Abandonhope16 Posted December 13, 2006 Share Posted December 13, 2006 Can anyone with experience, provide some info on this setup. I guess I'm getting older, and I dont want anything really loud; but I'd still like to have some tone to the exhaust. It seems to be reasonably priced compared to other options, but is it still noticeable for what you pay/worth it? Thanks in advance. -A Link to comment Share on other sites More sharing options...
Waxiboy Posted December 13, 2006 Share Posted December 13, 2006 I assume you are in Reston so if you want you can listen to my set-up. Link to comment Share on other sites More sharing options...
Abandonhope16 Posted December 13, 2006 Author Share Posted December 13, 2006 What exactly is your setup? Yeah, I work in Reston. Link to comment Share on other sites More sharing options...
Waxiboy Posted December 13, 2006 Share Posted December 13, 2006 STi UP + Cobb DP w/ HFC + stock mid/Y-pipe + Prodrive mufflers Link to comment Share on other sites More sharing options...
Daedalus Posted December 13, 2006 Share Posted December 13, 2006 STi UP + Cobb DP w/ HFC + stock mid/Y-pipe + Prodrive mufflers That sounds exactly like the setup I want! Do you also happen to know piping diameters are for the Perrin center section? Isn't it 3" and after the Y split it goes down to 2.5"? Or is it 2.25" after the Y? I know the Y portion bolts up to the stock axelbacks but does the 3" section that bolts up to the downpipe share the same donut gasket that the stock pipe does (therefore tapering down to 2.5")? NM. I just read that you have the stock mid/Y instead of the Perrin one. Durrrrrrrrrr. Link to comment Share on other sites More sharing options...
Waxiboy Posted December 13, 2006 Share Posted December 13, 2006 ^ there was someone on the boards that installed Lachute mid/Y (similar to Perrin I think) and Prodrives and he commented that it was too loud. With my set-up, it is nice and quiet with just a bit of that boxer rumble...until you go WOT :D Link to comment Share on other sites More sharing options...
Abandonhope16 Posted December 13, 2006 Author Share Posted December 13, 2006 ^^I believe that was Hal9e3, but I could be wrong Link to comment Share on other sites More sharing options...
IwannaSportSedan Posted December 13, 2006 Share Posted December 13, 2006 Stock mid-y-pipe has a nice big resonator in it, as well, not just the pipe diameter difference. I forget, but perrin either has none, or a small resonator... that will make a difference. I have a de-resonator-ed stock mid-y-pipe, and aftermarket mufflers, and it is VERY loud. Intrusively so. Nice sound. too much volume. Link to comment Share on other sites More sharing options...
j255c Posted December 13, 2006 Share Posted December 13, 2006 i have crucial complete dp setup (catless) w/ stock midpipe resonating section and stock y-pipe and perrin muffs. I have a perrin y-pipe i think im going to just weld in since the y-pipe is the most restrictive part i have left in my exhaust. Then get a perrin 3" catless dp for when I go big My brother thinks its too loud, my father likes it. My brother got a exhaust ticket for going WOT infront of a cop though. hes an idiot. 06 TB EVO IX SE stock turbo monster subaru hater Link to comment Share on other sites More sharing options...
MacLGT-B Posted December 13, 2006 Share Posted December 13, 2006 I have the PERRIN Catted Downpipe hooked up to The PERRIN Mid & Y-Pipe with the Hi-Flow Resonator in the Mid-Pipe and a pair of Hi-Flow AVO Mufflers. And it's loud, sweet but Loud. Link to comment Share on other sites More sharing options...
VXCL Posted December 13, 2006 Share Posted December 13, 2006 running up/cobb catted dp/perrin mid and y/stock cans barely any change overstock. no one would ever notice. slightly deeper rumble at idle, but again no one but you may be able to notcie the change. adds some shiny bling under the car. also from dataloging the perrin pipes allow about 8 more g/s through the maf, so its defintely making some more power. not enough for the butt dyno, but 5th gear is smoother on the highway and the turbo holds a little more boost to redline. not much. best part is my car is still super quiet thanks to those crazy stock cans with the brick walls inside them MAYHEM #122/22 STS NNJR SCCA AUTOX4U.COM XENON RETRO GUIDE Link to comment Share on other sites More sharing options...
automaticsti Posted December 13, 2006 Share Posted December 13, 2006 running up/cobb catted dp/perrin mid and y/stock cans barely any change overstock. no one would ever notice. slightly deeper rumble at idle, but again no one but you may be able to notcie the change. adds some shiny bling under the car. also from dataloging the perrin pipes allow about 8 more g/s through the maf, so its defintely making some more power. not enough for the butt dyno, but 5th gear is smoother on the highway and the turbo holds a little more boost to redline. not much. best part is my car is still super quiet thanks to those crazy stock cans with the brick walls inside them Same setup here except i have catless DP and an invidia upipe...with the stock cans you cant even tell the diffrence untill you step on then it growls. Link to comment Share on other sites More sharing options...
