Agnt86 Posted November 20, 2007 Share Posted November 20, 2007 Hey guys, I just noticed this, and wanted to see if anyone has a workaround. I've got a 2008 2.5i Limited. I did the DRL "mod". Basically, I found the plug labeled DRL underneath the kickplate and unplugged it. That turned off the DRLs as expected. However now, when you engage the high beams, the blue indicator light does not appear on the cluster. I plugged the DRL module back in, and the high beam indicator starts appearing again in the cluster. It looks like the plug contains both the DRL wiring and the high beam indicator wiring. Does anyone know the pinout of the DRL plug? I would love to pop the pin out to disable the DRLs, but keep the rest of the module plugged in to retain the high beam indicator if at all possible. Link to comment Share on other sites More sharing options...
whobaru Posted November 20, 2007 Share Posted November 20, 2007 Link to comment Share on other sites More sharing options...
tito_b0y Posted November 20, 2007 Share Posted November 20, 2007 crap, are you kidding me? i just unplugged mine 20 minutes ago. are the high beams working even though the blue indicator doesn't light up? 2006 SWP 3.0R 5EAT VDC BBQ 2008 OBP 2.5i 4EAT BBQ [RIP] Link to comment Share on other sites More sharing options...
Zed 2.0 Posted November 20, 2007 Share Posted November 20, 2007 Huh, interesting. I just went to check on mine (with the DRL mod done). High beams come on fine, but there isn't any high beam indicator. Had never noticed that. [edit] More specifically, the low beam indicator goes out when I turn high beams on, the fog beam indicator will remain on. The high beam indicator never comes on. Not a big deal, imo, but if somebody can find a fix, that's great. Link to comment Share on other sites More sharing options...
Bbc84 Posted November 20, 2007 Share Posted November 20, 2007 if u say fog light indicator stays on, have u checked if the fogs turn off when highbeams are on now? I wouldnt mind doing the mod so i can have my lows, highs, and fogs on all at the same time. Link to comment Share on other sites More sharing options...
whobaru Posted November 20, 2007 Share Posted November 20, 2007 I'll be doing this with a couple relays and a single switch so I can light up the night with the flip of one switch. Stay tuned for my walkthrough. I did this on my Integra too. Nice feature. Link to comment Share on other sites More sharing options...
Agnt86 Posted November 20, 2007 Author Share Posted November 20, 2007 The high beams come on and function normally, you just don't get the indicator on the cluster. As Zed has said, its not a big deal, but it would be nice to have it back if at all possible. Link to comment Share on other sites More sharing options...
whobaru Posted November 20, 2007 Share Posted November 20, 2007 I'm sure it involves reconnecting one or maybe two wires that were unplugged. It's got to be very simple. Link to comment Share on other sites More sharing options...
gianspi Posted November 20, 2007 Share Posted November 20, 2007 Start snipping enough zip ties and duct tape will fix anything. Link to comment Share on other sites More sharing options...
whobaru Posted November 20, 2007 Share Posted November 20, 2007 Any potential problem with a particular wire unplugged while another is still plugged in? I can't think of any. Link to comment Share on other sites More sharing options...
whobaru Posted November 20, 2007 Share Posted November 20, 2007 I think I'll bust out the meter tomorrow and figure this out...stay tuned. Link to comment Share on other sites More sharing options...
whobaru Posted November 20, 2007 Share Posted November 20, 2007 I just realized that in the title, you said unplug '08 DRL...apparently you don't need to disable the DRLs on an '08. This is in my walkthrough and I talk a little about that. http://legacygt.com/forums/showthread.php?t=69506&highlight=plug+play Link to comment Share on other sites More sharing options...
whobaru Posted November 20, 2007 Share Posted November 20, 2007 I just checked my '06 where I've done the disable and my high beam indicator still works. Link to comment Share on other sites More sharing options...
Guest Posted November 20, 2007 Share Posted November 20, 2007 I'm sure it involves reconnecting one or maybe two wires that were unplugged. It's got to be very simple. Might be or may not be that simple. The gauge cluser is on CAN (controller area network). On USDM cars the DRL module takes over some functions of BIU (body integrated unit) on JDM/EDM cars. Clearly DRL, at least on 05-06, looked like an add-on hack to an existing design. Link to comment Share on other sites More sharing options...
hmoob_gt Posted November 20, 2007 Share Posted November 20, 2007 i posted the same thread up too. but i got it solved. check hid, but no highbeam/foglights . you mainly need to unplug the blue with black stripe wire only. Link to comment Share on other sites More sharing options...
hmoob_gt Posted November 20, 2007 Share Posted November 20, 2007 try this link. this helped me out. i had the same problem. =) http://www.legacygt.com/forums/showp...8&postcount=67 Link to comment Share on other sites More sharing options...
