fweasel Posted June 22, 2007 Share Posted June 22, 2007 Who's running DBA4000 blanks (not slotted) and where'd you get them from? As I understand it they're special order. Did it take long to get them? ignore him, he'll go away. Link to comment Share on other sites More sharing options...
azca Posted June 22, 2007 Share Posted June 22, 2007 I asked all dealers, none of them have it in stock. TDC told me that they will have some in stock next week or so Link to comment Share on other sites More sharing options...
rao Posted June 22, 2007 Share Posted June 22, 2007 How are the brake pad gasses going to escape without the slots Good choice and good luck finding them. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
jim1969 Posted April 17, 2008 Share Posted April 17, 2008 anyone ever get these? Link to comment Share on other sites More sharing options...
Th3Franz Posted April 17, 2008 Share Posted April 17, 2008 I'm going to try and find a set of the blanks too.. I'll let you know if I have any luck. -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
fweasel Posted April 17, 2008 Author Share Posted April 17, 2008 When I was looking, I found only one dealer who had one set in stock. Don't even recall who it was. Definitely going to be a special order and seeing the slotted rears are BO'd already, have fun with that. ignore him, he'll go away. Link to comment Share on other sites More sharing options...
BrownBoy Posted April 18, 2008 Share Posted April 18, 2008 former member DriftMonkey runs them on his car. I believe he got them through ImportImage. Link to comment Share on other sites More sharing options...
jim1969 Posted April 18, 2008 Share Posted April 18, 2008 what's the advantage of running the DBA blanks over the OEM blanks? Link to comment Share on other sites More sharing options...
rao Posted April 18, 2008 Share Posted April 18, 2008 The DBA rotors come with sickers Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
jim1969 Posted April 18, 2008 Share Posted April 18, 2008 so not worth it? I've upgraded pads and lines. Anything else? Link to comment Share on other sites More sharing options...
kevinh Posted April 18, 2008 Share Posted April 18, 2008 I'm interested in DBA4000 blanks too. Just from reading so many threads, the advantage of DBA blanks would be there cooling veins. KevinH Link to comment Share on other sites More sharing options...
FPerron Posted April 18, 2008 Share Posted April 18, 2008 what's the advantage of running the DBA blanks over the OEM blanks? The DBA rotors have a more effective internal vane design, the advantage of which you will not notice on the street. Link to comment Share on other sites More sharing options...
jim1969 Posted April 18, 2008 Share Posted April 18, 2008 then since I don't track or auto-x the car, there's no reason for me to go past OEM rotors? Link to comment Share on other sites More sharing options...
kevinh Posted April 18, 2008 Share Posted April 18, 2008 And, if I'm correct....a slotted rotor is not effective for street driving either. In that it's job is to clear the glaze effect off pads caused by high heat temperatures (often caused by autocross/track) But, then I have read DBA rotors work better with pads for stopping power. Or is that BS....and it's just a better pad? KevinH Link to comment Share on other sites More sharing options...
SubLGTaru Posted April 18, 2008 Share Posted April 18, 2008 then since I don't track or auto-x the car, there's no reason for me to go past OEM rotors? Correct, spend the money on something you will benefit from. Link to comment Share on other sites More sharing options...
fweasel Posted April 18, 2008 Author Share Posted April 18, 2008 then since I don't track or auto-x the car, there's no reason for me to go past OEM rotors? Roger that. Pads, fluid, lines (for feel) are all that would be needed for the street. New tires, if you really want to improve your stopping ability. ignore him, he'll go away. Link to comment Share on other sites More sharing options...
fweasel Posted April 18, 2008 Author Share Posted April 18, 2008 And, if I'm correct....a slotted rotor is not effective for street driving either. In that it's job is to clear the glaze effect off pads caused by high heat temperatures (often caused by autocross/track) But, then I have read DBA rotors work better with pads for stopping power. Or is that BS....and it's just a better pad? 99% of the people with slotted and corss drilled rotors have them for looks. Neither feature will add any benefit for the street, IMO. For the street, your best upgrade in terms of stopping power is tires. Cheapest upgrade, pads. ignore him, he'll go away. Link to comment Share on other sites More sharing options...
praedet Posted April 18, 2008 Share Posted April 18, 2008 Interestingly though, it seems like the stock rotors are "soft" I have changed rotors on a few cars of my own, and on other folks cars, and the LGT is the only one where with ONLY a rotor change, the brakes felt stiffer. The comparison has always been w/ no bleeding after the rotor change Link to comment Share on other sites More sharing options...
BrownBoy Posted April 18, 2008 Share Posted April 18, 2008 The stock rotors are definitely "softer". The local member that got the DBA blanks got them just so he wouldn't warp the rotors with one panic stop, etc, like I have done with my stock rotors. The stock rotors can't really even take an aggressive daily driving routine:rolleyes: Link to comment Share on other sites More sharing options...
praedet Posted April 18, 2008 Share Posted April 18, 2008 ^^^Not what I am saying You will not warp the stock rotors, and they are structurally fine... All I am saying is that feel-wise, kind of like steel brakelines give you a slightly firmer pedal, I noticed with an AM rotor the pedal felt firmer. Less give. Had I not done the work, I would have assumed the brakes were bled also Link to comment Share on other sites More sharing options...
rs6er Posted April 18, 2008 Share Posted April 18, 2008 Sure it wasn't just the new pads? Link to comment Share on other sites More sharing options...
praedet Posted April 19, 2008 Share Posted April 19, 2008 Pads weren't changed at the time, niether were fluid or the lines. Only rotors... Link to comment Share on other sites More sharing options...
Guest Posted April 19, 2008 Share Posted April 19, 2008 I am running DBA 4000 blanks. Took like 3 months to get. Coincidentally I'll be selling them very soon, probably in a week, as soon as I install my Brembos. I have 15k on them, most of which was highway (two cross country trips). Link to comment Share on other sites More sharing options...
jim1969 Posted April 19, 2008 Share Posted April 19, 2008 did you notice anything different going from the OEM rotors to the DBA blanks (assuming same pads)? Link to comment Share on other sites More sharing options...
Guest Posted April 19, 2008 Share Posted April 19, 2008 Actually yes, pedal seemed bit more firmer. I know it looks like it's my head (and praedet's), but I think there was a difference. Yes, I used the same pads (Endless SSM). The only component that changed was rotors at that time. Link to comment Share on other sites More sharing options...
