RangerMan Posted April 7, 2008 Share Posted April 7, 2008 I have been toying with the idea of putting in some subframe connectors on my car (probably weld in some 2" square tubing). Has anyone done the same? Any pictures? Link to comment Share on other sites More sharing options...
rao Posted April 7, 2008 Share Posted April 7, 2008 Why? I have never seen anyone try that with a Legacy. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
RangerMan Posted April 7, 2008 Author Share Posted April 7, 2008 Short and stupid answer...so I can jack up the car in 10 seconds on each side. (also get the other subframe benefits like stiffer chassis). I need to pull the plastic off and see if there are decent spots to weld them in that don't involve cutting apart my floorpans (which is what I plan on doing with the Mercury project). Link to comment Share on other sites More sharing options...
rao Posted April 7, 2008 Share Posted April 7, 2008 Actually that is a great reason Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
praedet Posted April 7, 2008 Share Posted April 7, 2008 Post pics!!! Link to comment Share on other sites More sharing options...
RangerMan Posted April 7, 2008 Author Share Posted April 7, 2008 I'll need to do it first! If/When I do I will definitely post some pics! Got the idea when I went to a track weekend and my friend needed to check out his suspension bolts, etc. under the car. He had each side jacked up in about 3 pumps. Whenever I need to do brakes or rotate tires I swear that it takes me at least 10 minutes of foolin' around before I get the car jacked up and on stands. I think it took my friend 90 seconds. Link to comment Share on other sites More sharing options...
rao Posted April 7, 2008 Share Posted April 7, 2008 If you can live without the chassis stiffening (which I suspect will be none ) this type of thing might work well for you: http://liftbars.com/ Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
enthusiast Posted April 8, 2008 Share Posted April 8, 2008 ^^^ That is genius! My mod list Link to comment Share on other sites More sharing options...
tomfohr15 Posted April 8, 2008 Share Posted April 8, 2008 If you can live without the chassis stiffening (which I suspect will be none ) this type of thing might work well for you: http://liftbars.com/ Weld some of those on and you've got some nice rock sliders! Sorry, I've also got a Jeep. Link to comment Share on other sites More sharing options...
RangerMan Posted April 8, 2008 Author Share Posted April 8, 2008 Those lift bars are pretty cool. But I think some subframes would be cooler. They are also the best beginner welding job you can do because no one will ever see your work :-) (FWIW I have had about 80 hours of welding experience but never welded on a car, on my back, with the work only 18" from my face...so I will probably do the '64 Mercury first to learn on) Link to comment Share on other sites More sharing options...
Vimy101 Posted April 8, 2008 Share Posted April 8, 2008 Whenever I need to do brakes or rotate tires I swear that it takes me at least 10 minutes of foolin' around before I get the car jacked up and on stands. I think it took my friend 90 seconds. This takes longer than 90 seconds but I use my cordless drill (14.4v) to jack up the car. The 19mm socket for the lug nuts fits over the end of the OEM scissor jack. Once the car is up, place the jack stand, reverse the drill to lower the jack for the next corner and repeat. Major time saver. Use the drill to spin on/off the nuts. I can change/rotate the tires (back to front/one side at a time) in ~30 minutes. Link to comment Share on other sites More sharing options...
harman.khinda Posted April 8, 2008 Share Posted April 8, 2008 Vimy you are an f'n genius! Link to comment Share on other sites More sharing options...
ebpda9 Posted April 8, 2008 Share Posted April 8, 2008 This takes longer than 90 seconds but I use my cordless drill (14.4v) to jack up the car. The 19mm socket for the lug nuts fits over the end of the OEM scissor jack. Once the car is up, place the jack stand, reverse the drill to lower the jack for the next corner and repeat. Major time saver. Use the drill to spin on/off the nuts. I can change/rotate the tires (back to front/one side at a time) in ~30 minutes. is that cordless drill also a Spec B ? Link to comment Share on other sites More sharing options...
rao Posted April 8, 2008 Share Posted April 8, 2008 Does it emit GG? Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
Vimy101 Posted April 8, 2008 Share Posted April 8, 2008 is that cordless drill also a Spec B ?Ryobi set on slow speed (i.e. "driver" not "drill"). Link to comment Share on other sites More sharing options...
Vimy101 Posted April 8, 2008 Share Posted April 8, 2008 Does it emit GG?Yes, during the charging sequence but it depends upon the electricity source e.g. Nuke vs coal fired vs peak load NG. Link to comment Share on other sites More sharing options...
RangerMan Posted April 8, 2008 Author Share Posted April 8, 2008 My floor jack brings each wheel up in 3 pumps. But getting a whole side up in 3 pumps and getting the jack stands in place is so much easier than fooling around with each corner. Link to comment Share on other sites More sharing options...
bobo69 Posted April 9, 2008 Share Posted April 9, 2008 why dont you go front and to back instead of side to side? Link to comment Share on other sites More sharing options...
Deer Killer Posted April 9, 2008 Share Posted April 9, 2008 So is my car extra stiff or what? I jack up both wheels with either side jack point. *shrug* Link to comment Share on other sites More sharing options...
Beanboy Posted April 9, 2008 Share Posted April 9, 2008 So is my car extra stiff or what? I jack up both wheels with either side jack point. *shrug* That's Spec B like! -B http://www.standardshift.com Link to comment Share on other sites More sharing options...
Vimy101 Posted April 9, 2008 Share Posted April 9, 2008 why dont you go front and to back instead of side to side?I do. One side at a time. My description wasn't clear. Link to comment Share on other sites More sharing options...
bobo69 Posted April 10, 2008 Share Posted April 10, 2008 you can jack up the whole front end with the front cross member and the whole rear with the diff i can have my car in the air in less than 2 min. which leaves the four jack points open for jack stands Link to comment Share on other sites More sharing options...
