tahoegt Posted March 19, 2008 Posted March 19, 2008 Going with Goodridge SS lines and Carbotech pads but not really sure which fluid to go with. The mechanic has ATE, but a buddy of mine loves the RBF 600. Probably not going to the track, and I live where it's very cold in the winter and hot in the summer with very low humidity. Well?
t0ad Posted March 19, 2008 Posted March 19, 2008 Honestly, I'd just go to Advance or Autozone and grab some Valvoline. That's what I plan on doing when I put my Goodridge lines on here soon. An EVO buddy of mine has tried them all and prefers OEM or Valvoline synth stuff for street driving. Doesn't seem worth the extra money for the 'racing' spec fluids for a daily driver to me, and I've heard they absorb moisture faster as well. This could be BS of course, I don't know
Jim_KT Posted March 20, 2008 Posted March 20, 2008 on using Valvoline's synthetic brake fluid. Cheap, readily availble and from what I've read, performs really well.
Boostjunkie Posted March 21, 2008 Posted March 21, 2008 +2. We have successfully used Valvoline Synpower even on cars that see a good amount of track time. It is so close in performance to the super high buck stuff that you will never be able to tell the difference. Your wallet will definitely know the difference though.
cleaver Posted March 21, 2008 Posted March 21, 2008 Sorry to disappoint you guys, but I think Synpower Brake Fluid has been discontinued. I just flushed my system with it but can't find it anymore, and a web search of various other boards indicates Valvoline has discontinued the whole Synpower line. Sorry :-(
bugblatterbeast Posted March 21, 2008 Posted March 21, 2008 Go with the ATE if you need to pick one of the two. I've used both in really cold conditions (-40c). The brakes will release better with the ATE + ATE is pretty reasonably priced ($14/liter last I checked)
Xenonk Posted March 21, 2008 Posted March 21, 2008 there's nothing bad for running RBF600 at all.. it has a higher wet boiling point, so it will eventually not feel as squishy as time goes on due to the fluid retaining moisture. When the fluid retains moisture (ie water) and you super heat the water molecules, you end up creating more water vapors, which is more compressable hence the soft pedal feel. Keefe
MiniStiGuy Posted March 21, 2008 Posted March 21, 2008 + infinity on the valvoline. http://i26.tinypic.com/seorva.jpg OEM HID's Rx330 Retro
t0ad Posted March 21, 2008 Posted March 21, 2008 Hmm, looks like they did kill the SynPower line, all i can find now is regular valvoline synthetic. Wonder if it's actually any different? http://www.valvoline.com/pages/products/product_detail.asp?product=138
RaceComp Engineering Posted March 21, 2008 Posted March 21, 2008 If you're not tracking your car, ATE is great, cheap, and easy to bleed, or just get the Valvoline Synthetic. - Andrew
f1anatic Posted March 21, 2008 Posted March 21, 2008 I have ATE superblue and I have noticed my brake fade to be less. I do not track the car nor did I change the brake pads at the time of bleeding my brakes. I considered it a noticeable improvement in regards to brake feel during daily driving. I attribute it solely to the fluid.
tahoegt Posted March 21, 2008 Author Posted March 21, 2008 Thanks for the input everyone. Mechanic stocks ATE so I think I'ss go with that since no one really has anything bad to say.
Saul_Good Posted March 22, 2008 Posted March 22, 2008 I'm going to be using Prospeed GS610 fluid in April. I've been using Motul RBF600 and figured i'd give this a try.
jim1969 Posted September 23, 2009 Posted September 23, 2009 I'm going to be using Prospeed GS610 fluid in April. I've been using Motul RBF600 and figured i'd give this a try. how did they compare?
system60 Posted September 23, 2009 Posted September 23, 2009 funny just got my car back from my Mechanic, had him do the brakes since I was unable to brake the caliper bolts free (car's from MA) Was having him do brakes/lines/fluid, tranny fluid, oil change and he was busting my balls about the blue brake fluid, yellow tranny fluid in Bathroom cleaner bottles (ExtraS from fredbeans). All I needed was if I still had any of the Green German castrol left.
AZP Installs Posted September 28, 2009 Posted September 28, 2009 I have the Motul in my CTS-V (Had to have it put in at a track day) I have always ran ATE Superblue in our race cars and street car. Recently moved over to Amsoil Racing Brake Fluid (To give it a try). Here are my thoughts.... Motul is on par or slightly below the ATE Superblue, not worth the extra $ IMO. Amsoil Racing Fluid is on par or slightly better than superblue at a price on par with the Superblue. Conclusion is that we'll be using the Amsoil and ATE Superblue (alternating between the 2) on both our own and our customer's cars. -mike
