My Valentine 1 install (remote display)
Bwana
Oh, and just so that us Escort guys don't get too jealous (yes, something about the V1 that appeals to the "gadget-guy" part of me is all these integration/add-on possibilities):
http://www.radardetector.net/viewtopic.php?p=234539&highlight=#234539
^ A really slick remote display install for perhaps one of the best integrated remote radar detector and/or laser jammer combos out there.
<-- I love Winky, my "periwinkle" (ABP) LGT! - Allen / Usual Suspect "DumboRAT" / One of the Three Stooges
'16 Outback, '16 WRX, 7th Subaru Family
  • Replies 116
  • Created
  • Last Reply
I don't know how you guys can stand having the remote mounted low. First thing I do when it goes off is look at the display. Last thing you want to do is to look that far down.
I have mine mounted on the dash so I can easily see it.
Im trying it there for a few days. (or until my hands heal from all the scrapes & cuts :lol:) So far it's not that bad down there...i pretty much only drive to/from work, so i know where all the false alarms are. If it goes off, I slow down anyway (if im speeding). Not a good idea to check the display first THEN decide if you want to slow down depending on the arrows. If Ka goes off, im slowing down no matter where it's coming from. :spin:
If you slow down regardless of the arrows, that kind of defeats the purpose of having arrows. For me, the arrows determine how fast I need to slow down which is why it is mounted just below my line of sight.
http://smiliesftw.com/x/dunno.gif
Obviously if it just starts out at 1 or 2 dots, ill look and then decide, but if it goes off any higher, the best bet would be to slow down first, then look.
I'll have mine done next week it looks like. I'll put up pix once it's done, but I'm essentially doing the same remote location as Scotty, but with the remote audio unit located right near the parking brake. I had my remote display right in the center of the cluster area on my WRX and hated reaching through the steering wheel to hit the mute button.
2013 S4 - Glacier White - DSG - B&O - Tech Package - Sports Diff - Napa - RS4 Grille - Stasis Exhaust - APR Intake - KW Variant 1 - Stern Control Arms - CR-15 - Stasis RSB - Moog Endlinks - PC Hyper Black Peelers - Deval Front Lip - ECS Rear Diffuser - Carbon Imports Ducktail - ECS Mirror Caps - Relak Paddle Extensions - Autostyle Floor Mats - LED Interior - V1 - Blackvue DR900s -
[sIGPIC][/sIGPIC]
yeah i think its about time i do this, between my scangauge, my new tomtom 510, my v1 and my pod mounted boost gauge my dash/windshield area is getting a wee bit out of control
If everything seems under control, you're just not going fast enough. - Mario Andretti
I really like the OP's install and the instrument panel concept but I love the simplicity of my gauges. No clutter, straight business in a good looking format. What if you cut windows in the radio fascia mirror to the hazard lights button. Mount the board so the arrows are flush up the face and call it a day.
Today I took apart my gauge cluster to see what was exactly behind it.
I am going to change my initial design to something a little simpler to install and cheaper to replace if I mess up.
Here are some of the pictures I took:
Panel Cover (I think the part number is 85070AG22A [$50])
http://deniscoan.googlepages.com/Panel.JPG
Gauge Cluster
http://deniscoan.googlepages.com/cluster.JPG
Back Side of the Cluster
http://deniscoan.googlepages.com/Back.JPG
Guts of the V1 Display
http://deniscoan.googlepages.com/V1_bare.JPG
Yikes! I never realized that our cluster "guts" would look like that! That's some kind of complicated/clustered!
I never thought it would look like that either...
I am going to order an extra panel cover and cut the V1 display into pieces.
I figure I can cut the panel so the arrows lay flush. The other lights i will make a small grove that an overlay can be used keeping the flat back appearance, but allow the lights to illuminate when being used.
Placement would be the arrows between the RPM and Speedo. The signal count and type/strength would go to the left of the cruise/set lights.
These are the spots I would notch down inside the cluster:
Arrows:
http://deniscoan.googlepages.com/Center_cut.JPG
Count/Type/Strength:
http://deniscoan.googlepages.com/Right_Side_cut.JPG
You are one brave man, my friend! :)
Please keep us updated on how this goes - I think you'd certainly win the award for "cleanest RD integration" once this project of yours is done!
Best of luck! :)
I just received my extra V1 remote display today. I am going to modify it first and then move to the gauge panel (which I will be ordering a test subject soon).
I think the hardest part will be routing out the face of the panel to the depth of the overlay, so everything is completely flush.
I may change out a few LEDs while i am in there for some different color alerts, but am still undecided.
They're all surface mounted LED's, right? I was planning on using some of the OEM warning LED's for my WI project, but the surface mount ones might make it more difficult to solder in diodes and additional leads. I might just mount standalone LED's in the extra spaces that currently have none.
ignore him, he'll go away.
WI project?
Correct the LEDs are SMT. Also that panel is dense, not even the brightest light will pass through any area not already cut out.
sort of on a sidenote...does disconnecting the gauge cluster screw w/ the odometer at all?
The odometer info is stored in the ECU. But to be on the safe side I disconnected the battery before removing the cluster. Plus I didn't want to keep honking the horn while removing it.
i figured as much, otherwise replacing the cluster might be a huge warranty fiasco.
how much space is there in the dash behind the gauge cluster?
crazy idea: would it be possible to mount the remote display in a diy HUD sort of manner? granted it'd take a lot of work...but it'd be amazing if it worked.
and something i meant to mention in my first post, awesome project!
