Jedi Pimp Posted February 14, 2007 Share Posted February 14, 2007 What does the spacer washer do between the upper perch and the tophat? What happens if you don't use it? Link to comment Share on other sites More sharing options...
AWDxBOOST Posted February 14, 2007 Share Posted February 14, 2007 you car will fall apart if you take it out i dunno, maybe its to allow slight rotation without backing the bolt off Link to comment Share on other sites More sharing options...
rao Posted February 14, 2007 Share Posted February 14, 2007 It spreads the load of the strut to a wider area of the unibody. Is it critical? probably not. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
Waxiboy Posted February 14, 2007 Share Posted February 14, 2007 i think it is required for USDM struts and not for JDM Link to comment Share on other sites More sharing options...
Guest Posted February 15, 2007 Share Posted February 15, 2007 i think it is required for USDM struts and not for JDM Correct for Bilsteins, but not for Ohlins (which come with their own spacer washer). Link to comment Share on other sites More sharing options...
SubiGT Posted February 15, 2007 Share Posted February 15, 2007 Removing it or changing it's thickness will alter front ride height, correct? Many Shuvs and Zuuls knew what it was to be roasted in the depths of the Slor that day, I can tell you! Link to comment Share on other sites More sharing options...
Speedracerx Posted February 18, 2007 Share Posted February 18, 2007 If you're referring to the conical washer that fits between the strut and tophat, it allows the strut to rotate when you turn the steering wheel. It provides a face for the bearing in the top hat to seat against. If it is not there or installed upside down, you will have increased resistance when turning. Link to comment Share on other sites More sharing options...
NutBucket Posted February 18, 2007 Share Posted February 18, 2007 ^^^ What he said. First time I was swapping springs I reassembled in the wrong order and the top hat was very hard to turn. Reassembled and it just spun freely, like it did when it came off the car. Link to comment Share on other sites More sharing options...
PGT Posted February 18, 2007 Share Posted February 18, 2007 Dave...I've got a pair of spares if you need them. Link to comment Share on other sites More sharing options...
Waxiboy Posted February 19, 2007 Share Posted February 19, 2007 Now I am confused. My Bilstein HD came with a washer. Does that sit between the nut and top hat or spring seat and top hat? Link to comment Share on other sites More sharing options...
PGT Posted February 19, 2007 Share Posted February 19, 2007 between spring seat and tophat. The Spec B/JDM tophats have a bearing in them. The USDM tophats do not and use the cambered washer instead. I'm not sure why the HD's would come with them - are the flat, or thick with one flat side and the other cambered? Link to comment Share on other sites More sharing options...
Waxiboy Posted February 19, 2007 Share Posted February 19, 2007 it is about 1mm-2mm thick. i did notice that it is not perfectly flat...maybe i should put it between the spring seat and top hat. i'll try to assemble one tonight (minus the spring) and see how it goes. so there is no need for a washer between the nut and top hat? Link to comment Share on other sites More sharing options...
Guest Posted February 19, 2007 Share Posted February 19, 2007 JDM Bilsteins do not take any washers in front. Strut, then spring perch, then top hat, then nut and cap. Done. Link to comment Share on other sites More sharing options...
PGT Posted February 19, 2007 Share Posted February 19, 2007 as long as you have the JDM/Spec B tophat that has the bearing pressed in, you don't need the spacers. I'd surmise that using USDM tophats is ok as long as you use the washer, provided the rod on the Bilstein clears the hole that is. Link to comment Share on other sites More sharing options...
