DSMsuby Posted April 5, 2007 Share Posted April 5, 2007 that s2k is probably dead reliable with a drivetrain that beastly No way. Once you've seen a couple dozen projects similar to this run around for a year or two you will know what I mean. No one puts a car together better than the factory. And the factory isn't perfect either but at least they are working with the same brand new parts day after day under ideal and controlled conditions using the best tools money can buy. BTW, one of my other car forums found this. http://videos.streetfire.net/search/2jz+s2000/0/09229355-dd6d-49ae-83aa-987d0007d017.htm Link to comment Share on other sites More sharing options...
PGT Posted April 5, 2007 Share Posted April 5, 2007 sure it's the same car? chances are there's more than one silver S2000 with the swap. lots of parts look different Link to comment Share on other sites More sharing options...
DSMsuby Posted April 5, 2007 Share Posted April 5, 2007 It doesn't look like the same car to me either. Link to comment Share on other sites More sharing options...
Barrok Posted April 5, 2007 Share Posted April 5, 2007 The guys ebay site for the car says that his is only 1 of 2 cars in the world/nation (I forget) which has the swap. Not sure if I completely trust that, but I bet there aren't many. Link to comment Share on other sites More sharing options...
AWDxBOOST Posted April 5, 2007 Author Share Posted April 5, 2007 that is a different one, but its the same people who built this one i believe i still dont know why you think the motor wont be reliable. turn the boost down to "only" 600hp and i doubt you will see many problems. my friends na-t on stock block put down 496whp and ran perfectly fine for 3+ years before he sold it the 2jzgte block is even stronger than the 2jzge, 700whp can be had on the stock internals. another one of my friends has a 94tt converted to a single t88 and layed down 640whp. its never had any problems for about 2 years now Link to comment Share on other sites More sharing options...
Spec B Posted April 5, 2007 Share Posted April 5, 2007 That S2000 must be almost as fast as a SRT4? Link to comment Share on other sites More sharing options...
DSMsuby Posted April 5, 2007 Share Posted April 5, 2007 i still dont know why you think the motor wont be reliable. turn the boost down to "only" 600hp and i doubt you will see many problems. I'm not saying the motor will blow up eventually. What I'm talking about is the nuts and bolts that find a way to back themselves out. Or the wiring harness that manages to fall on the exhaust manifold or pipe. More common problems include intake and exhaust leaks that tend to cause hard starts or stalling. Wiring or hoses that rub on something and fail, etc. Of course, I'm sure there are plenty of home made parts that probably aren't built to Honda's or Toyota's standards as well. BTW, there are several things I mentioned above that could blow up a motor. Still, I would love to have this car. And I'm well aware of the robust nature of this motor. Link to comment Share on other sites More sharing options...
BDII Posted April 5, 2007 Share Posted April 5, 2007 Need forum help? Private Message legGTLT Link to comment Share on other sites More sharing options...
rao Posted April 5, 2007 Share Posted April 5, 2007 Nice looking swap. The HP numbers are a secret I bet they are. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
underpowerd Posted April 5, 2007 Share Posted April 5, 2007 I have never seen a car with a turbo the size of the GT45 with such a small diameter muffler (single muffler too). I was thinking the same thing...all that mod effort + and all that power coming out, and leaving such puny pipes . Maybe the restriction is intentional, and suits it/tames it a little . Link to comment Share on other sites More sharing options...
Penguin Posted April 5, 2007 Share Posted April 5, 2007 Something tells me that turbo lag must be a real bastard in that car, when it comes on boost mid corner watch out! Link to comment Share on other sites More sharing options...
AWDxBOOST Posted April 5, 2007 Author Share Posted April 5, 2007 I'm not saying the motor will blow up eventually. What I'm talking about is the nuts and bolts that find a way to back themselves out. Or the wiring harness that manages to fall on the exhaust manifold or pipe. More common problems include intake and exhaust leaks that tend to cause hard starts or stalling. Wiring or hoses that rub on something and fail, etc. Of course, I'm sure there are plenty of home made parts that probably aren't built to Honda's or Toyota's standards as well. ahh i see...but hopefully they did a good job ive done several swaps in honda's...k series, b series, h...etc. ive never had any problems as long as you take your time when putting it together Link to comment Share on other sites More sharing options...
