legandrex Posted December 14, 2004 Share Posted December 14, 2004 Does your clutch make a squeaking sound when it is pressed or released? Link to comment Share on other sites More sharing options...
Beanboy Posted December 14, 2004 Share Posted December 14, 2004 Yes. Mentioned to dealer, they tried lubricating it, didn't help. Known issue. I haven't fiddled with it yet. -B -B http://www.standardshift.com Link to comment Share on other sites More sharing options...
D-2.5-GT Posted December 14, 2004 Share Posted December 14, 2004 yeah mine seems to squeak ever so faintly, not enough to hear it when the car is moving, but at a stop it is somewhat / barely noticable....with the radio on, not at all. I don't see it as a high priority, i am sure it just needs some lube in the right place. Link to comment Share on other sites More sharing options...
gtguy Posted December 14, 2004 Share Posted December 14, 2004 [quote name='Beanboy']Yes. Mentioned to dealer, they tried lubricating it, didn't help. Known issue. I haven't fiddled with it yet. -B[/QUOTE] Ditto. I'll give them another try. They fixed it on my WRX. Kevin Link to comment Share on other sites More sharing options...
sandwood Posted December 14, 2004 Share Posted December 14, 2004 THANK YOU. I was wondering if I was the only one. Had the dealer lubricate it. came right back. I think I will ask them to replace the whole clutch pedal assembly next time. It's annoying the heck outta me. getting out of the legacy game Link to comment Share on other sites More sharing options...
legandrex Posted December 14, 2004 Author Share Posted December 14, 2004 It seems rather common to me. My old wrx did it too. My silver GT did it from day one, but the dealer was able to fix it after taking basically everything apart and replacing the tension spring and filing down burs on some metal parts apparently. I have started to notice my wife's GT doing it now too. She says she doesn't care about it, but it annoys the heck out of me. Maybe because I feel like a $29,000 car shouldn't do this. Well I am sure they can fix hers since they fixed mine, but I was hoping that Subaru would have figure out how to solve this by now. I would think they are/will be wasting a lot of money on warranty claims with regards to this. Link to comment Share on other sites More sharing options...
HansGT Posted December 14, 2004 Share Posted December 14, 2004 My clutch would squeak too. The dealer told me to give it 3000 miles for the spring to loosen up. Well 3000 miles later it was still squeaking. When I took it in for my first oil change I told them to grease it. I've since put 300 miles on the car and not a single squeak. A good tech should be able to pinpoint the problem area and give it a good coating of grease. Link to comment Share on other sites More sharing options...
rao Posted December 14, 2004 Share Posted December 14, 2004 A good tech or anyone with 5 minutes, a flashlight and some spray grease :lol: Rob   IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
canis Posted December 14, 2004 Share Posted December 14, 2004 Nope, but the clutch itself squeals when cold. And the seat squeaks when I push the clutch. I hardly notice either anymore though. Link to comment Share on other sites More sharing options...
SUBE555 Posted December 14, 2004 Share Posted December 14, 2004 Did it on my old GT and it just started showing up on the new one. I know it was temporarily fixed on the old one, but I gave up after time. I'll have them look at that when my car goes in for service on Thursday. Link to comment Share on other sites More sharing options...
Guest *Jedimaster* Posted December 14, 2004 Share Posted December 14, 2004 Mine does it sometimes and it's not all that bad- I can barely detect it. I've thought about getting under there with some spray silicon, but it's not enough to motivate me to. Link to comment Share on other sites More sharing options...
shane Posted December 15, 2004 Share Posted December 15, 2004 Yep mine certainly does - sounds like a whale mating and if the pedal is pressed slowly, it feels rough - engine on or off. Also feels rough when using the gears to slow down. My car is the non turbo 05 model in Australia. Clutch pedal was smooth but since the sound has started, it is beginning to feel rough, when pressed slowly or used to slow down using the gears as explained above. Where the slave cylinder meets the clutch arm has been lubricated by Subaru but this hasn't helped - I suspect the problem lies with the actual clutch assembly. Being looked at again next week. Is this thread about the clutch pedal inside the car squeaking or the clutch system outside the car - engine bay or bell housing?? Link to comment Share on other sites More sharing options...
Th3Franz Posted December 15, 2004 Share Posted December 15, 2004 I need to start making a list of things to have them check the next time I get the car serviced... Key fob -- still issues even after putting in a brand new battery Stuttering/hesitation -- they probably can't do anything but might as well make them know about it Clutch squeak -- happens every now and then.. And I think I noticed a rattle near the passenger door panel area and I had the stereo at pretty low volume.. I'll see if it happens again. -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
MtnSub Posted December 15, 2004 Share Posted December 15, 2004 No squeak, just STINK and I mean Skunky Just drove thru a 90 minute stop-start LA traffic jam with MT and no stink. One back up out of drive way and BIG STINK. Had 64k miles on BMW3/MT and it was in great shape, not smell, but my LegGT, STINKY. No Squeak, sorry about off Link to comment Share on other sites More sharing options...
shane Posted December 15, 2004 Share Posted December 15, 2004 Can someone please translate that previous message into English please for those of us here in Australia. Link to comment Share on other sites More sharing options...
MtnSub Posted December 15, 2004 Share Posted December 15, 2004 Sorry about that Shane, I went off topic. Started talking about how my clutch produces a bad smell, but does not squeak. The rest was poor sentence structure, and Los Angeles speak that you and any literate person missed. :redface: Link to comment Share on other sites More sharing options...
shane Posted December 16, 2004 Share Posted December 16, 2004 I keep seeing LA on the screen and do wonder what it's actually like. The Michael Mann movies don't help! (ie Heat and Colateral Damage). LA's just a little bigger than Adelaide here (1 million population). Link to comment Share on other sites More sharing options...
Euclid Posted December 16, 2004 Share Posted December 16, 2004 No noise @ 5500 miles Link to comment Share on other sites More sharing options...
Nick Posted December 20, 2004 Share Posted December 20, 2004 Mine squeaks when cold, but the squeak goes away when the car warms up. Link to comment Share on other sites More sharing options...
Unilat Posted December 21, 2004 Share Posted December 21, 2004 [quote name='Nick']Mine squeaks when cold, but the squeak goes away when the car warms up.[/QUOTE] Mine goes away when I turn the radio on... It was 0 degrees F today, and I did notice it more, but I also wasn't listening to the news as usual. BTW, this is the first real cold day I've driven the car, and it made a noticeable difference in power. Heh. Link to comment Share on other sites More sharing options...
SUBE_MN Posted December 21, 2004 Share Posted December 21, 2004 My squeaked A LOT. The dealer told me it was the starter safety switch. They replaced it under warranty. Link to comment Share on other sites More sharing options...
Avishar Posted December 21, 2004 Share Posted December 21, 2004 Mine began squeaking recently, the techs said it was the clutch return spring, they ordered it and are going to fix it under warranty Link to comment Share on other sites More sharing options...
mwiener2 Posted December 26, 2004 Share Posted December 26, 2004 Mine only squeaks when cold...but i like it...kinda sounds like my own personal BOV. My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
NonovUrbizniz Posted December 27, 2004 Share Posted December 27, 2004 my base wagon's clutch pedal has faint squeek CONTANTLY... you can't really hear it when you're driving around but it's there. Link to comment Share on other sites More sharing options...
Legacy05 Posted December 27, 2004 Share Posted December 27, 2004 No squeek here .. (Keeps fingers crossed) Link to comment Share on other sites More sharing options...
