dmiller5 Posted March 3, 2008 Share Posted March 3, 2008 excellent. If all works well, I think I will modify my V1 design to fit this guy. Maybe even a hybrid which will include both the V1 and the boost Link to comment Share on other sites More sharing options...
lossol Posted March 3, 2008 Author Share Posted March 3, 2008 I saw your V1 design. That was great. I like your idea of hybrid too. This gauge would need some kind of smoked plexiglass in front of it. (like the trip computer provides) PM me if your interested in one for development. VBG1 gauges available at www.gtboostgauge.com Link to comment Share on other sites More sharing options...
lossol Posted March 4, 2008 Author Share Posted March 4, 2008 UPDATE: The first real rev. of the board came in today. Here is the comparison shot. VBG1 gauges available at www.gtboostgauge.com Link to comment Share on other sites More sharing options...
han Posted March 6, 2008 Share Posted March 6, 2008 Received the stuff today. Don't know when I'll install. Should I just tap into the clock's wires? Link to comment Share on other sites More sharing options...
lossol Posted March 6, 2008 Author Share Posted March 6, 2008 Yes it's prolly easiest to tap on the wiring harness for the clock. All lines that are needed to connect are already there. +12, Gnd, and Ignition. Edit: (THIS IS TRUE FOR THE 2005/2006 LGTs) Do you have a wiring diagram for the 07 clock wiring harness? I bet that diagram is floating around somewhere on this site. I have the 05 06 diagrams from the "vacation Pics" posted a while ago. VBG1 gauges available at www.gtboostgauge.com Link to comment Share on other sites More sharing options...
nemo Posted March 6, 2008 Share Posted March 6, 2008 just use a multimeter If you don't vote Trump, out, you're a bigot who hates america. Link to comment Share on other sites More sharing options...
han Posted March 6, 2008 Share Posted March 6, 2008 Yeah. Finally got my computer back with the '07 vacation pix on it. Will give it a go when the time is right. Link to comment Share on other sites More sharing options...
lossol Posted March 6, 2008 Author Share Posted March 6, 2008 On my install in the 2006 I use BY (Ground) GB (ignition) and (V) illumination. Now if you look at the attached image it looks like your clock does not have the (V) line or the (GB) line. Instead of iggnition you can you can use the accesory line (YR) line In my 2006 setup I'm using th (V) illumination line. This line goes to 12V when the parking lights are on. For the 2007 clock only install the solution may be to use the (LR) line. However I'm not sure it will work, we may need to get the illumination line from somewhere else. Han, I'll have to get my multimeter on the LR line in my car to see if that voltage is compatible with the ill control line on GTBoost. Unless anyone else knows the answer...? VBG1 gauges available at www.gtboostgauge.com Link to comment Share on other sites More sharing options...
han Posted March 6, 2008 Share Posted March 6, 2008 They way I see it, I think just using your setup of BY (ground), GB (ignition), and V (illumination) should be fine. I'll play with it during my lunch break and see how it goes. Link to comment Share on other sites More sharing options...
lossol Posted March 6, 2008 Author Share Posted March 6, 2008 Sweet! Here is the first run at the install document. It's good for pictures and such. http://www.gtboostgauge.com/gtboostinstall.pdf EDIT: This install guide seems to be accurate for 2006 Auto trans only. The vac routing will differ for a manual trans. VBG1 gauges available at www.gtboostgauge.com Link to comment Share on other sites More sharing options...
dvdt Posted March 6, 2008 Share Posted March 6, 2008 Very nice. I just got the test gauge and I have been searching the vacation pics and the forum for some install info. Should have just waited a few more mins. Can't wait to get my vac lines and install this, this weekend. On the install doc, my only suggestion is that the directions to remove the trip computer be located at the top of page 2 or just before you show how to attach the adhesive. I'm quite impressed how professional everything is. From the heat shrink that holds the wires together to the little silver anti-static bag it came in. This Rocks! Link to comment Share on other sites More sharing options...
lossol Posted March 6, 2008 Author Share Posted March 6, 2008 They way I see it, I think just using your setup of BY (ground), GB (ignition), and V (illumination) should be fine. I'll play with it during my lunch break and see how it goes. Han I think I meant that you may not have the GB line and the V line. At least at the back of the clock. (by looking at the wiring diagram) Or you may, I have no idea. Let me know what you find out. VBG1 gauges available at www.gtboostgauge.com Link to comment Share on other sites More sharing options...
