15devils Posted February 23, 2008 Share Posted February 23, 2008 hey guys I wanna change the vf38 I have in my car...anyone knows if the vf36 from the spec c would bolt up straight ? seeing that i'm already running twinscroll.Would I have to change the manifold/injectors,or the lgt one would work back? Link to comment Share on other sites More sharing options...
2005garnetGT Posted February 23, 2008 Share Posted February 23, 2008 no it won't Link to comment Share on other sites More sharing options...
b4rsk2003 Posted February 24, 2008 Share Posted February 24, 2008 You will need to change your turbo inlet hose, downpipe, uppipe and extractors obtained from a twin scroll STI. Injectors must be upgraded before tuning on the 36. Link to comment Share on other sites More sharing options...
nekdut Posted February 24, 2008 Share Posted February 24, 2008 You do not have to change your turbo inlet. Outlet is a different story. You can get by with stock LGT injectors, but 650s or higher will yield better gains. Link to comment Share on other sites More sharing options...
15devils Posted February 25, 2008 Author Share Posted February 25, 2008 okay so what would be a good twin scroll upgrade from the vf38..I tried searching but got nothin. Link to comment Share on other sites More sharing options...
nekdut Posted February 25, 2008 Share Posted February 25, 2008 For a pure bolt-on upgrade, I believe your only choice is a TD04HLA-19T-8.5. Hopefully there will be a series of upgrades coming soon since the JDM Impreza S-GT shares the same turbo configuration as the JDM 2.0 LGT. Link to comment Share on other sites More sharing options...
15devils Posted February 25, 2008 Author Share Posted February 25, 2008 so the jdm impreza uses a vf38 twinscroll as well ? Link to comment Share on other sites More sharing options...
StylesJM Posted February 26, 2008 Share Posted February 26, 2008 For a pure bolt-on upgrade, I believe your only choice is a TD04HLA-19T-8.5. Hopefully there will be a series of upgrades coming soon since the JDM Impreza S-GT shares the same turbo configuration as the JDM 2.0 LGT. Hopefully....... Link to comment Share on other sites More sharing options...
JALEGACY Posted March 6, 2008 Share Posted March 6, 2008 There is a thread on the forum called - "How to Install a VF39" or something like that which may help you. It seems that you can modify the turbo to fit and using a connector pipe. Link http://legacygt.com/forums/showthread.php?t=39164&highlight=install+VF39 Have fun. Link to comment Share on other sites More sharing options...
mickeyd2005 Posted March 6, 2008 Share Posted March 6, 2008 so the jdm impreza uses a vf38 twinscroll as well ? No, it uses an MHI turbo. However, I heard that it is compatible with the JDM LGT intercooler and exhaust pipes. It's probably similar to the TD04HLA-19T but smaller. Link to comment Share on other sites More sharing options...
Boxer Boy Posted June 26, 2009 Share Posted June 26, 2009 So i don't really know to much at all but apparently the vf44 is the same as the TD04HLA-19T and both are listed a replacements for the vf38, and suppose to give a bit more topend, weather or not this is true and or any mods are needed at all i don't know? I'm looking for an up grade to for my lgt after my vf38 let go after 112,000 klm's ? and didn't see the point of going stock, cos thats boring compaired to more hp, oh and the local subie dealer wanted $7100 for just the new turbo, ( i did't see the funny side of that, i can tell you.) Link to comment Share on other sites More sharing options...
Guest Posted June 26, 2009 Share Posted June 26, 2009 Where are you located Boxer Boy? Link to comment Share on other sites More sharing options...
Underdog Posted June 26, 2009 Share Posted June 26, 2009 Wow I hope that's not true... I just paid $100 more for a td04hla-19t on ebay than a for a vf44. Do you have a source for that info? I though vf turbos were IHI and the td04 was a mitsu. The Crimson Dynamo Link to comment Share on other sites More sharing options...
