BigT Posted March 25, 2008 Share Posted March 25, 2008 So I was messing with another car today and I was wondering where I was supposed to be shifting. If I'm starting from a rolling start, do I shift at red line or where the max power was put out on my dyno reading? Also, as a side note, my max power on the dyno sheet was at 5200 rpm in 3rd gear. Is it the same in all the gears, and the same max power in all gears? For example, if I had 250whp in 3rd would I have 250whp in my max output in 1st? Link to comment Share on other sites More sharing options...
Scotty Posted March 25, 2008 Share Posted March 25, 2008 Ideally, the shift should occur so that when you engage the next year, it rpm is at the peak torque. Link to comment Share on other sites More sharing options...
Gire Posted March 25, 2008 Share Posted March 25, 2008 Ideally, the shift should occur so that when you engage the next year, it rpm is at the peak torque. I knew it! The Legacy GT actually can travel thru time!!! It's that fast!!!1 Link to comment Share on other sites More sharing options...
RangerMan Posted March 25, 2008 Share Posted March 25, 2008 You shift BEYOND where the max power is generated. That way when you shift into the next gear you won't have lost much RPM. Link to comment Share on other sites More sharing options...
BigT Posted March 25, 2008 Author Share Posted March 25, 2008 You shift BEYOND where the max power is generated. That way when you shift into the next gear you won't have lost much RPM. Ah... So at redline? Link to comment Share on other sites More sharing options...
RangerMan Posted March 25, 2008 Share Posted March 25, 2008 Yes Link to comment Share on other sites More sharing options...
Spec B Posted March 25, 2008 Share Posted March 25, 2008 Good info here. http://www.legacygt.com/forums/showthread.php?t=56469&highlight=shift+points Link to comment Share on other sites More sharing options...
LittleBlueGT Posted March 25, 2008 Share Posted March 25, 2008 You want the average hp in the gear range you are using to be the highest. This almost always means above peak hp. Assuming the hp curve looks symmetrical you would shift at the rpm above peak hp that causes the next gear to be at the same rpm difference below peak hp. That is on over-simplification, but I hope it helps. Full tune of 68HTA, KSTech 73 MAF, Racer X FMIC and ID1000s................by the DataLog Mafia!!! Link to comment Share on other sites More sharing options...
Tuned200 Posted March 27, 2008 Share Posted March 27, 2008 Yes Have you ran your car? MY car made 263awhp before the cbe install and if I shift at redline, i am slower than shifting at 6000 in 1st and 2nd, 6200 in 3rd. Those shift point netted me 12.95@106.6 Yes, I have well over 500 tripsdown the 1320, with about 65 in the lgt. Link to comment Share on other sites More sharing options...
RangerMan Posted March 27, 2008 Share Posted March 27, 2008 No, I haven't run on a dragstrip before. I always shifted at or near redline if I was running hard. You are much more well versed in drag racing than I so I'll defer to your answer. Dipping into the 12s is always a great time to celebrate. Those are some nice numbers! In my (feeble) defense...the OP asked if he should shift at redline or where the dyno runs max power was generated (5200 in his case)...and given those two choices the answer would be redline. Link to comment Share on other sites More sharing options...
Infamous1 Posted March 27, 2008 Share Posted March 27, 2008 I will only reline first at the strip and that is only because it comes so fast. Keep the shifts around 6000rpms with a max of 6300rpms, that has netted me the best results. After 4800rpms or so the psi is dropping off HARD on the stock vf40. Link to comment Share on other sites More sharing options...
BigT Posted March 27, 2008 Author Share Posted March 27, 2008 Have you ran your car? MY car made 263awhp before the cbe install and if I shift at redline, i am slower than shifting at 6000 in 1st and 2nd, 6200 in 3rd. Those shift point netted me 12.95@106.6 Yes, I have well over 500 tripsdown the 1320, with about 65 in the lgt. Thanks! I'm assuming you're stage II. How did you arrive at those numbers? Guess and check? Link to comment Share on other sites More sharing options...
Ridgeracer Posted March 27, 2008 Share Posted March 27, 2008 I will only reline first at the strip and that is only because it comes so fast. Keep the shifts around 6000rpms with a max of 6300rpms, that has netted me the best results. After 4800rpms or so the psi is dropping off HARD on the stock vf40. Alway thought you ran a larger than stock turbo... "Gimme mines Balboa...Gimme mines".....Clubber Lang - Mr. T Link to comment Share on other sites More sharing options...
Infamous1 Posted March 27, 2008 Share Posted March 27, 2008 Alway thought you ran a larger than stock turbo... Not yet, I just know figures for tons of them;) Link to comment Share on other sites More sharing options...
GTTuner Posted March 27, 2008 Share Posted March 27, 2008 I will only reline first at the strip and that is only because it comes so fast. Keep the shifts around 6000rpms with a max of 6300rpms, that has netted me the best results. After 4800rpms or so the psi is dropping off HARD on the stock vf40. ^^^^Exactly how I shifted with the stock turbo. Now I will hold 1st to almost 7K, then 6500 in 2nd, 6000 in third. Shifting at 6k in third nets a rush of speed in 4th. Link to comment Share on other sites More sharing options...
Tuned200 Posted March 28, 2008 Share Posted March 28, 2008 Thanks! I'm assuming you're stage II. How did you arrive at those numbers? Guess and check? basic stage 2 tdc map aem cai perrin catted dp mr cat back invidia up pipe cobb crank pulley After looking at my dyno graph, thats when I decided to keep the rpms down. I tried flat foot shifting, but it didnt work out to well. Stupid stock clutch Link to comment Share on other sites More sharing options...
