rao Posted January 23, 2007 Share Posted January 23, 2007 Well, I plan on buying the $95 walbro. Can you elaborate on what you did to the housing to make the pump fit. I have yet to actually look at one myself and would like to know what to expect before attempting it. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
CrakuhBlack Posted January 24, 2007 Share Posted January 24, 2007 My walbro 260lph pump is know installed. The install is fairly simple, just a pain when you have to modify the housing to fit the bigger pump. You can definetely hear the new pump when priming and first starting. I'll probably get a ban or at least a stern warning for this, but...I fail to see what's laughable other than your apparent lack of reading skills and respect for other members. If you look at the above quote (which was posted immediately before my post) you will realize who I was asking. I'm well aware that the OP did NOT modify his pump assembly. It's a shame how certain moderators on this site like to give people crap instead of being helpful to the community. Thanks Robert! Link to comment Share on other sites More sharing options...
mickeyd2005 Posted January 24, 2007 Share Posted January 24, 2007 I think rao is laughing because of the difficulty involved in modifying the housing. TDC explains in detail how to do it here: http://legacygt.com/forums/showthread.php?t=38929 As a moderator, he probably should have just let you know instead of posting a laugh. That's for the regular members to make fun of eath other. Link to comment Share on other sites More sharing options...
acooper5 Posted January 24, 2007 Share Posted January 24, 2007 ^^^mickey thanks for the info, I am planning on doing the same thing as crakublak, I bought the pump now I need to modify, thanks for TDCs info thread, doesnt look all that bad...anybody now how long this could take??? Semper Fi. Link to comment Share on other sites More sharing options...
SC GT Posted February 21, 2007 Share Posted February 21, 2007 Installed the pltek/walbro unit last night; was pretty simple. I waited until my low fuel light was on, removed the fuel pump fuse, started my engine until it stalled, cranked the ignition for 5 more seconds, disconnected the neg terminal off my battery, then followed LUKEGT03's instructions. Spillage was kept to a minimum. Thanks for the write up, Luke. Link to comment Share on other sites More sharing options...
fweasel Posted February 22, 2007 Share Posted February 22, 2007 cranked the ignition for 5 more seconds, Spillage was kept to a minimum.. Yeah, wish I would have added that step as I think it might have helped relieve the last bit of pressure in the system. I tried lifting the pump from the tank slightly before removeing the three lines, but one of them was still pressurized. Oh well, over and done with. ignore him, he'll go away. Link to comment Share on other sites More sharing options...
MarcusDubya77 Posted April 29, 2007 Share Posted April 29, 2007 great write up...just changed out my pump w/ it :woowoo:check out the Diamond Gray Metallic Monster!!! Link to comment Share on other sites More sharing options...
al-gorithm Posted June 18, 2007 Share Posted June 18, 2007 ^+1 I just did this yesterday. Starting the car with the fuel pump fuse, then cranking the engine over for a few seconds resulted in no pressure in the lines. I used an old ice cream container instead of rags as quite a bit of fuel came out of the pump. It also allows you to pour the gas back in if you like (if the container is clean). I would also use something to cover the molex receptacle on the pumps to ensure no gas gets in there before you plug it back in. No nests, just some rust around there. Link to comment Share on other sites More sharing options...
PhilT Posted August 5, 2007 Share Posted August 5, 2007 Nice write up, thanks. Just swapped mine out this evening with the AVO unit. Surprised how much dirt and rust was on the top of the tank, gotta be very careful to clean it before pulling the old pump out. Otherwise very straightforward. Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
fweasel Posted August 5, 2007 Share Posted August 5, 2007 Surprised how much dirt and rust was on the top of the tank, gotta be very careful to clean it before pulling the old pump out. Dirt better than mouse ignore him, he'll go away. Link to comment Share on other sites More sharing options...
PhilT Posted August 5, 2007 Share Posted August 5, 2007 Dirt better than mouse If you could install a wheel for him to run on, then take a power output onto the main drive shaft, then a mouse would add hp, or would that be mp Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
fweasel Posted August 5, 2007 Share Posted August 5, 2007 If you could install a wheel for him to run on, then take a power output onto the main drive shaft, then a mouse would add hp, or would that be mp Yeah, you and your theoretical mp numbers. All that matters to the big boys is mp at the wheels! ignore him, he'll go away. Link to comment Share on other sites More sharing options...
Scooby2.5 Posted August 13, 2007 Share Posted August 13, 2007 I guess this is the same for the Wagon as far as the pump being under the seat? Link to comment Share on other sites More sharing options...
PhilT Posted August 14, 2007 Share Posted August 14, 2007 I guess this is the same for the Wagon as far as the pump being under the seat? Yes, just pull out the bench and there it is, passenger side. Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
PLTek Posted August 17, 2007 Share Posted August 17, 2007 nice write up, anyone else need a walbro? Link to comment Share on other sites More sharing options...
R man P Posted August 17, 2007 Share Posted August 17, 2007 once i get a few issues worked out with my FMIC i am going to order one. Link to comment Share on other sites More sharing options...
PLTek Posted August 17, 2007 Share Posted August 17, 2007 ROCK ON !!!!once i get a few issues worked out with my FMIC i am going to order one. Link to comment Share on other sites More sharing options...
mwiener2 Posted September 30, 2007 Share Posted September 30, 2007 what's the difference between the PLtek one and the AVO one My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
spiralsmurf Posted October 26, 2007 Share Posted October 26, 2007 Is there a writeup for how to install the fuel pump into the basket by yourself? Link to comment Share on other sites More sharing options...
BDII Posted October 26, 2007 Share Posted October 26, 2007 Pump install makes me Need forum help? Private Message legGTLT Link to comment Share on other sites More sharing options...
XLeezardx Posted October 26, 2007 Share Posted October 26, 2007 Fuel pump install isnt that bad if u have the right tools. After removing/install my AVO, Walbro, and OEM fuel pump 20 times I know it like the back of my hand. The difference about the AVO and Walbro fuel pump is that the AVO comes with a new fuel filter that actually fits, plus it has clips that snap in and hold in the assembly housing. The AVO is also quieter and seems like a much mure quality peice. Link to comment Share on other sites More sharing options...
mwiener2 Posted October 27, 2007 Share Posted October 27, 2007 what's the difference between the PLtek one and the AVO one My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
boostsr20 Posted October 31, 2007 Share Posted October 31, 2007 Hows the seat actually come out? Is it just teh lower that needs to come out? Where are those clips at on the seat? Link to comment Share on other sites More sharing options...
pegleg Posted November 25, 2007 Share Posted November 25, 2007 I've done search after search, and have yet to see a definitive answer or picture. I followed a tdc writeup on here and modified my fp housing by grinding out the ribs inside and adding a walboro with the terminals modified and stock sock, put everything back together (done it twice now double checking all the o-rings which were new) and am still experiencing the pressure loss manifested by a need to prime for 1-2 sec. before starting. Do I need to grind off more than the ribs on the housing? This is maddening. Could it be a bad check valve in the fuel pump itself? In one of these myriad threads I remember reading that grinding off the ribs is only "semi-divulging" the "SECRET". Any documented solution with pics for the do it yourselfer? Prettttttty pleeeeeeeeeeeease? Link to comment Share on other sites More sharing options...
spiralsmurf Posted November 25, 2007 Share Posted November 25, 2007 i would ditch the stock fuel sock and plumb in a regular fuel filter. just realize that you're gonna have to spend $200 in a few years when you want to change your filter. Link to comment Share on other sites More sharing options...