Mitch Posted March 7, 2008 Share Posted March 7, 2008 Nice Mod. Something I'd be interested in. Nice website too. Your link to buy isn't set up yet. You might want to deactivate the link until you're ready. (just an idea) If I'm going faster than you, Move Right. Link to comment Share on other sites More sharing options...
han Posted March 7, 2008 Share Posted March 7, 2008 Han I think I meant that you may not have the GB line and the V line. At least at the back of the clock. (by looking at the wiring diagram) Or you may, I have no idea. Let me know what you find out. You were correct on the 'not have the GB and V' wires. I dont understand how the wire diagram is supposed to work then. Isn't what the diagram says supposed to be the color of the actual wire?? Anyways, I did find the acc wire, and the ignition wire using the voltmeter. Hooking up the circuit doesn't work for me though. 12v ignition wire hooked upto red wire of the boost gauge circuit, Ground wire hooked up to black wire of boost gauge circuit, and blue wire of boost gauge circuit hooked up to what I think is the illumination wire. Nothing happens when I turn key on. I rechecked voltage, and only get 3V at the ignition wire with the circuit hooked up, and when undoing the circuit, I get 12V again. I am not that good with electronics, so I have no idea what that means. I thought I was supposed to always have 12V. Will try again tomorrow. EDIT::: You know what... The wire diagram you attached is not the correct one. IT is for the '07 2.5i, NOT GT. I got the correct diagram now, but am now very confused on my finds with the voltmeter. This wire diagram will help TONS to hook it up now. Will do tomorrow and now I am 50% sure it will work. I hope i didn't fry the boost gauge circuit. http://i272.photobucket.com/albums/jj179/hanacyGT/clockWD.jpg Link to comment Share on other sites More sharing options...
lossol Posted March 7, 2008 Author Share Posted March 7, 2008 The gauge is prolly fine. Just a matter of finding the right wires. Even reverse voltage may not kill it. I tested that before i shipped it. How was the fit? VBG1 gauges available at www.gtboostgauge.com Link to comment Share on other sites More sharing options...
han Posted March 7, 2008 Share Posted March 7, 2008 edited; i am an idiot. Looks okay. Fits well. IT is same as 06-05 just except the display I think. Link to comment Share on other sites More sharing options...
dvdt Posted March 7, 2008 Share Posted March 7, 2008 So I was looking at your routing of the vac line. It's not really going to work for a manual because the grommet you went thru is where the clutch fluid reservoir is attached. I think I'm going to look at going thru the driver side footwell or the one behind the glove box. Anyone else have any better suggestions? Link to comment Share on other sites More sharing options...
lossol Posted March 7, 2008 Author Share Posted March 7, 2008 Han thats great news that the gauge fits that location. We'll figure out the wiring! dv/dt - I never thought of that! Of corse that make sense, this whole time I was wondering why people routed their boost line through the fender and stuff. To me the glove box looks easiest. I will look around for other methods too! VBG1 gauges available at www.gtboostgauge.com Link to comment Share on other sites More sharing options...
han Posted March 8, 2008 Share Posted March 8, 2008 I routed the vac line through the driver's fender, then up behind the instument cluster, then to the gauge. I got it working. Using the correct wiring diagram for the 07 clock. -BY(black with yellow stripe) is hooked up to the black wire of the "GTBoost". -L (blue) is hooked up to the blue wire of GTBoost. -YR(Yellow with red stripe) is hooked up to the red wire of GTBoost. This is really awesome! (sorry for the crap phone cam pic) http://i272.photobucket.com/albums/jj179/hanacyGT/SSPX0247.jpg Link to comment Share on other sites More sharing options...
lossol Posted March 8, 2008 Author Share Posted March 8, 2008 Han! Wow! you got the gauge installed quick!I am so excited to see it installed in some other car than my own, really neat! So the L wire is your illumination wire? Does the illumination controll work? Wow thanks again for installing it! VBG1 gauges available at www.gtboostgauge.com Link to comment Share on other sites More sharing options...
han Posted March 8, 2008 Share Posted March 8, 2008 Yes. Everything is working great! Turn headlights on, and the gauge does a sweep in the red, and is dimmer. Turn lights off, and it does the sweep, and gets brighter! Really a cool feature. Wish I could video it. Link to comment Share on other sites More sharing options...
lossol Posted March 8, 2008 Author Share Posted March 8, 2008 Thanks for your update han! Looks like the gauge will work great with the 2007! GTBoost model year compatibility: 2005 - dv/dt will be testing fit and function 2006 - fits/works tested by me! 2007 - han will be testing fit - WORKS! 2008 - monkonmonk will be testing fit and function VBG1 gauges available at www.gtboostgauge.com Link to comment Share on other sites More sharing options...
monkonmonk Posted March 8, 2008 Share Posted March 8, 2008 lossol, That looks sick I really hope mine works out as well. However, I still have not received mine yet, I was just curious as to how you shipped it. I am sure the snow did not help with delivery though. Thanks, Monk Link to comment Share on other sites More sharing options...
lossol Posted March 8, 2008 Author Share Posted March 8, 2008 monkonmonk, Bummer, should be there by now. Yours was shipped 3-4-08 at 739pm - prolly went out the next day. Was sent first class. I think it was supposed to be 2 day del. maybe it comes in todays mail. i think your hookup will be very similar to han's VBG1 gauges available at www.gtboostgauge.com Link to comment Share on other sites More sharing options...
TSiWRX Posted March 9, 2008 Share Posted March 9, 2008 Speaking for NE-Ohio (Metro Cleveland, near-eastern suburbs) - we actually did not get mail service today. Snowed in........ I'm sure the mail's getting held-up. <-- I love Winky, my "periwinkle" (ABP) LGT! - Allen / Usual Suspect "DumboRAT" / One of the Three Stooges '16 Outback, '16 WRX, 7th Subaru Family Link to comment Share on other sites More sharing options...
