tarambuka3500 Posted February 15, 2011 Share Posted February 15, 2011 just FYI, what is shown in a metric trip-comp when plugged directly ti a US car: [ame=http://www.youtube.com/watch?v=wcOTsKeasJQ]YouTube - US Subaru Outback trip computer replaced with metric version [driving][/ame] Link to comment Share on other sites More sharing options...
Tomkat1127 Posted April 2, 2011 Share Posted April 2, 2011 Subscribed. Link to comment Share on other sites More sharing options...
tarambuka3500 Posted April 5, 2011 Share Posted April 5, 2011 I have the MPG->metric convertor almost done, thanks to the information in this thread. Hopefully this week it should be done Link to comment Share on other sites More sharing options...
tarambuka3500 Posted May 12, 2011 Share Posted May 12, 2011 all working now! Link to comment Share on other sites More sharing options...
lossol Posted May 13, 2011 Share Posted May 13, 2011 Excellent Job! So was the trick all mathematical conversion? VBG1 gauges available at www.gtboostgauge.com Link to comment Share on other sites More sharing options...
tarambuka3500 Posted May 13, 2011 Share Posted May 13, 2011 yes and no the display itself is not *universal* and can accept & show only certain values. e.g. you cant' make it show each and every value that one think should be possible, using XX.Y format. so code is a mix between mathematical conversion and additional logic to make the converted values *compatible* with the display. but at the end it all works properly. Link to comment Share on other sites More sharing options...
brou4164 Posted June 10, 2011 Share Posted June 10, 2011 Complete novice here; please go easy: Are y'all talking about modifying the programming to calculate the trip meter & MPG calculator to be more accurate? I.E. account for injector upgrades, etc? I've been hunting for a while to see what's the deal, (if this needs to be done or if the computer can adjust for said changes) because I upgraded my injectors to 1150cc & would really like accurate readings. Any and all guidance would be greatly appreciated! Link to comment Share on other sites More sharing options...
tarambuka3500 Posted June 11, 2011 Share Posted June 11, 2011 Are y'all talking about modifying the programming to calculate the trip meter & MPG calculator to be more accurate? I.E. account for injector upgrades, etc? No - we're talking about making it show the values in Liters/kilometers/celsiues (e.g. metric units) instead of MPG/miles/Fahrenheit (imperial). However what you need is also doable, if you know the mathematics e.g. if you can calculate the difference by hand, the car can be *fixed* to show the updated values. Link to comment Share on other sites More sharing options...
brou4164 Posted June 12, 2011 Share Posted June 12, 2011 Thank you for clearing all that up! I do actually know the formula in order to fix this issue... I just have no clue how to actually do it. The instant mpg is based on the injector size (520cc) and so I would just need to replace that info with my new injector size (1150cc). Do you think y'all can help? Link to comment Share on other sites More sharing options...
brou4164 Posted June 22, 2011 Share Posted June 22, 2011 Anyone? Link to comment Share on other sites More sharing options...
tarambuka3500 Posted July 17, 2011 Share Posted July 17, 2011 here's how it all works/looks first display is the metric one+convertor IC, second is the original (imperial units) [ame=http://www.youtube.com/watch?v=xEu0fNIso_M]US Subaru Outback trip computer replaced with metric version [all working!] - YouTube[/ame] finally I'll close my dash and KUDOS to CombatCQB for all the research he did!!! Link to comment Share on other sites More sharing options...
Zephrant Posted July 20, 2011 Share Posted July 20, 2011 Has anyone got this data fed in to a car pc yet? It's such a PITA to move the display, I'd rather just pull it out and then get the same data from the touch-screen. Link to comment Share on other sites More sharing options...
Zephrant Posted September 15, 2011 Share Posted September 15, 2011 Bump- Still looking to feed this in to the Car PC (Centrafuse desired, but I'd take anything). I don't want to relocate the display, but I'm tired of not having the outside temp and MPG. Anyone know of those two things are available though the OBD-II port? Link to comment Share on other sites More sharing options...