VXCL Posted December 14, 2006 Share Posted December 14, 2006 Same setup here except i have catless DP and an invidia upipe...with the stock cans you cant even tell the diffrence untill you step on then it growls. i still cant hear any change over the engine, turbo, and gear whine of the MT it is also much easier to backfire under no load MAYHEM #122/22 STS NNJR SCCA AUTOX4U.COM XENON RETRO GUIDE Link to comment Share on other sites More sharing options...
automaticsti Posted December 14, 2006 Share Posted December 14, 2006 i still cant hear any change over the engine, turbo, and gear whine of the MT it is also much easier to backfire under no load rev it up with the door open...maybe it has to do with your cat also......mine f'in growls...almost sounds 350zish Link to comment Share on other sites More sharing options...
hal9e3 Posted December 14, 2006 Share Posted December 14, 2006 ^ there was someone on the boards that installed Lachute mid/Y (similar to Perrin I think) and Prodrives and he commented that it was too loud. With my set-up, it is nice and quiet with just a bit of that boxer rumble...until you go WOT :D Yep, that's me. I kept the Lachute and reverted back to stock cans, blacked out, with Borla tips. I'm very happy with the results. Nice subtle growl, but never loud or obnoxious. SOMEDAY I want to dyno the car w/ and w/o the stock cans to see what the max gains are available from different mufflers. Link to comment Share on other sites More sharing options...
VTGT Posted December 14, 2006 Share Posted December 14, 2006 nova people yay....I want to hear too Link to comment Share on other sites More sharing options...
VXCL Posted December 18, 2006 Share Posted December 18, 2006 rev it up with the door open...maybe it has to do with your cat also......mine f'in growls...almost sounds 350zish i was actually at dinner with another member mmm def and shortly after I got home i get a call from him "i heard you pull away out of the parking lot. sounds f@#$@$g mean!" so i guess it did something but seriously my gear whine is loud in 1st and 2nd, so i can't tell any difference from inside the car. however i took my fam to dinner a couple days ago, so the radio wasn't on and on the highway there is def a very slight hum of the exhaust, but nothing they noticed. I know prior perrin mid/y all i had to listen to was the re92s and maybe some wind every now and then. MAYHEM #122/22 STS NNJR SCCA AUTOX4U.COM XENON RETRO GUIDE Link to comment Share on other sites More sharing options...
Puckman Posted December 19, 2006 Share Posted December 19, 2006 The Peerin y/mid is catless right? With you're setup, is just the high flow cat in the cobb enough to stop alot of the smell, or does the setup reek to all hell? Link to comment Share on other sites More sharing options...
KGreb Posted December 19, 2006 Share Posted December 19, 2006 There is not a cat in the stock y/mid, only a resonator. Link to comment Share on other sites More sharing options...
Puckman Posted December 20, 2006 Share Posted December 20, 2006 Thanks. So if you run this set up with a Cob Up & Down w/HFC how bad are we talking here for cat stink, since you'd only be running one HFC in the whole setup? Link to comment Share on other sites More sharing options...
VXCL Posted December 21, 2006 Share Posted December 21, 2006 Thanks. So if you run this set up with a Cob Up & Down w/HFC how bad are we talking here for cat stink, since you'd only be running one HFC in the whole setup? i never smell anything. no diffrent to me then when the car was stock unless its a colder or damp day when you just start it up. if you stand behind it there is a slight exhuast smell. inside the car there is never a smell. never has anyone said anything either. cobb hfc is a good choice along with the perrin pipes and stock cans seriously if i had to get a sniffer test for emissions i bet it would pass no prob MAYHEM #122/22 STS NNJR SCCA AUTOX4U.COM XENON RETRO GUIDE Link to comment Share on other sites More sharing options...
antny Posted December 21, 2006 Share Posted December 21, 2006 I have MR headers with catless up and perrin catless dp and stock mid and y with perrin axleback and I just had the resonator cutout on my mid and she sounds mean now just a tad bit louder then what my WRX was. But on my WRX I didnt have headers but had a 3 inch catless tbe. I like how my car sounds now pretty throaty and deep. Link to comment Share on other sites More sharing options...
