hodgeee Posted January 21, 2005 Share Posted January 21, 2005 Well, found a new issue, and talked to Perrin and Cobb about it today. It turns out that if you are going to run a turbo back exhaust system, and you have done the up-pipe on our Legacy's, that you do the 2.2K resistor mod to the up-pipe instead of leaving the EGT sensor in. While attempting to use my cruise control, like clockwork at 15 minutes the check engine light would come on, and the cruise control light would flash and not turn off. The car gave a P0546 cel for the EGT reading being to low temperature. It turns out without any cats or reduced cats in the system, that the exhaust temperatures run much lower in the vehicle, and this throws the cell. Now for some reason it only happens when the cruise control is on. I have done the resistor mod and now my cruise control works fine. And Cobb tuning stated that they will have that Cell turned off in future maps. This also is a very common problem with WRX and STI owners from reading other reviews on nosaic and what not. Just throwing this out there so no one else has to worry about running into this! Link to comment Share on other sites More sharing options...
JGR Posted January 21, 2005 Share Posted January 21, 2005 Good to know, thanks! -JGR Link to comment Share on other sites More sharing options...
Rexmobbin Posted January 21, 2005 Share Posted January 21, 2005 thanks man, good thing i don't utilize my CC at all. was this an apparent issue in the WRX? i'm sure i used the CC then with the mentioned mods with no CEL Link to comment Share on other sites More sharing options...
driggity Posted January 21, 2005 Share Posted January 21, 2005 It could definitely happen on the WRX (although it seemed to happen plenty to people not using the CC) and is the reason why many aftermarket up-pipes don't include a bung for the stock EGT sensor. Link to comment Share on other sites More sharing options...
KGreb Posted January 21, 2005 Share Posted January 21, 2005 I'm guessing not as big an issue on the WRX as they have a mechanical throttle. We have electronic throttles so the cruise control has to be programmed with more safety in mind. Link to comment Share on other sites More sharing options...
rao Posted January 21, 2005 Share Posted January 21, 2005 It is not related to the cruise control. The exhaust changes cause the lower temps and once the code is thrown and the cruise control blinks whenever the check engine light is on. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
hodgeee Posted January 21, 2005 Author Share Posted January 21, 2005 They said that the cruise control, was one of the problems, but just in general the egt sensor could cause a lot of problems. Mine was to the CC, as some had experienced, others would get all kinds of crazy problems. I guess it just pretty much turns out, if you do the up-pipe, do the resister mod PERIOD!!!!!!! Link to comment Share on other sites More sharing options...
2Simpletons Posted January 21, 2005 Share Posted January 21, 2005 Yes, I have an uppipe with no bunghole, hehe. I called COBB adn they said I still needed to do the resistor mod. So I did and all is well. Link to comment Share on other sites More sharing options...
Jaxx Posted January 22, 2005 Share Posted January 22, 2005 yup the sensor in my WRX died ~4 months after i gutted the uppipe honestly i am suprised that any one sells and uppipe with a sensor bung ... Link to comment Share on other sites More sharing options...
