldnt have dont that i would have prolly used hipoint black vinyl to mwatch the doors and dash... Link to comment Share on other sites More sharing options...
scooby600 Posted June 25, 2008 Share Posted June 25, 2008 Very professional looking, btw my windshield is cracked in that same spot. Link to comment Share on other sites More sharing options...
MaStaMooN Posted June 25, 2008 Share Posted June 25, 2008 Mine TOO! Starts a little higher.. but in the same area... flipping weird! Nice install! Jon - vBGarage Profile Link to comment Share on other sites More sharing options...
str8dwn Posted June 27, 2008 Share Posted June 27, 2008 Always impressive, thanks for sharing. If only I could afford to ship my ride to you AND for you to do the work. The level of detail certainly puts you in a class of your own. Link to comment Share on other sites More sharing options...
Town Posted June 28, 2008 Share Posted June 28, 2008 now thats a statement i have herad time and again, yet i have built over 200 pairs and have never had one broken by a foot... to get an idea how strong it is, i can stand my 200lb body on it and it will hold fine, if your foot can kick through 14 guage steel mesh on the grilles, then you must be doing it on purpose by aiming at it and stomping at it hehe... its one of hte most durable parts of a stereo install acutally... Very very well done, Bing. Yes, Curiosly, what did you use for the grilles? I'm in the process of a 4" 3way kick install on myLGT 5MT and am NOT confident in the grilles that come with the Focals. As in, 2lbs will likely dent them... I want to use something else, but don't know what to make or order. Any advice on what you used? Thanks! btw, if you're interested in selling and shipping a 4" version of those kicks... Link to comment Share on other sites More sharing options...
16psibrick Posted June 29, 2008 Author Share Posted June 29, 2008 my grilles, regardless of the design, always features HD grille mesh on top, 16-18guage perforated mesh from mcmaster...its plenty strong...but to be honest, stock grilles that come wtih speakres, are usually strong enough to hold out, unless someone really stomps on them on purpose Link to comment Share on other sites More sharing options...