CombatCQB Posted December 29, 2011 Author Share Posted December 29, 2011 It's been a while since I've poked around this port, but I don't think the data is available on the OBD-II port. This data is from the Body Integration Unit with gathers some info from the ECU but not the other way around. Link to comment Share on other sites More sharing options...
dahoseman Posted March 2, 2013 Share Posted March 2, 2013 I ran across this thread and thought I would resurrect it. I have a modified 05 Outback XT with an onboard trip calculator that no longer reads fuel-calculated information correctly. I would be very interested in finding out how to implement changes to make the Instant MPG, AVG MPG, and range calculator more accurate. Over many trips and various manual calculation comparisons, I've found that changing stock injectors to 740CC has left the trip calculator reading at 1.48(actual) on all of accounts. Avg MPG will read ~34mpg when actual (miles/gallons) turns out to be 23mpg Range reads 510 miles to empty when actual turns out to be ~345 I have no programming experience, but I would be highly interested in learning how to make these changes Link to comment Share on other sites More sharing options...
Hoojammyflip Posted March 3, 2013 Share Posted March 3, 2013 Subscribed... Sent from my HTC Desire HD A9191 using Tapatalk 2 Link to comment Share on other sites More sharing options...
tarambuka3500 Posted March 7, 2013 Share Posted March 7, 2013 I would be very interested in finding out how to implement changes to make the Instant MPG, AVG MPG, and range calculator more accurate. Over many trips and various manual calculation comparisons, I've found that changing stock injectors to 740CC has left the trip calculator reading at 1.48(actual) on all of accounts. Avg MPG will read ~34mpg when actual (miles/gallons) turns out to be 23mpg Range reads 510 miles to empty when actual turns out to be ~345 I have no programming experience, but I would be highly interested in learning how to make these changes It can be done easily by someone with embedded-programming experience. Most of the info you need is in the thread. A small IC must intercepts the ECU feed, multiply the values by 1.48 and then feed to the display. That is all that's needed. Same as what I have in my car, just different formula. Link to comment Share on other sites More sharing options...
uncle humjaba Posted October 12, 2014 Share Posted October 12, 2014 I'm working on replacing the clock module with a couple of screens... one fed by information from the ECU (ssm) and the other from the factory trip computer (mpg, etc). I was wondering if anyone had figure out how to make the airbag light go away? Is it just a matter of jumping pins 3 and 4 to ground through a resistor? http://legacygt.com/forums/showpost.php?p=1315335&postcount=692 Also, I have everything working when I talk to SSM but I can't get useful information from the UART line. It just seems to read gibberish. See here: 248 112 80 3 240 13 87 112 80 3 248 184 80 3 248 112 80 3 240 13 87 184 160 248 112 80 3 240 13 87 184 160 248 184 80 3 240 13 87 112 80 3 248 184 160 248 112 80 3 240 13 87 184 160 248 112 80 3 240 13 87 184 160 248 184 80 