BDII Posted January 25, 2008 Share Posted January 25, 2008 I have been doing my homework latley and I think I might pull the trigger this fall on TEIN's system My FLEX's are due for a rebuild and I'd like to weigh some new options. anyone have any experience with this system? I know it's basically a time saver, but on track days around here time is everything. Need forum help? Private Message legGTLT Link to comment Share on other sites More sharing options...
Knight705 Posted January 26, 2008 Share Posted January 26, 2008 from what my friend told me of his setup on his 240sx, it is very useful. even has a memory function to store preset settings. instantaneous damper adjustment. he says he doesn't want to go without it if he ever gets another coilover setup on his new car. Link to comment Share on other sites More sharing options...
1freak Posted January 26, 2008 Share Posted January 26, 2008 I have flex and efdc and they work great. I dont track the car much, but on city streets in nice to soften them up and then stiffen on the highway with a push of the button check us out here http://newenglandsubarus.com/ Link to comment Share on other sites More sharing options...
derffred Posted January 26, 2008 Share Posted January 26, 2008 How is it wired? Link to comment Share on other sites More sharing options...
MGV101 Posted January 26, 2008 Share Posted January 26, 2008 I had one my old accord but I can't talk about track experience since there isn't even a track here in HK. For street use though, I think it is very helpful during the first few months while you are still adjusting to the new suspension. There is no way that you can get the damper setting perfect on the first try and it really does take a lot of trial and error to get it right. With the EDFC, you can quickly change settings without the need of getting out of the car. Since it makes adjusting damper settings so much easier, you can me much more picky about your damper settings and use that extra time gained to fine tune your suspension even more. After the first few months though where everything had settled in, I rarely touch the EDFC unit since I have no need to adjust my damper settings anymore as it is "perfect" and the driving conditions rarely change for me. You'll need to change your suspension settings more often as you go onto different tracks. EDFC will save you time when changing such settings and will allow you to have more time for testing and to make additional adjustments. Link to comment Share on other sites More sharing options...
jim1969 Posted January 26, 2008 Share Posted January 26, 2008 can you adjust while moving or only when stopped? Link to comment Share on other sites More sharing options...
Aczwild Posted January 26, 2008 Share Posted January 26, 2008 I'll be using the Tein Flex Coilovers with the EDFC unit on the Project. I like that you can store the settings and can tweak it as you like. It will be really nice when going from track to track JDM'd All to hell Thanks Jimmy @ Hkc-Speed.com! RIP Coxx & Thanks Link to comment Share on other sites More sharing options...
MGV101 Posted January 26, 2008 Share Posted January 26, 2008 can you adjust while moving or only when stopped? it still works when you're on the move but it is not recommended. Adjusting the valves while the shocks are still moving is not good. I adjust it while the car is stopped but if you want to be absolutely safe, do it with the ignition off. Link to comment Share on other sites More sharing options...
BDII Posted January 28, 2008 Author Share Posted January 28, 2008 I have flex and efdc and they work great. I dont track the car much, but on city streets in nice to soften them up and then stiffen on the highway with a push of the button Are you gonna be around this weekend? I'll be in ********** on Friday night, and I'd love to check this out. Need forum help? Private Message legGTLT Link to comment Share on other sites More sharing options...
hayasa Posted January 28, 2008 Share Posted January 28, 2008 How much was the whole setup? Also, where did you mount the control box? I was thinking it would look great integrate into the ashtray slot... Link to comment Share on other sites More sharing options...
BDII Posted January 28, 2008 Author Share Posted January 28, 2008 I've found the unit itself is under $400 This does not include struts (obviously) I Will probably mount mine in the some where on teh center consol. Need forum help? Private Message legGTLT Link to comment Share on other sites More sharing options...
1freak Posted January 31, 2008 Share Posted January 31, 2008 Are you gonna be around this weekend? I'll be in ********** on Friday night, and I'd love to check this out. :lol: No man I wont be, another time. check us out here http://newenglandsubarus.com/ Link to comment Share on other sites More sharing options...
whitetiger Posted January 31, 2008 Share Posted January 31, 2008 I just ordered the edfc for my tien flex's. Im not sure where ill put the controller, but ive installed one before and put it in the center console. Link to comment Share on other sites More sharing options...
1freak Posted January 31, 2008 Share Posted January 31, 2008 How much was the whole setup? Also, where did you mount the control box? I was thinking it would look great integrate into the ashtray slot... for the coilovers and controller it like $1800 check us out here http://newenglandsubarus.com/ Link to comment Share on other sites More sharing options...
whitetiger Posted January 31, 2008 Share Posted January 31, 2008 less, if you buy from the right place. Link to comment Share on other sites More sharing options...
VTGT Posted January 31, 2008 Share Posted January 31, 2008 OT but is there anything like this for KW suspensions? Link to comment Share on other sites More sharing options...
BDII Posted February 1, 2008 Author Share Posted February 1, 2008 no Need forum help? Private Message legGTLT Link to comment Share on other sites More sharing options...
hayasa Posted February 7, 2008 Share Posted February 7, 2008 I just ordered the edfc for my tien flex's. Im not sure where ill put the controller, but ive installed one before and put it in the center console. How hard was the install of the controller? Also, anyone know its the dimentions? Still thinking it would fit in the ashtray slot... Link to comment Share on other sites More sharing options...
whitetiger Posted February 7, 2008 Share Posted February 7, 2008 no it wont fit in the ash tray slot, its just alittle too big IIRC. Ill be putting mine in the cubby i think. The install is easy. Its just running wires. you need a contsant power source and acc on power source and ground. acc-on comes from the cig-lighter, and the constant power on can come from the brake light circuit in the fuse box. Link to comment Share on other sites More sharing options...