Guest Posted June 26, 2009 Share Posted June 26, 2009 Underdog - Mitsu is bigger than vf44, don't worry. Link to comment Share on other sites More sharing options...
mickeyd2005 Posted June 26, 2009 Share Posted June 26, 2009 The VF44 is the twinscroll equivalent of the VF46. It uses the same wheels as the VF38/VF40. The compressor housing is pinched like the VF46. Since the VF46 only makes a hair more power than the VF40, I think the VF44 probably is similar to the VF38 in the same way. I believe the more recent LGT turbos are the VF45 and VF47. The TD04HLA-19T uses a larger compressor wheel and turbine wheel and has a larger turbine housing than the VF38/VF44/VF45. These turbos can be found on eBay for between $500 to $800. Link to comment Share on other sites More sharing options...
Boxer Boy Posted July 6, 2009 Share Posted July 6, 2009 Where are you located Boxer Boy? FS (MA): JDM LGT twinscroll VF44 turbo & header/uppipe ... what a deal! this was one of the threads i was reading, i can't find the others ( sorry if i was miss leading or just miss understood) i live in Brisbane Australia, so i currently have a silver GT wagon as drive way ornament ( oh and a grumpy missus that wants her car back ) so if you where to upgrade to a vf44 or a tdo4 hla 19t would you need to retune the car or will the car ecu be able to cope with the change? Link to comment Share on other sites More sharing options...
mickeyd2005 Posted July 6, 2009 Share Posted July 6, 2009 I don't consider the VF44 an upgrade over the VF38. It's more of a replacement. However, you can not just swap turbos without re-tuning boost. Subaru uses a variety of actuator sizes and restrictor pill sizes. It's doubtful that the VF38 and VF44 uses the same actuator and pill. In the US, when SOA made the equivalent change from VF40 to VF46, they change the actuator and pill size. You can always attach the hose directly from the compressor nipple to the actuator until you get a chance to tune the boost. Link to comment Share on other sites More sharing options...
Boxer Boy Posted July 7, 2009 Share Posted July 7, 2009 so in basic terms, ditching the factory electronic boost control and go aftermarket either electronic or mechanical? thanks heaps so a td04hla 19t would be an upgrade though? and either the td04 or the vf44 are straight bolt-on up grade for the GT's, or is there a better option? sorry if this is deviating away from the thread topic, Link to comment Share on other sites More sharing options...
mickeyd2005 Posted July 7, 2009 Share Posted July 7, 2009 so in basic terms, ditching the factory electronic boost control and go aftermarket either electronic or mechanical? thanks heaps so a td04hla 19t would be an upgrade though? and either the td04 or the vf44 are straight bolt-on up grade for the GT's, or is there a better option? sorry if this is deviating away from the thread topic, I never said anything about ditching the factor control. Just tune it. Romraider can tune JDM LGTs. I'm fairly sure the TD04HLA-19T is an upgrade. I've compared the wheels side by side to a VF38/VF40 and both wheels are significantly larger. The only thing that might be better is the turbo that comes in the new SGT but I don't know anything about it other than the pipes are the same as the JDM LGT. Link to comment Share on other sites More sharing options...
MGV101 Posted July 7, 2009 Share Posted July 7, 2009 itching to upgrade my VF44 in due time too :subscribe: Link to comment Share on other sites More sharing options...
JMLegacy Posted January 16, 2013 Share Posted January 16, 2013 [bump] What would you upgrade to? Any info on the VF45 vs 38 vs 44? apart from that long page on NASIOC Link to comment Share on other sites More sharing options...
Siv Posted September 1, 2017 Share Posted September 1, 2017 bump? Would love to hear back as my VF38 is out of the way and I'm considering a TD04HLA 19t or a VF44 as they're direct bolt ons Link to comment Share on other sites More sharing options...
Andy_Mac Posted September 1, 2017 Share Posted September 1, 2017 Just get a used VF44 or VF45 for a fraction of what a new 19t costs. Even the 20t's aren't that big of an improvement over the 44/45 so not worth spending big money on one. 2000 Legacy B4 RSK - SOLD 2006 Legacy BP5 GT Spec B wagon - Garage Thread 2011 VW T5 van 2.0L of turbo diesel awesomeness Link to comment Share on other sites More sharing options...
JMLegacy Posted September 1, 2017 Share Posted September 1, 2017 bump? Would love to hear back as my VF38 is out of the way and I'm considering a TD04HLA 19t or a VF44 as they're direct bolt ons I went single scroll VF34. Best choice yet. Link to comment Share on other sites More sharing options...