3 240 13 87 112 80 3 248 184 160 248 112 80 3 240 13 87 184 160 248 112 80 3 240 13 87 184 160 248 184 80 3 240 13 87 112 80 3 248 184 160 248 112 80 3 240 13 87 184 160 248 112 80 3 240 13 87 184 160 248 184 80 3 248 112 80 3 240 13 87 184 160 248 112 80 3 240 13 87 184 160 248 184 80 3 240 13 87 112 80 3 248 184 160 248 112 80 3 240 13 87 184 160 248 112 80 3 240 13 87 184 160 248 184 80 3 248 112 80 3 248 184 160 248 112 80 3 240 13 87 184 160 248 112 80 3 240 13 87 112 80 3 248 184 80 3 240 13 87 112 80 3 240 13 87 184 160 248 112 80 3 240 13 87 184 160 248 112 80 3 240 13 87 184 160 248 184 160 248 112 80 3 240 13 87 184 160 248 112 80 3 240 13 87 184 160 248 184 80 3 240 13 87 112 80 3 248 184 160 248 112 80 3 240 13 87 184 160 248 112 80 3 240 13 87 184 160 248 184 80 3 240 13 87 112 80 3 248 184 160 248 112 80 3 240 13 87 184 160 248 112 80 3 240 13 87 184 160 248 184 80 3 240 13 87 112 80 3 248 184 160 248 112 80 3 240 13 87 184 160 248 184 80 3 240 13 87 184 160 248 184 80 3 248 112 80 3 240 13 87 184 160 248 112 80 3 240 13 87 184 160 248 184 80 3 240 13 87 112 80 3 248 184 160 248 112 80 3 240 13 87 184 160 248 112 80 3 240 13 87 184 160 248 184 80 3 240 13 87 112 80 3 240 13 87 184 160 248 112 80 3 240 13 87 184 160 It's like it pretty routinely misses some bytes. Here's my code: void setup() { // initialize serial: Serial.begin(9600); Serial1.begin(2400); } int count = 0; void loop() { if (Serial1.available()) { if (count == 9) { Serial.println(Serial1.read()); count = 0; } else { Serial.print(Serial1.read()); Serial.print("\t"); } count += 1; } } Link to comment Share on other sites More sharing options...
DonnyJagaru Posted October 15, 2014 Share Posted October 15, 2014 Watching this one...analog designer by training but can work in digital domain. Link to comment Share on other sites More sharing options...
uncle humjaba Posted October 24, 2014 Share Posted October 24, 2014 So I redid my wiring a bit and now I get this: 7 32 41 D0 41 5 6E B8 20 7 32 41 68 81 5 6E 70 10 7 32 41 D0 41 5 6E B8 20 7 32 41 68 81 5 6E 70 10 7 32 41 D0 41 5 6E B8 20 7 32 41 68 81 5 6E B8 10 7 32 41 68 41 5 6E 70 10 7 32 41 D0 41 5 6E B8 20 7 32 41 68 81 5 6E 70 10 7 32 41 D0 41 5 6E B8 20 7 32 41 68 81 5 6E B8 10 7 32 41 D0 41 5 6E 70 10 7 32 41 68 81 5 6E B8 20 7 32 41 68 41 5 6E 70 10 7 32 41 D0 41 5 6E B8 20 7 32 41 68 81 5 6E 70 10 7 32 41 D0 41 5 6E B8 20 7 32 41 68 81 5 6E B8 10 7 32 41 68 41 5 6E 70 10 7 32 41 68 81 5 6E B8 20 7 32 41 68 41 5 6E 70 10 7 32 41 D0 41 5 6E B8 20 7 32 41 68 81 5 6E 70 10 7 32 41 D0 41 5 6E 70 10 7 32 41 68 81 5 6E B8 10 7 32 41 D0 41 5 6E 70 10 7 32 41 D0 41 5 6E B8 20 7 32 41 68 41 5 6E 70 10 The car isn't running, sitting with the key in the "on" position. Any ideas on what is what? How do I know? I have it start a new line every 9th byte but how do I know where the stop is? Thanks Code is: void setup() { // initialize serial: Serial.begin(9600); Serial3.begin(2400); } int count = 0; void loop() { if (Serial3.available()) { if (count == 9) { Serial.println(Serial3.read(), HEX); count = 0; } else { Serial.print(Serial3.read(), HEX); Serial.print("\t"); } count += 1; } } Link to comment Share on other sites More sharing options...
