Voo Posted January 13, 2008 Share Posted January 13, 2008 I have an 06 LGT with a 5MT (as the title says), and I was wondering if anyone else has problems shifting into Reverse. This problem usually presents itself when I am initially moving in 1st (or 2nd). After coming to a complete stop, I shift to engage Reverse. Sometimes I find that the gear won't shift into the R position, and I have to re-engage 1st, creep forward for a few inches, and then trying again. Unfortunately, there have been times that I had to "creep" 3 times before I managed to engage R. Anyone else experiencing this problem, or am I doing something wrong here? Thanks! Link to comment Share on other sites More sharing options...
LGT Dave Posted January 13, 2008 Share Posted January 13, 2008 Mine does the same thing. There are no synchros on the reverse gear, so the teeth have to match up almost exactly for it to engage. It's a common occurance and there's plenty of other threads about it: http://www.legacygt.com/forums/showthread.php?t=67405 http://www.legacygt.com/forums/showthread.php?t=22493 http://www.legacygt.com/forums/showthread.php?t=17181 http://www.legacygt.com/forums/showthread.php?t=3216 Link to comment Share on other sites More sharing options...
Underdog Posted January 13, 2008 Share Posted January 13, 2008 Double-clutching almost always works for me when stationary. Don't try to force it and focus on your double-clutching technique. I park on a very slight incline so I usually clutch-in, let out the e-brake and as I start to roll backwards I let the shifter fall into place with light pressure. Blip the revs, clutch-out and gone... The Crimson Dynamo Link to comment Share on other sites More sharing options...
Zed 2.0 Posted January 13, 2008 Share Posted January 13, 2008 I have the same problem as the OP, as bad or worse. It's stiff getting into R about 1 in 5 shifts. 1 in 10 is bad enough that I have to drive forward in 1st before I can get into R. I'm amazed Subaru makes a tranny with such crap behavior. The notchy, craptacular 5MT is definitely the most disappointing part about this car. Link to comment Share on other sites More sharing options...
fweasel Posted January 13, 2008 Share Posted January 13, 2008 double clutching usually does it for me. ignore him, he'll go away. Link to comment Share on other sites More sharing options...
subieboyLGT05 Posted January 13, 2008 Share Posted January 13, 2008 Mine does this too..so did my rex...it makes our cars unique... Link to comment Share on other sites More sharing options...
forestir Posted January 13, 2008 Share Posted January 13, 2008 You needn't engage 1st and creep forward. Just drop back to neutral, let out clutch briefly (this is what allows the tranny gears to spin to a new position relative to the reverse gear), and clutch in and try Reverse again. Link to comment Share on other sites More sharing options...
Zed 2.0 Posted January 13, 2008 Share Posted January 13, 2008 You needn't engage 1st and creep forward. Just drop back to neutral, let out clutch briefly (this is what allows the tranny gears to spin to a new position relative to the reverse gear), and clutch in and try Reverse again. This usually works for me, but there is that one shift in ten where nothing works but driving forward. I'm thinking about taking it into a dealer but I suspect the ones around here will tell me it's "within spec" Link to comment Share on other sites More sharing options...
edkwon Posted January 13, 2008 Share Posted January 13, 2008 Mine does this too..so did my rex...it makes our cars unique... Yep both my 5 MT Imprezas had the same issue, i always had to throw it into 1st then R in order to properly engage it. The subaru 5 MT box has been essentially unchanged for 15-20 years, hence the consistency in the quirks. Link to comment Share on other sites More sharing options...
starla79 Posted January 14, 2008 Share Posted January 14, 2008 The trick i always use is to put it back in neutral and ever so gently push on the gas while putting it back into reverse -- don't punch the gas (not the easiest thing to do in a LGT) and then try to shift, you have to be gentle and gas/shift nearly simultaneously. Too much gas and you'll grind it (which is why my husband doesn't use this trick to get it to shift -- he always grinds it and I never do). If you're on an incline, letting it roll back a tiny bit sometimes helps. My integra had the same issue and once i figured out the gas trick i had no trouble getting it into reverse. I only notice the LGT doing it when it's on a slight incline, too... never on a steep incline or flat surface. Link to comment Share on other sites More sharing options...
vr4Legacy Posted January 15, 2008 Share Posted January 15, 2008 ^ I started using the same technique on my '05 impreza. Thought it was because I had the "cheap" model and the problem would be eliminated with the upgrade... oh well I still LOVE this car and would buy it again, it's just so damn unique, even down to it's quirky tranny Link to comment Share on other sites More sharing options...
NSFW Posted January 15, 2008 Share Posted January 15, 2008 It's what makes a Subaru, a Subaru. Link to comment Share on other sites More sharing options...
Voo Posted January 15, 2008 Author Share Posted January 15, 2008 It seems that releasing the clutch before engaging Reverse helps it a lot. Thanks Forestir! It does feel kinda weird tho, I'll just have to keep at it Link to comment Share on other sites More sharing options...
bama16 Posted January 15, 2008 Share Posted January 15, 2008 mine does it...but all my manuals have done it. if it's not fiding it when i try to put in in reverse...i just let off the clutch and push it back in...usually finds it then. Link to comment Share on other sites More sharing options...