Zed 2.0 Posted November 20, 2007 Share Posted November 20, 2007 try this link. this helped me out. i had the same problem. =) http://www.legacygt.com/forums/showp...8&postcount=67 The DRL connector on 08s is different from the 07s. Link to comment Share on other sites More sharing options...
whobaru Posted November 20, 2007 Share Posted November 20, 2007 Hopefully my '06 is the same as hmoob's. I'll try this today (day off) and let you guys know what happens. Link to comment Share on other sites More sharing options...
tito_b0y Posted November 20, 2007 Share Posted November 20, 2007 ok, a few things happened after i did the DRL mod. first, the DRL's are turned off (which i wanted to happen, of course), then i find out the high beam indicator doesn't work, but the high beams themselves work perfectly fine, and as i was driving home FROM school, i find the cruise control indicator is blinking, and the check engine light is on. now what i'm thinking is that i accidentally knocked a wire loose down there, which would explain both indicators lighting up/blinking, or i just need an oil change, which would explain the check engine light. but i still can't figure out what the problem is about the cruise control light blinking. help. please. i'm going nuts. 2006 SWP 3.0R 5EAT VDC BBQ 2008 OBP 2.5i 4EAT BBQ [RIP] Link to comment Share on other sites More sharing options...
whobaru Posted November 20, 2007 Share Posted November 20, 2007 start a new thread that has "help" in the title Link to comment Share on other sites More sharing options...
Bimmer Posted November 26, 2007 Share Posted November 26, 2007 as i was driving home FROM school, i find the cruise control indicator is blinking, and the check engine light is on. now what i'm thinking is that i accidentally knocked a wire loose down there, which would explain both indicators lighting up/blinking... but i still can't figure out what the problem is about the cruise control light blinking. help. please. i'm going nuts. Did this ever get sorted out? I did the DRL mod (I've got a 2008 OB XT), and my high beam indicator still doesn't work. I haven't had ANY problems with the cruise or CEL after 600+ miles. Am I really going to have to get out the wiring diagrams and figure this out myself?! Ben Link to comment Share on other sites More sharing options...
Bbc84 Posted November 26, 2007 Share Posted November 26, 2007 I got a CEL and flashing cruise control light before, and also unable to switch SI modes. It was becase I unpluged the MAF and turned ignition to ON position. Try resetting the ECU (unplug negative terminal, press the brake pedal a couple times, plug battery back in) then its up and running. Link to comment Share on other sites More sharing options...
tito_b0y Posted November 26, 2007 Share Posted November 26, 2007 I got a CEL and flashing cruise control light before, and also unable to switch SI modes. It was becase I unpluged the MAF and turned ignition to ON position. Try resetting the ECU (unplug negative terminal, press the brake pedal a couple times, plug battery back in) then its up and running. well i DID reset the ECU but didn't press the brake pedal, and it worked for a few hours. is pressing the brake pedal necessary? if anything i already made an appointment to bring it in for an oil change on tuesday. i'll try it again tomorrow, this time pressing the brakes. will it hurt to unplug the battery if the door is left open and the lights are on? 2006 SWP 3.0R 5EAT VDC BBQ 2008 OBP 2.5i 4EAT BBQ [RIP] Link to comment Share on other sites More sharing options...
tito_b0y Posted November 26, 2007 Share Posted November 26, 2007 Did this ever get sorted out? I did the DRL mod (I've got a 2008 OB XT), and my high beam indicator still doesn't work. I haven't had ANY problems with the cruise or CEL after 600+ miles. Am I really going to have to get out the wiring diagrams and figure this out myself?! Ben yea sorry about that, i made a new thread since i wasn't getting many replies in here. http://www.legacygt.com/forums/showthread.php?t=75373 2006 SWP 3.0R 5EAT VDC BBQ 2008 OBP 2.5i 4EAT BBQ [RIP] Link to comment Share on other sites More sharing options...
Bimmer Posted November 26, 2007 Share Posted November 26, 2007 I did some checking in the 2008 wiring diagram... See pages WI-129-132. Unfortunately, most of the wiring for the headlights and foglights goes through the DRL module. Fortunately, most the stuff we want to keep working runs through the black plug (B96), because most of it's redundant. Unplugging the white plug (B242) from the DRL module knocks out the DRL and little else, EXCEPT the hi-beam indicator. Looking at the wiring diagram, there should be a green-red (GR) wire coming out of the white plug (position #4), running towards the instrument panel. This is for the hi-beam indicator. There ought to be some way to find the right wire coming out of the turn signal/light switch (connector B71) and connect it directly to that green-red wire, bypassing the DRL module entirely. I'm not sure, but it looks like the blue-white (LW) wire going into position #1 of the black plug is from the hi-beam switch. Connecting this to the aforementioned green-red wire coming out of the white plug should make the hi-beam indicator work again. Maybe I'll crawl under the dash this weekend and see if this works... Ben Link to comment Share on other sites More sharing options...
