mustang killer Posted November 23, 2007 Share Posted November 23, 2007 im selling my AEM CAI because the stock MAF size is too restrictive for the turbo i am putting in soon. so i am looking for a FMIC-friendly intake that is easily tunable and has a bigger MAF diameter than the stock one and AEM Link to comment Share on other sites More sharing options...
mikeyan Posted November 23, 2007 Share Posted November 23, 2007 might want to go custom made... mine is a 3" custom fabbed by my tuner, with a velocity stack and the 5" filter from my k&n typhoon. Talk to your tuner to see what he/she is comfortable with and familiar with tuning. At the stage of the game that you're at, you want your tuners input on a lot of the parts you pick up. That isn't to say your tuner or my tuner is entirely right, but you do want to run things by them. Mike SoCal Duck Hunters Club - Unit 52 Link to comment Share on other sites More sharing options...
Infamous1 Posted November 23, 2007 Share Posted November 23, 2007 Once again, see if they are compfortable with tuning a blow through MAF setup. Link to comment Share on other sites More sharing options...
boostsr20 Posted November 24, 2007 Share Posted November 24, 2007 Blow through is pimp. Definately the way to go if your looking for max power. Link to comment Share on other sites More sharing options...
mwiener2 Posted November 24, 2007 Share Posted November 24, 2007 Blow through usually ends up with a blow up My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
Infamous1 Posted November 24, 2007 Share Posted November 24, 2007 ^^^ Explain how Mr. Speed Density... Link to comment Share on other sites More sharing options...
mwiener2 Posted November 24, 2007 Share Posted November 24, 2007 The hot wire system isn't designed to work under pressure. It measures air by how much voltage is required to keep a wire at a certain temp. When you pressurize air, you move the same amount of air at a lower velocity. Because the pressure of the air has very little effect on the wire compared to the amount of air moving over it, you get inaccurate readings. Also, if you still have your recirc and/or pcv system intact, it's very easy to get the wire covered in oil and crap and really throw off the readings. You can redo your entire MAF table in the ECU to compensate for the pressurized readings, but it's really only the tuner's best guess as to what is actually happening. It's really just a major pain in the ass that Subaru decided to use MAF instead of MAP. Blow through should be easier to control idle and make it harder to max out the MAF sensor. But Draw through is safer....although much harder to get idle right and you can max out the MAF fairly easily. My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
Infamous1 Posted November 24, 2007 Share Posted November 24, 2007 Makes sense to me, however I haven't heard of any engine failures due to incorrect readings. Link to comment Share on other sites More sharing options...
mwiener2 Posted November 24, 2007 Share Posted November 24, 2007 We have had 3 here in boulder this summer. My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
VTGT Posted November 24, 2007 Share Posted November 24, 2007 I hear the avo intake is pretty nice If it worked on Wuki's sz55 i think you should be fine. Link to comment Share on other sites More sharing options...
mustang killer Posted November 25, 2007 Author Share Posted November 25, 2007 the avo cold air intake or avo short ram? Link to comment Share on other sites More sharing options...
AKLGT Posted November 25, 2007 Share Posted November 25, 2007 the avo cold air intake or avo short ram? you need an interfooler! j/k i would think if you're going with an FMIC, you'd need to go with the SR.. Doesn't the FMIC piping go where most of the CAI tubes usually go? what about the Perrins? Wiggle wiggle wiggle wiggle wiggle yeah!!! Link to comment Share on other sites More sharing options...
mustang killer Posted November 25, 2007 Author Share Posted November 25, 2007 you need an interfooler! j/k i would think if you're going with an FMIC, you'd need to go with the SR.. Doesn't the FMIC piping go where most of the CAI tubes usually go? what about the Perrins? i already got my FMIC covered. its an XO2 racing FMIC. i sold my AEM because i dont think it would fit with the FMIC but most intakes work, u just gotta avoid the ones that go deep into the fender such as the AEM Link to comment Share on other sites More sharing options...
VTGT Posted November 25, 2007 Share Posted November 25, 2007 the avo cold air intake or avo short ram? http://rallitek.com/avopoinkit.html Link to comment Share on other sites More sharing options...
mustang killer Posted November 25, 2007 Author Share Posted November 25, 2007 http://rallitek.com/avopoinkit.html is this what wuki had? if so im gettin this Link to comment Share on other sites More sharing options...
VTGT Posted November 25, 2007 Share Posted November 25, 2007 is this what wuki had? if so im gettin this and more information http://legacygt.com/forums/showthread.php?t=53097 Yes I think wuki had it with his setup (sz55) Link to comment Share on other sites More sharing options...
AKLGT Posted November 25, 2007 Share Posted November 25, 2007 i already got my FMIC covered. its an XO2 racing FMIC. i sold my AEM because i dont think it would fit with the FMIC but most intakes work, u just gotta avoid the ones that go deep into the fender such as the AEM right, that's a full CAI vs the short ram like the one VTGT posted. the full CAI goes all the way down into the fender well. That's why i figured it'd not work with an FMIC since your piping would need to go there. plus, SR is much easier to deal with when it comes time to clean. Wiggle wiggle wiggle wiggle wiggle yeah!!! Link to comment Share on other sites More sharing options...
mustang killer Posted November 25, 2007 Author Share Posted November 25, 2007 and more information http://legacygt.com/forums/showthread.php?t=53097 Yes I think wuki had it with his setup (sz55) thanks i appreciate it! looks like a great intake, i have heard good things about it, im gonna get it Link to comment Share on other sites More sharing options...
Infamous1 Posted November 25, 2007 Share Posted November 25, 2007 Search the socal forum there is a slightly used one forsale. By the way the AEM probally would of fit but you most likely would of maxed the MAF out. Link to comment Share on other sites More sharing options...
mustang killer Posted November 25, 2007 Author Share Posted November 25, 2007 Search the socal forum there is a slightly used one forsale. By the way the AEM probally would of fit but you most likely would of maxed the MAF out. i sold it for that reason mostly Link to comment Share on other sites More sharing options...
wukindada Posted November 25, 2007 Share Posted November 25, 2007 The AVO CAI will work with a FMIC it is a very tight fit but it does work. It by no means reaches as far into the fenderwell as the AEM but 90% of the filter is in the fenderwell. For the $ it's a great buy!! Toyota 6EATS .........SUCK!!!!!! Link to comment Share on other sites More sharing options...
Legacy_GT_Pilot Posted November 25, 2007 Share Posted November 25, 2007 I'm maxxing out my MAF with the AEM and a 20G. Does anyone know the diameter of the AVO cold air intake? How much more headroom is this going to provide? Dave ________ Hotels In Mexico Link to comment Share on other sites More sharing options...
wukindada Posted November 25, 2007 Share Posted November 25, 2007 Edmund has a write up about it;) It is larger than the AEM & the AVO has no difficulty @ all at 460whp....... Toyota 6EATS .........SUCK!!!!!! Link to comment Share on other sites More sharing options...