AkumaMax Posted October 24, 2014 Share Posted October 24, 2014 I'm working on replacing the clock module with a couple of screens... one fed by information from the ECU (ssm) and the other from the factory trip computer (mpg, etc). I was wondering if anyone had figure out how to make the airbag light go away? Is it just a matter of jumping pins 3 and 4 to ground through a resistor? http://legacygt.com/forums/showpost.php?p=1315335&postcount=692 Also, I have everything working when I talk to SSM but I can't get useful information from the UART line. It just seems to read gibberish. See here: 248 112 80 3 240 13 87 112 80 3 248 184 80 3 248 112 80 3 240 13 87 184 160 248 112 80 3 240 13 87 184 160 248 184 80 3 240 13 87 112 80 3 248 184 160 248 112 80 3 240 13 87 184 160 248 112 80 3 240 13 87 184 160 248 184 80 3 240 13 87 112 80 3 248 184 160 248 112 80 3 240 13 87 184 160 248 112 80 3 240 13 87 184 160 248 184 80 3 240 13 87 112 80 3 248 184 160 248 112 80 3 240 13 87 184 160 248 112 80 3 240 13 87 184 160 248 184 80 3 248 112 80 3 240 13 87 184 160 248 112 80 3 240 13 87 184 160 248 184 80 3 240 13 87 112 80 3 248 184 160 248 112 80 3 240 13 87 184 160 248 112 80 3 240 13 87 184 160 248 184 80 3 248 112 80 3 248 184 160 248 112 80 3 240 13 87 184 160 248 112 80 3 240 13 87 112 80 3 248 184 80 3 240 13 87 112 80 3 240 13 87 184 160 248 112 80 3 240 13 87 184 160 248 112 80 3 240 13 87 184 160 248 184 160 248 112 80 3 240 13 87 184 160 248 112 80 3 240 13 87 184 160 248 184 80 3 240 13 87 112 80 3 248 184 160 248 112 80 3 240 13 87 184 160 248 112 80 3 240 13 87 184 160 248 184 80 3 240 13 87 112 80 3 248 184 160 248 112 80 3 240 13 87 184 160 248 112 80 3 240 13 87 184 160 248 184 80 3 240 13 87 112 80 3 248 184 160 248 112 80 3 240 13 87 184 160 248 184 80 3 240 13 87 184 160 248 184 80 3 248 112 80 3 240 13 87 184 160 248 112 80 3 240 13 87 184 160 248 184 80 3 240 13 87 112 80 3 248 184 160 248 112 80 3 240 13 87 184 160 248 112 80 3 240 13 87 184 160 248 184 80 3 240 13 87 112 80 3 240 13 87 184 160 248 112 80 3 240 13 87 184 160 It's like it pretty routinely misses some bytes. Here's my code: void setup() { // initialize serial: Serial.begin(9600); Serial1.begin(2400); } int count = 0; void loop() { if (Serial1.available()) { if (count == 9) { Serial.println(Serial1.read()); count = 0; } else { Serial.print(Serial1.read()); Serial.print("\t"); } count += 1; } } For your issue with the clock's airbag light the only way that I found a work around for it was to make a Y connector keeping the clock connection together and then jumping the wires out for what was needed. Link to comment Share on other sites More sharing options...
uncle humjaba Posted October 25, 2014 Share Posted October 25, 2014 So with some help I figured out the problem with the UART part - just had to pass in the instructions on the UART settings. Oops. Serial3.begin(2400,SERIAL_8E1_RXINV_TXINV); Would love to figure out a better way to fix the airbag light. Link to comment Share on other sites More sharing options...
uncle humjaba Posted November 22, 2014 Share Posted November 22, 2014 Alright, so I've got this all working pretty well. Two screens; clock and trip computer on one side, ECU info on the other. Now I just have to figure out that damned airbag light! Does nobody know how it works? Link to comment Share on other sites More sharing options...
tarambuka3500 Posted November 23, 2014 Share Posted November 23, 2014 Here is what I have as diagrams. I *might* also have my original clock display (USDM), will have to look for it -can look at the wiring inside. (If I still have it, that is) Link to comment Share on other sites More sharing options...
